Hi I have found a galvanic isolated probe that look like it's a great start but maybe a bit noisy, max 70MHz and bw of 35MHz.
I was thinking if it would be possible to reduce noise, get higher max MHz and maybe a wider bandwidth, by replacing some of the "old" chips.
The author wrote about the possibility to improve the design, but to me do it look like the project is abandoned.
Full article with original schematic here:
https://hackaday.io/project/12231-fiber-optic-isolated-voltage-probe#menu-descriptionHere are some of the most important exemption from the authors notes:
Ideally, the probe will have 50-80MHz bandwidth, without horrible distortion and with less noise that an oscilloscope.
Goal, an isolated oscilloscope probe with 10x attenuation, +-50 volt input voltage range, less than 2mVrms noise, and more than 30MHz bandwidth.
The core of the probe are the IF-E91D and IF-D91 plastic optical fiber transmitter max 70Mhz.
Managed to get 9-10nS rise and fall times. Works out to an approximate bandwidth of 35MHz. Roll-off past 35MHz is first order as best I can tell with a noise source and scope FFT. Might be able to compensate with the post-amplifier and get more bandwidth.
Had to remove trimmer C5 due to the unbalanced capacitive dividers.
First problem is that the OPA 847 is oscillating a bit near 100MHz. The output is also rather noisy. So since the OPA847 has more bandwidth than required due to the 35MHz front end, Boosting it to 15K was enough to quiet the oscillation, but I went all the way to 39K to help with noise. Also dropped the LT1819 gain because of the increased sensitivity of the OPA847 stage... (from 10k)
Noise is now about 15mVrms at the output or 150mVrms at the input.... The noise level is a lot higher than I'd like and limits the useful signal amplitude range of the probe.
I did attempt to extend the bandwidth of the probe by adding a 22pf capacitor in parallel with R31. While this did extend the bandwidth, it also resulted in a blunt peek at 60-70MHz. Didn't keep the capacitor because the distortion was just too obvious.
I get 636uVrms of noise. (3900MHz gain bandwidth, 0.85nV/Hz voltage noise, 2.5pa/Hz current noise, 30Kohm Rf, Cf around 0.2pf, Cin around 7pf) That's consistent with my 7-10mV peak to peak noise I'm seeing after the 3-6x gain from the LT1819.
A noise-free op-amp would drop my noise floor about 5x. Looks like it's worth spending time to develop a better amplifier
Found a few links online I want to keep track of. First is paired plastic optical fiber. This would allow a V2 probe to use differential optical signalling to eliminate offset drift and allow gain compensation. POF pair
http://www.afwoptics.com.au/index.php?route=product/product&path=119&product_id=495END OF NOTES
I have tried to find some alternative to some of the chips but have a hard time to select one that is more usable:
https://www.analog.com/en/parametricsearch/11091#/
