Author Topic: ESD mat cable clip connects top and bottom layer  (Read 777 times)
Offline Haggis McHaggisTopic starter
« on: June 19, 2019, 09:02:56 pm »
i wonder why the mount of my ESD mat cable connects the top and bottom layer of the mat. The clip is made of metal.
In this video you can see the cable i have got and how it is mounted:
I thought the grounding cable should be connected to the bottom layer only. The mat itself has some conduction between the top and bottom layer.
What do you think?
Online Gyro
Re: ESD mat cable clip connects top and bottom layer
« Reply #1 on: June 19, 2019, 09:06:45 pm »
The bottom layer is the resistive one (ie. the one that spreads ground potential over the whole area of the mat). The top layer is static dissipative (resistance too high to measure by normal methods). Having the eyelet riveted through both is just a matter of practicality, it makes no difference that it contacts the top layer too.
Best Regards, Chris
The following users thanked this post: Haggis McHaggis
« Reply #2 on: June 19, 2019, 10:13:01 pm »
Thank you. So i can use this cable and be done with it.
