Author Topic: Separating THT components from the PCB - metal post thing  (Read 5039 times)
Offline ElectronicsNewbieTopic starter
« on: July 28, 2015, 08:04:37 pm »
Hi guys,
This is really silly question. Whats the proper name for this metal post thing that lifts up the power resistor in this case?
Thanks for your help!
« Last Edit: July 28, 2015, 10:32:57 pm by ElectronicsNewbie »
Online T3sl4co1l
    • Seven Transistor Labs
Re: Separating THT components from the PCB - metal post thing
« Reply #1 on: July 28, 2015, 11:05:41 pm »
I thought I had seen them somewhere before... possibly in here,
http://www.digikey.com/product-search/en/connectors-interconnects/terminals-pc-pin-single-post-connectors/1442576
but good luck digging.
Seven Transistor Labs, LLC
Offline Whales
    • Halestrom
« Reply #2 on: July 28, 2015, 11:10:45 pm »
(Completely tangential)
I have a similar resistor permanently branded with a burnt copy of my fingerprint.
I think I see a circular imprint on the left half of yours.  Nice thermal marks in the centre too.
« Last Edit: July 28, 2015, 11:15:28 pm by Whales »
« Reply #3 on: August 04, 2015, 08:38:47 pm »
Thanks for your reply guys.
I found the pic over the Internet.
Offline alsetalokin4017
« Reply #4 on: August 05, 2015, 03:35:35 am »
I'd call it a "standoff"... and I must be right because when I searched Google for "power resistor standoff" your image is the second one on the image page...
Actually they look like quick-disconnect pins, PCB-mountable, that have been pressed into service as standoffs.
Taking apart old CRT chassis, are we?
Offline Whales
    • Halestrom
« Reply #5 on: August 06, 2015, 01:26:51 am »
This was a close as I could get.  All of the socket-like pins that I found only had a hole at one end, however.
Offline tautech
« Reply #6 on: August 06, 2015, 02:35:36 am »
+1
Maybe even a obscure old day TH PCB test point.  :-//
Ceramic standoff's are a far better solution and have the advantage of conducting much less heat onto the PCB.
IMO metal standoffs were probaly used instead of having to buy ceramics and therefore it's been done on the cheap.  ::)
Offline andtfoot
« Reply #7 on: August 06, 2015, 04:19:59 am »
You could also search for hollow PCB turrets. They are usually riveted to the board, but could be repurposed.
Offline Whales
    • Halestrom
« Reply #8 on: August 08, 2015, 11:01:14 pm »
I would have thought heat conduction into the board was desired.  The resistors are already high-wattage and stood off by a distance, so presumably any extra cooling is useful.  Even if the ceramic standoffs covered most of the legs it would be detrimental.
Offline tautech
« Reply #9 on: August 08, 2015, 11:35:40 pm »
Yes, it can be, and sometimes components are just elevated only enough to clear the PCB and are supported by their own leads with no standoffs. This can be fine for something like a TV where the only physical stresses components will ever see is while in infrequent transport.
Other equipment must be more physically robust and hence standoffs are then often used.
IME standoffs are more often seen in old equipment with Phenolic PCB's that are more susceptable to elevated temperatures.
I have seen quite tall standoffs used with other components below, right on the PCB so standoffs can also be used to help with density/routing paths.
Other than power resistors (some with integral pressed metal standoff leads) it is not so common to see hollow standoffs these days with designers more conscious of better efficiencies in modern appliances/equipment and also the more commonly used FR4 having better heat tolerance.
Offline Vntrev
« Reply #10 on: April 18, 2023, 08:12:55 am »
Hello these component standoffs look very old. Here is a link to the new version. https://www.mouser.com/ProductDetail/Keystone-Electronics/1582-2?qs=sRmtjTgUjYXOlBQXe%252Bt9UQ%3D%3D
Offline mariush
« Reply #11 on: April 18, 2023, 10:03:41 am »
Good job reviving a thread from 2015, I'm sure OP was still waiting for answers  /s
Anyway, that's a terminal, not really ideal for use with resistors.
If anyone actually still looks, another option may be ceramic spacers ... Digikey has some in another category, here's a link or two:
https://www.digikey.com/en/products/detail/essentra-components/CER-1/3811718
https://www.digikey.com/en/products/detail/essentra-components/CER-2/3811719
https://www.digikey.com/en/products/detail/essentra-components/CER-3/3811720
https://www.digikey.com/en/products/detail/essentra-components/CER-4/3811721
and more ...  https://www.digikey.com/en/products/filter/component-insulators-mounts-spacers/585?s=N4IgTCBcDaIMYFMBOBDAtgSziAugXyA
1 and 4 are stocked in big quantities (46k , 98k) as I write this post and they're fairly cheap at 10 cents each at 100+ pcs ordered.
Offline donlisms
« Reply #12 on: April 20, 2023, 12:54:25 am »
Nah...  I'm going with "Post Thingy."
