1. I am using N76E003, keil v9.51 . Controller is running at 16Mhz, I can measure this on Clockout pin by DSO.
2. Internal clock diagram shows, Clockout frequency & peripheral frequency is same.
3. Timers works correctly accroding to 16Mhz clock.
4. Issue I faced is when I write:
P04 = 0; or P04 = 1;
it takes around 250ns as measured on DSo with 10x probe for single instruction.
5. Disassembly on keil shows:
C:0x07FE C284 CLR P04(0x80.4)
C:0x0800 D284 SETB P04(0x80.4)
6. These are single cycle instruction. What I dont understand is when cpu is running at 16Mhz, single cycle time should be 1/16Mhz i.e 62.5ns, but on DSO it takes 250ns around
7. Then why pin high low takes large time
