Author Topic: getting 18.6 volts from a 12 volt powersupply?  (Read 1448 times)
Offline vulturebetrayerTopic starter
« on: September 05, 2016, 08:43:29 pm »
I'm still a bit new to figuring out power output etc, but this seems wrong.
Is there something I'm doing wrong or is this power supply shitting on me?
not sure why image link is broken, here's a direct link:
http://imgur.com/a/LCpYG
I'm just a terrible programmer who thinks electrons flow through tubes.
Offline Zero999
  • 0999
Re: getting 18.6 volts from a 12 volt powersupply?
« Reply #1 on: September 05, 2016, 08:59:36 pm »
No, it's perfectly normal and to be expected. You have an unregulated power supply, which will give a much higher voltage than its rated value, when lightly loaded. Don't use it for anything which might be damaged by the higher voltage output.
The following users thanked this post: vulturebetrayer
Offline langwadt
« Reply #2 on: September 05, 2016, 09:07:08 pm »
The supply has little or no regulation so the voltage will be high without load, it is quite normal
for that kind of supply
« Reply #3 on: September 05, 2016, 09:15:24 pm »
Thanks folks, that helps out.
