Author Topic: entrance alert  (Read 6578 times)
Offline Brumby
Re: entrance alert
« Reply #25 on: October 13, 2016, 12:27:22 pm »
Pedestrian traffic is still traffic ...   ;D
But yes, as unlikely as it might be, people could have parked down the road and wandered up to the property.
I suppose the best thing we can do is keep throwing ideas around and the OP can see what might work for him.
Offline blueskull
  • Country: cn
  • Power Electronics Guy
Re: entrance alert
« Reply #26 on: October 13, 2016, 12:42:19 pm »
This is not only a sensor, but also an actuator :D.
Offline digsys
    • DIGSYS
Re: entrance alert
« Reply #27 on: October 13, 2016, 01:29:03 pm »
As can be seen the number of incident variations posted, and enviromental considerations (snow etc), this is unlikely to ever be 100% solved / accurate.
It's looking like my suggestion of - grandpa with a shotgun - is probably the most relaible.
Offline Brumby
Re: entrance alert
« Reply #28 on: October 13, 2016, 02:25:34 pm »
LOL
A little less discriminating than grandpa with a shotgun - but lower maintenance cost.
Offline NottheDan
Re: entrance alert
« Reply #29 on: October 13, 2016, 03:07:09 pm »
My employer uses a software-based tracking system that seems to work well for them, something like this. (not affiliated, just the first example I found)
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Re: entrance alert
« Reply #30 on: October 13, 2016, 04:33:10 pm »
Best solution. Even works when the power goes down. Although you might want another brand.
Offline darinsquared
Re: entrance alert
« Reply #31 on: October 13, 2016, 10:19:30 pm »
Two star pickets, some decent fishing line and a cow bell, that's all I have to offer up today.   :(
I was contemplating something like this but a little more technical.  Using a fishing line connected to a switch that would sound an alarm if the line is "disconnected".  If would need to be physically reset everyday.
For one entrance I am now considering a gate.  When the gate is closed it will line up with a proximity switch shutting off an alarm.  I need to figure out a way to open the gate remotely for guests and open it from a vehicle with RFID (or similar method).  Both will have to disable alarm.  All other entrances are too wide for this method.
I prefer an invisisble barrier.  I am playing with using a straight sound sensor on both perimeters.  If my intruders drive electric cars I might be hooped.  :-DD
Offline C
Re: entrance alert
« Reply #32 on: October 13, 2016, 11:48:30 pm »
According to Vishay you can do 30m for a beam break IR sensor.
No idea how wide your other entrance(s) are, but sliding gates do close very large widths. Gate slides behind current fence as it opens.
Some the gate does not touch the ground. Some have support wheels on gate. Some hang from overhead beam.  Can use cable to pull open or closed.
