Author Topic: I2c bit banging, AT89C55WD, EEPROM BL24C04 interfacing  (Read 1506 times)
Offline Vindhyachal.taknikiTopic starter
« on: April 16, 2016, 03:53:03 pm »
1. I am using AT89C55WD(40 pin DIP), with 12Mhz crystal.
Have to interface BL24C04 with it.
2. System is +5V powered & I have made bit banging code in C for it.
I have kept 50kbps speed. Took refereence from here while making code ( http://saeedsolutions.blogspot.in/2012/10/pic16f84a-i2c-bit-banging-code-proteus.html )
3. I have simualted code in proteus & seems to be working as values shown in its I2c debugger.
4. One issue I think may be its very small delay. At 50kbps , 1 bit delay is 20us, half bit delay is 10us & quarter bit delay is 5us. In codeI have used nop statements for 10us & 5us.
5. In link above, blogger has used quarter(5us)/half(10us) but delay at many places. I dont know why quarter(5us) bit delay is used. Below is code. Is it ok?
sbit sda = P1^7;
sbit scl = P1^6;
#define i2c_speed_kbps     50
#define half_bit_delay_us  10     /* ( (1*1000000) / (i2c_speed_kbps*1000) )/ 2  */
#define delay_10us()       _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_();
#define delay_5us()       _nop_(); _nop_(); _nop_(); _nop_(); _nop_();
void all_tasks_manager(void)
    uint8_t temp;
    i2c_init();
/* write to eeprom */
    i2c_start();
    while( 1U == i2c_write_byte(0xa0U) )
        i2c_start();
/* address */
    i2c_write_byte(0x00U);
/* value */
    i2c_write_byte(0x05U);
/* stop */
    i2c_stop();
    wait_delay_us(50000);
    i2c_start();
        i2c_start();
/* address */
    i2c_restart();
    i2c_write_byte(0xa1U);
    temp = i2c_read_byte();
    i2c_send_nack();
    i2c_stop();
    while(1);
} /* function ends here */
void i2c_init(void)
    sda = 1U;
    scl = 1U;
void i2c_start(void)
    scl = 1U;
    sda = 1U;
/* half bit delay for 50kbps which is 10us for 12Mhz it is 10 nops */
    delay_10us();
    sda = 0U;
    delay_10us();
void i2c_restart(void)
scl = 0U;
/* half bit delay/2 for 50kbps which is 5us for 12Mhz it is 5 nops */
    delay_5us();
    sda = 1U;
    delay_5us();
    scl = 1U;
    delay_5us();
    sda = 0U;
    delay_5us();
void i2c_stop(void)
    scl = 0U;
    delay_5us();
    sda = 0U;
    delay_5us();
    scl = 1U;
    delay_5us();
    sda = 1U;
    delay_5us();
void i2c_send_ack(void)
    scl = 0U;
    delay_5us();
    sda = 0U;
    delay_5us();
    scl = 1U;
    delay_10us();
void i2c_send_nack(void)
    scl = 0U;
    delay_5us();
    sda = 1U;
    delay_5us();
    scl = 1U;
    delay_10us();
uint8_t i2c_write_byte(uint8_t byte)
    uint8_t cnt;
for(cnt = 0U ; cnt < 8U ; cnt++)
        scl = 0U;
        delay_5us();
if( (byte << cnt) & 0x80U )
            sda = 1U;
        else
            sda = 0U;
        delay_5us();
        scl = 1U;
        delay_10us();
/* get ack from slave */
    scl = 0U;
    sda = 1U;
    delay_10us();
    scl = 1U;
    delay_10us();
return sda;
uint8_t i2c_read_byte(void)
    uint8_t cnt;
    uint8_t rxdata = 0U;
    uint8_t temp;
        scl = 0U;
        sda = 1U;
        delay_10us();
        scl = 1U;
        delay_5us();
        temp = sda;
rxdata = rxdata | (temp << (7U - cnt));
        delay_5us();
    return rxdata;
Re: I2c bit banging, AT89C55WD, EEPROM BL24C04 interfacing
« Reply #1 on: April 18, 2016, 06:24:17 am »
I have checked on hardware, MCU: AT89C55WD, 12Mhz crsytal & BL24C04.
It is working.
For me exact performance of 50kbps is not required, because I have to read it only once on startup & write only once.
« Reply #2 on: April 22, 2016, 08:23:33 am »
How byte addressing is done in 24C04 eeprom.
24C04 has 4K of eeprom, so byte address range  0 to 4095 i.e 0 to 0x0FFFH. So byte address require two  bytes.
But here in Maxim app note, it only sends one byte to address the byte ( https://www.maximintegrated.com/en/app-notes/index.mvp/id/4649 ).
Foe example, if I have to write at address location 0x00, I should send two 0's.
Similarly for 4095 adress, I should send 0xff & 0xff.
But here codes works by sending one bytes only.
1. I have tested the code by sending one byte adress, & it is workign on hardware. I haven't tested by sending two byte address.
2. This is below codes for writing multiple bytes & reading back. Any comments/suggestions on it.
Performance wise I dont require to be exact 50kbps. Since I have to read/write only once at startup.
/* AT89C55WD, 12Mhz crystal, 1us inst time */
sbit sda = P1^7;
sbit scl = P1^6;
#include "regx55.h"
#include "i2c.h"
static uint8_t eeprom_write_mutiple_bytes(uint8_t address , uint8_t byte[] , uint8_t no_bytes)
    uint8_t cnt;
    uint8_t cnt2;
    uint8_t err = 0U;
    cnt = 10U;
    i2c_start();
    while( (1U == i2c_write_byte(0xa0U)) && (--cnt) )
    /* stop */
        i2c_stop();
    /* delay 100ms */
        for(cnt2 = 0U ; cnt2 < 20U ; cnt2++)
            wait_delay_us_complete(DELAY_10000_US_TH , DELAY_10000_US_TL);
        i2c_start();
    if(0U == cnt)
        err = 1U;
/* if no error */
    if(0U == err)
    /* address */
        i2c_write_byte(address);
        for(cnt = 0U ; cnt < no_bytes ; cnt++)
            (void)i2c_write_byte(byte[cnt]);
    /* stop */
        i2c_stop();
/* delay 100ms */
    for(cnt = 0U ; cnt < 15U ; cnt++)
    return err;
static uint8_t eeprom_read_mutiple_bytes(uint8_t address , uint8_t byte[] , uint8_t no_bytes)
    uint8_t cnt;
    uint8_t cnt2;
    uint8_t err = 0U;
    cnt = 10U;
    i2c_start();
    /* stop */
        i2c_stop();
    /* delay 100ms */
        i2c_start();
    if(0U == cnt)
        err = 1U;
/* if no error */
    if(0U == err)
    /* address */
    /* restart */
        i2c_restart();
    /* address */
        byte[0] = i2c_read_byte();
        for(cnt = 1U ; cnt < no_bytes ; cnt++)
            i2c_send_ack();
            byte[cnt] = i2c_read_byte();
    /* nack */
        i2c_send_nack();
    /* stop */
        i2c_stop();
/* delay 100ms */
    return err;
static void i2c_start(void)
    scl = 1U;
    sda = 1U;
    delay_10us();
    sda = 0U;
    delay_10us();
static void i2c_restart(void)
scl = 0U;
    delay_5us();
    sda = 1U;
    delay_5us();
    scl = 1U;
    delay_5us();
    sda = 0U;
    delay_5us();
static void i2c_stop(void)
    scl = 0U;
    delay_5us();
    sda = 0U;
    delay_5us();
    scl = 1U;
    delay_5us();
    sda = 1U;
    delay_5us();
static void i2c_send_ack(void)
    scl = 0U;
    delay_5us();
    sda = 0U;
    delay_5us();
    scl = 1U;
    delay_10us();
static void i2c_send_nack(void)
    scl = 0U;
    delay_5us();
    sda = 1U;
    delay_5us();
    scl = 1U;
    delay_10us();
static uint8_t i2c_write_byte(uint8_t byte)
    uint8_t cnt;
        scl = 0U;
        delay_5us();
            sda = 1U;
        else
            sda = 0U;
        delay_5us();
        scl = 1U;
        delay_10us();
    scl = 0U;
    sda = 1U;
    delay_10us();
    scl = 1U;
    delay_10us();
return sda;
static uint8_t i2c_read_byte(void)
    uint8_t cnt;
    uint8_t temp;
        scl = 0U;
        sda = 1U;
        delay_10us();
        scl = 1U;
        delay_5us();
        temp = sda;
        delay_5us();
    return rxdata;
« Reply #3 on: April 22, 2016, 04:35:37 pm »
yes got it. It has 2 pages of 256 bytes each. pages are selected in device address register bit.
