If it's a positive displacement pump, the mechanical load on the motor, and therefore the slip, will increase as the filter clogs, due to the increase in backpressure.
If it's a centrifugal pump, the load (and slip) will decrease as the increased backpressure results in a reduction in flow. (I think...)
