Author Topic: Electrolytic capacitor ESR confusion  (Read 914 times)
Offline valley001Topic starter
« on: March 18, 2019, 12:56:52 am »
I am in the process of recapping a Fluke 332D.  Once cap has failed on it so far and I would rather not chase bad caps over the next 10 years so I have decided to simply replace as many of the electrolytic as I can (reasonable?)
Three of the caps are 450v 8uf +50/-10%.  I found KEMET PEG124YF2100QL1 450v 10uf however the quoted ESR is 5.7 ohms.  Is this a normal ESR figure for this type of capacitor?  My noob impression is that ESR should be less than an ohm.  I just want to be sure I install a cap that will work properly.  Thanks in advance for the education.
Offline helius
Re: Electrolytic capacitor ESR confusion
« Reply #1 on: March 18, 2019, 01:12:48 am »
High voltage, low capacitance devices have high ESR as a result of their physical construction. That is perfectly normal.
I would probably not replace all capacitors at once because there is a risk of damage with any kind of rework.
« Last Edit: March 18, 2019, 01:14:25 am by helius »
The following users thanked this post: valley001
« Reply #2 on: March 18, 2019, 01:19:06 am »
Is this risk lower than a cap going sideways?  I worry about a sideways cap taking out other more unobtainable parts.
Offline Jay_Diddy_B
« Reply #3 on: March 18, 2019, 01:19:46 am »
Less than 1 \$\Omega\$ is a simplification.
A lot of commonly encountered values will be less than 1 \$\Omega\$, but if you look at the Kemet datasheet:
https://www.mouser.ca/datasheet/2/212/KEM_A4011_PEG124-1104316.pdf
You will see that some low capacitance and higher voltage electrolytic capacitors are more than 1 \$\Omega\$ ESR.
The Kemet part you have chosen is probably better than the part that was used originally.
Do you have a method foe measuring ESR?
Regards,
Jay_Diddy_B
« Reply #4 on: March 18, 2019, 01:29:47 am »
Thanks everyone for chiming in.  I use one of those cheap component testers for measuring ESR.
