Not to dive down too far, but at my old job we had static strap testers, static coats, dehumidifiers, humidity meters/loggers, and those fans blowing across benches.
The idea was the fans blew across the bench rather than try dissipating throughout the entire room. Humidity was to be kept above a certain percentage (don't remember the number now), the static coats dissipated ESD off your body, and the strap testers to confirm the wrist straps were conducting.
Over the years meters were used to measure the charge on benches and the fans did seem to work. It comes down to good practices too. if you're working on a bench that has lots of ESD build up, the fan isn't going to solve the issue, so it's a combination of the above that contributed to the overall decrease in ESD risk.
