Author Topic: Relay contact ratings  (Read 2008 times)
Offline nukie
« on: May 27, 2013, 03:06:21 am »
I just bought an Omron MY2 DPDT relay to fix an equipment. From the window, the contact rating as follow..
5A 240 VAC
5A 28 VDC
I don't understand why is there such a significant difference between AC and DC at the contacts?
When I google, the explanation is that DC current requires higher contact rating than AC but why so?
Is this because of the resistance difference between AC and DC?
Vincent.
Offline Rufus
Re: Relay contact ratings
« Reply #1 on: May 27, 2013, 03:22:06 am »
Because an arc draw between the contacts as they open will extinguish on the next zero crossing of the ac current they are carrying. A dc arc can only be extinguished by the contacts moving far enough apart.
Offline nukie
« Reply #2 on: May 28, 2013, 04:16:40 am »
Great explanation, thanks!
