Hi. I was doing some work on the house. I was going to replace the old telephone line with Cat6. So I did what any electrician does, taped the two cable together, and started pulling on the old cable. It went well, up to the ~90% of the way, when the telephone cable just snapped. I started investigating, so the conduit is filled with concrete. The conduit is poured in concrete, and somehow it is very much filled up just below the surface. The blockade starts at around 50mm below the surface, and I have no way of telling where does it end.
Otherwise the conduit is smooth, I have no trouble whatsoever pushing that CAT6 cable through up to the point where the blockade starts.
So any tips? I dont think I can chisel it out, it is at an awkward angle, close to the wall, angled the opposite direction of the wall. How did concrete get there is beyond me, or how they pulled the phone line through in the first place.
