Author Topic: Electrolytic Capacitor questions  (Read 2370 times)
Offline Joule ThiefTopic starter
« on: June 20, 2014, 04:04:48 am »
I am in the process of repairing a HP 6237B triple output power supply ( 0.5 volt ripple on ALL outputs).
The problem seems to be centered around a dried out metal can electrolytic cap in the REF and BIAS supply. 13 volts of ripple on the cap is not helping.
My question is in regards to the value of this capacitor. The value is marked as 490uf at 85 volts. Why would the design spec out 490uf when 470 uf would be a more common value? Is it possible 470 was not available in an appropriate form factor and a 490 cap was available ?  I can't believe 20uf would make a difference in the circuit performance.
Perturb and observe.
Offline c4757p
  • adieu
Re: Electrolytic Capacitor questions
« Reply #1 on: June 20, 2014, 04:09:57 am »
Typical HP, they used all sorts of bizarre capacitor values. Just use 680uF :P
« Reply #2 on: June 20, 2014, 04:34:46 am »
470uF 160V is a common value, and will likely fit as well. The only reason HP used odd values was because they made the capacitors themselves, or were buying enough to specify a value that was the maximum a manufacturer could stuff into a can.
Offline Hydrawerk
« Reply #3 on: January 26, 2019, 11:14:16 pm »
What is this capacitor? Is it a RD series from Samwha?
http://www.samwha.com/electric/product/list_pdf2/RD.pdf
Offline Electro Detective
« Reply #4 on: January 26, 2019, 11:37:35 pm »
Buy a handful of assorted (not in a packet) 470 uf caps from a local electronics parts shop, and I'll bet one or two of them will kick in at 490 uf
or... if you're in good with the staff and or a regular customer (like me  :-* ) bring in a cap tester/multimeter and explain what the deal is, and they usually say ok
and may help you sort some out too on the counter if the shop isn't busy
Best to go when it's the slow part of the day and the staff aren't 'multitasking'  :blah: |O :rant: :horse:
FWIW: I discharge/short the unsuitable value caps after testing, before returning them to their spot in the shop
I do the same test biz with resistors and potentiometers when I need a freaky value or matched pairs/quads etc
It saves time, money, online purchase headaches, keeps the shop in business
and fellow electronerds in a job  :-+ :-+
Offline tkamiya
« Reply #5 on: January 27, 2019, 03:20:23 am »
If tolerance of them are like many, there IS no differfence between 470 and 490.  Electro-dialetic capacitors can vary as much as 100% on PLUS side.
The following users thanked this post: spec
