I'm trying (with no luck) to read contents of eprom from Keithley multimeter (Edit: Meter is Keithley model 175). Ic is M5L2764K by Mitsubishi (8K x 8 ), and its datasheet states that its interchangeable with Intel 2764 (which I checked and seems to be 100% true). Using TL866 series programmer, I set it in software to Intel chip, cause there's no mitsubishi chip of that kind in library, hit read and nothing. FF from top to bottom. I tried other 2764 chips from library, but all of them behave exactly the same. I thought that maybe IC is bad, but meter works fine. Programmer should be ok too, since there was no problems with reading contents of second eprom (from GPIB board). Google doesn't want to help in any way and I ran out of ideas what might be problem here, so any help would be appreciated.
