Author Topic: Reading RPM of motorcycle's engine  (Read 3983 times)
Offline huu_tri0101Topic starter
  • Country: vn
« on: July 29, 2013, 05:05:33 pm »
I want to measure rpm of motorcycle's engine. The engine is 4 stroke, one cylinder. So in one cycle, the crankshaft rolls 2 revolutions, the spark plug sparks 1 time. So I need to count time the spark plug sparks in one second to measure rpm.
To count time the spark plug sparks, I use the hall sensor place near motorcycle spark plug wire, then use an op-am to compare the Voltage that hall sensor gives back with the V ref. Then read the result form the op-am by the MCU.
Is that a good idea? Any suggest ?
Thank you guys. Sorry for my English.
Offline Kremmen
Re: Reading RPM of motorcycle's engine
« Reply #1 on: July 29, 2013, 05:42:49 pm »
A hall sensor is sensitive to a magnetic field so not the best possible one to sense the electric field around the HV spark cable. A better solution would be to make a pickup coil from a few turns of wire around the spark cable.
Google will tell you more. Some infor e.g. here: http://www.eng-tips.com/viewthread.cfm?qid=320604
Nothing sings like a kilovolt.
Dr W. Bishop
Offline KJDS
    • my website holding page
« Reply #2 on: July 29, 2013, 06:44:15 pm »
Pick up coil feeding a schmidt trigger is the way to go.
Offline A Hellene
  • Country: gr
« Reply #3 on: July 29, 2013, 07:15:17 pm »
If you do not know EXACTLY what you are doing, DO NOT touch the pick-up coil. There are better ways of reading the engine speed.
Additionally, almost all of the single-cylinder motorcycle engines ignition controllers utilise the so-called "wasted spark" ignition system, since they are sensing the crankshaft rotational position and speed (where there is one spark for every crankshaft cycle); except, of course, if they have their sensors on the camshaft.
The answer you might be looking for is at the first link, above, by reading the charging system output frequency.
-George
Hi! This is George; and I am three and a half years old!
(This was one of my latest realisations, now in my early fifties!...)
Offline AndyC_772
« Reply #4 on: July 29, 2013, 08:07:09 pm »
If your bike has electronic ignition, then there may already be a perfectly good signal you can tap into at the back of the clocks, feeding the rev counter. My bike has a nice, clean 12V square wave available which I've used successfully, and there's a similar signal for the speedometer on a nearby pin.
If you place a pick-up coil near to one of the ignition leads, then you should be able to pick up a strong signal quite easily - but it's worth checking it with a scope to see what it looks like before designing any kind of interface. Expect the ignition pulses to be surprisingly high in amplitude and very brief in duration.
