Hallo Community,
it seems a simple programming question keeps me busy for a couple of days...... may someone can bring a torch to the dark. The Situation is on selection 2 (read the field)... I want to get the result shown in the field Char* Ergebnis. as result in selection 2 the field nvs_ret_data is a pointer
Hope for a solution
All the best Franzel61
* NVS handling
Char* nvs(int nvs_select,char* nvs_key, char* nvs_data)
char* nvs_result="abababababababa";
char* nvs_ret_data="bababababababababab";
printf("Selection %i\n",nvs_select);
* write to NVS String --Select 1
if (nvs_select==1)
esp_err_t err = nvs_flash_init();
if (err != ESP_OK) printf("NO NVS Initialization\n");
const esp_partition_t* nvs_partition = esp_partition_find_first(ESP_PARTITION_TYPE_DATA, ESP_PARTITION_SUBTYPE_DATA_NVS, NULL);
if(!nvs_partition) printf("FATAL ERROR: No NVS partition found\n");
nvs_handle my_nvshandle;
err = nvs_open(nvs_partition, NVS_READWRITE, &my_nvshandle);
if (err != ESP_OK) printf("FATAL ERROR: Unable to open NVS\n");
printf("wOS: Saving collected data into NVS...\n");
printf("%s\n", nvs_data ); //Prints the correct value
err = nvs_set_str(my_nvshandle, nvs_key, nvs_data );
printf((err != ESP_OK) ? "wOS: Failed to save Collected Data\n" : "wOS: Successfully saved Collected Data!\n");
esp_err_t nvs_commit(nvs_handle my_nvshandle);
* read from NVS String --Select 2
if (nvs_select== 2)
size_t nvs_required_size;
err = nvs_get_str(my_nvshandle, nvs_key, NULL, &nvs_required_size );
switch (err) {
case ESP_OK:
printf("wOS: Successfully grabbed size %i, loading in value..\n",nvs_required_size);
size_t nvs_ret_data = malloc(nvs_required_size);
err = nvs_get_str(my_nvshandle, nvs_key, &nvs_ret_data, &nvs_required_size );
printf( "Downloaded Data>: %s\n", nvs_ret_data ); // ****** the correct value will be shown
return(nvs_ret_data);
printf("result> %s < \n",nvs_ret_data);
******************* and of NVS
void app_main()
* Initialization
nvswait(10);
//write string
nvs(1,"key4","merlin");
nvswait(5);
//read string
Ergebnis= nvs(2,"key3",NULL);
printf("result 1st %s\n",Ergebnis);
Ergebnis=nvs(2,"key4",NULL);
printf("result 2nd - %s\n",Ergebnis);
