Author Topic: Controlling speed of EDF motor  (Read 813 times)
Offline TheboelTopic starter
  • Country: id
« on: December 08, 2020, 10:28:43 am »
Hi
I am looking for advice on how to control the speed of EDF motor without using the remote control, I need to control the speed based on pressure. (0,4 bar)
any help will apreciate.
https://www.turbines-rc.com/en/jp-hobby/1062-edf-ducted-fan-jp-hobby-90mm-12s-motor.html this is my target motor.
Thank You
Anton
Offline Berni
  • Country: si
Re: Controlling speed of EDF motor
« Reply #1 on: December 08, 2020, 10:34:09 am »
Hook up a I2C pressure sensor IC to a microcontroller then have the microcontroller generate the PWM servo signal to drive the throttle of the motor controller.
  • Country: id
« Reply #2 on: December 08, 2020, 02:40:27 pm »
Hi Berni,
Thank you for suggestion I start looking for an Arduino project.
Regards,
Anton
Offline Benta
« Reply #3 on: December 08, 2020, 06:25:13 pm »
+1
Buy the recommended BLDC motor controller as shown on the web page, and generate a 1...2 ms PWM pulse with 20 ms repetition rate from your microcontroller.
Getting the PID loop right is probably going to be the most difficult part.
Offline firehopper
« Reply #4 on: December 08, 2020, 11:48:29 pm »
and to clarify things. 1ms is low throttle or off. 2ms pulse is full throttle or fully on. and please keep fingers out of the spinning blades of death while on :)
