Consider using pulse transformers for isolation as multiple TRIACs firing would be disastrous, and if the input side of a pulse transformer is shorted (by its half-bridge driver) its output side will be low impedance, reducing the risk of false triggering. The TRIACs will need a generous voltage rating and probably RC snubbers across them, again to reduce the risk of false triggering.
