Author Topic: Emergency Lights Learning Project  (Read 1028 times)
Offline dcbrown73
« on: April 10, 2017, 05:01:38 pm »
Hello all,
I'm getting started in learning electronics and deciding on a project that isn't too deep to start or just too simple (I've already done the LED stuff)  I decided a nice little emergency lighting for my home would be a nice thing to have, but I had a question concerning relays.
My thought was I would plug the device into a 120v socket and use a relay to control it's function.  What I was thinking was the relay would use the house power to lock the relay in the NO state and the absents of the house power would flip (release) to NC which would engage the battery power.
My dumb question is, are relays meant to function with the magnet always engaged under normal use?  Does it not matter or does it stress the relay to the point of failure at some point?
So far I haven't fully designed the circuit, but I suppose it would be the 120v -> transformer to voltage level for relay -> rectifier to convert to DC -> relay?   I suppose I should get some software to design it.  I will look for some.
Thanks,
Why exactly do people feel I should have read their post before I responded?  As if that was necessary for me to get my point across.
Offline Seekonk
Re: Emergency Lights Learning Project
« Reply #1 on: April 10, 2017, 05:41:48 pm »
Relays do heat up as well as consume power.  Most DC relays will pull in at about half voltage.  Once pulled in it only takes about 15% power.  I'd use an opto isolator pulling down a FET gate to switch on lights.
The following users thanked this post: dcbrown73
Offline dcbrown73
« Reply #2 on: April 10, 2017, 05:52:03 pm »
Thank you, I will look up a  opto isolator.
Online james_s
« Reply #3 on: April 10, 2017, 06:26:53 pm »
A relay will work though, so long as the coil voltage supplied is within the rated range it can be left energized continuously. Small relays do not consume very much power, probably a bit more than the LED in an opto coupler but even those consume some power.
Offline edavid
« Reply #4 on: April 10, 2017, 06:43:06 pm »
Yes.  Solenoids often have on time limitations, but not relays.
You can do it that way if you want, but it's much simpler to buy a relay with a 120VAC coil.
I looked at some AC relay datasheets, and they have coil ratings of 0.5-1VA, so not much power at all.
