Hello, I'm trying to get 2x ESP32's to communicate over SPI Master Slave.. I wanted to verify the master is sending out data and I was surprised to see the clock and data at such low voltage levels. I only see ~336mV. I can only assume this is normal? Looking for confirmation?
Also if anyone has experience with siglent decode... I tried to get SPI decode to work but I'm not having any success. Siglent support was suggesting I was having trigger issues but it's very stable. BTW: Support is very slow and sometimes non-responsive.
I set the bit (8 bits), protocol, signal MOSI etc... no joy.
Thank you
