It appears that he is measuring the voltage across the series combination of an inductor, LED and resistor, and then also measuring the voltage just across the resistor. The latter will be proportional to the current.
I have a video that describes the voltage and current flow through capacitors and inductors, started with pen & paper, then followed up by some scope measurements:
