First time poster.
I was given a couple of USB scopes that were meant for teaching in the field, but were deemed useless due to their peculiarities and limitations!
Although the scopes perform well within their stated specs (low noise, accurate measurement and good frequency response), the main issue being that they don't have the internal electronics to do AC coupling.
I've played with putting a passive high pass filter on the scope probes (before and after the probe ).
This removes the DC but of course affects the signal at low frequencies.
I'll eventually either give up on them and regard them as toys OR get round to adding more stages, increasing the roll off rate & lowering the cut off frequency, plotting an actual frequency response for it and fiddling with software to compensate.
The questions that arose were:
1- what would this do to the overall input impedance? (as seen by the test point?)
2 - would using active filters be a better idea? (wouldn't this cause other issues related to the amplifiers' own bandwidth?)
3 - more important, how do real oscilloscopes vary the coupling? (particularly AC coupling)
Thanks in advance.
