I am making a lamp with leds. The lamp will have an MCU to do useless animation. In normal conditon, the lamp will draw 1 to 2 amps. Of course when I plug it to a computer for firmware update (or for any other reason), I want to be sure to only draw 500mA after I have politely asked permission to do so.
I've spent hours reading the USB and USB-IF documentation, and learned many things, but still don't want to spend more time prototyping and debugging the code myself (that would take as much time as the rest of the project !).
So my question is : What is the simplest IC I can buy that will tell me how much current I can use (and would possibly be able to deal with non standard Apple chargers) ?
For now, microchip's USB3751 seems rather ok (0.5mm pitch, no bga, easy to source since I will order things from microchip, only require 1 external capacitor). The thing is that it does not know about apple chargers, and don't tell you exactly how much current you can draw (e.g. it will tell you "Dedicated charging port", but this could be from 500mA to 2.5A available).
What is you current solution to this problem ?
Thanks you,
John.
