One question remains.
Xc of the Emitter bypas cap in the non splitted emitter resistance circuit was chosen to be 1/10 RE.
What should it be in the split emitter circuit? 1/10 Re1?
Or do i have to consider the resistance of Re2 also?
In the series resistance circuit if you have 26 Ohms on top and 10 Ohms on the bottom then if you short the cap you then have only 26 Ohms (again frequency not too low). That means that if you use the parallel circuit with the two resistors separate, you have one 36 Ohm resistor (Re1) and one unknown resistor Re2.
Since in the series arrangement you had 26 Ohms with the cap shorted, that would mean that the total resistance with the cap shorted in the parallel arrangement would also have to be 26 Ohms. So to calculate the unknown Re2 now you would use:
26=Re1*Re2/(Re1+Re2)
You can solve this for Re2 and get:
Re2=(26*Re1)/(Re1-26)
and since Re1 was 36 Ohms that means Re2 would be 93.6 Ohms.
The more general formula is:
Re2=(Rcs*Re1)/(Re1-Rcs)
where Rcs is the upper resistor value (26 Ohms in your case).
Checking, 93.6 in parallel with 36 we get:
Rcs=36*93.6/(36+93.6)
and so Rcs does come out to 26 ohms again which is what the original series combination had when the cap was shorted.
We probably want to keep the reactance of the cap at the lowest operating frequency to be 5 percent or less than the new resistor value of Re2. If Re2 is 93.6 Ohms then that means we want it to be 4.68 Ohms or less. Since the reactance of the cap is:
RC=1/(2*pi*f*C)
we can form the equation:
4.68=1/(2*pi*f*C)
and since C is 2200uf that means we can solve that for f to see what low frequency this would happen at. Solving that for f we get:
f=15.5 Hz
so this should work down to around 15 Hertz or thereabouts.
You can test it in spice.
