Author Topic: SLA Battery Question  (Read 1249 times)
Offline threephase03Topic starter
« on: January 22, 2022, 10:39:31 am »
Hi Everyone.
I have a 24V load that takes around 3.2A for approximately 25-30min then 0.5-1A for another 45min.
The question is....  I want to buy two 12V SLA Batteries and run them in series what sort of issues could
I face with this type of application?
I have a feeling there might be a discharge rate problem
Issues with charging them back again and again. (Wouldn't be a daily use maybe twice a week)
Link to what i want to buy
https://www.jaycar.com.au/12v-9ah-sla-battery/p/SB2487?pos=9&queryId=aa8d8b3a70a7afd7c1a1e95ef57b547d&sort=relevance
Thanks for any input/help
TIA
Online T3sl4co1l
    • Seven Transistor Labs
Re: SLA Battery Question
« Reply #1 on: January 22, 2022, 10:41:24 am »
If the units are identical, there's no problem.
What do you think they do internally? :D (12V is 6 cells in series)
Seven Transistor Labs, LLC
« Reply #2 on: January 22, 2022, 10:48:43 am »
Im worried about the longevity of the application. I know it will work. But is it a to simple idea and im failing to see something?
Offline BradC
« Reply #3 on: January 22, 2022, 10:53:53 am »
It'll be fine, but don't expect those Jaycar batteries to last when you cycle them that hard.
Something like a Vision FM or CSB GP series would likely last longer. The big trick to SLA longevity is charging them correctly.
« Reply #4 on: January 22, 2022, 11:04:49 am »
Thanks for the advice ill check them out. Much appreciated.
I was thinking about using one of those car trickle chargers.
Online T3sl4co1l
« Reply #5 on: January 22, 2022, 01:05:18 pm »
And not over discharge; going under 50% is bad for lead acid.
Offline BrokenYugo
« Reply #6 on: January 22, 2022, 08:40:55 pm »
Balance/equalization charges are just part of life with lead acid.
« Reply #7 on: January 22, 2022, 10:12:38 pm »
Thanks for everyone's input. I've got a 24V battery charge indicator, thinking about installing it on the battery box so I can check during use.
Guess I'm hoping when it indicates its close to flat it isn't below the 50% min level mentioned
Offline Circlotron
« Reply #8 on: January 22, 2022, 10:33:24 pm »
You could always charge them with two independent 12V chargers at the same time. 13.65V @ 20 deg C. More readily available than 24V chargers and less likelihood of cell voltage imbalance because of a shorter string of cells.
Online NiHaoMike
    • Facebook Page
« Reply #9 on: January 23, 2022, 01:49:18 am »
Might want to consider 6S lithium ion instead, similar cost to sealed lead acid (particularly for small packs) but lasts a lot longer.
« Reply #10 on: January 23, 2022, 02:38:27 am »
Yeah thats what I was thinking, I already have one for my car as it sits there a bit now with all the stuff happening now days
Offline SmallCog
« Reply #11 on: January 23, 2022, 11:57:35 am »
One of the instruments we use draws 16A for 3 seconds once an hour. Power is provided by a 7AHr lead acid battery and we find 3 years to be a safe service life.
As above no issues with series batteries, but if they don’t age the same one will die first. When ones dies you’ll have to replace both
*not using random jaycar batteries so can’t speak for their reliability but we find the century batteries from BSA to be exceptionally good.
« Reply #12 on: January 26, 2022, 03:45:05 am »
If I could get 10 - 15 charges out of them they will make their money back.
So ill think it will be right
Thanks for everyone's help
Offline tkamiya
« Reply #13 on: January 28, 2022, 07:17:35 pm »
Why not buy a 24V SLA?  They are not as common but they do exist.
