Author Topic: ESP8266 Custom Board  (Read 1774 times)
Offline fossilTopic starter
  • Country: in
« on: January 19, 2019, 02:14:53 am »
I have been watching this wonderful forum for many years. I could say, this forum has given me courage to consider the following project.
I am looking forward to build a standalone custom ESP8266 board based on ESP-WROOM. This exercise is purely for academic purpose. I want to learn how to use a wireless chip instead of module. If you are wondering why ESP8266, I have been given few dozen ESP8266EX, purchased as samples from Espressif, by a friend of mine.
The spec I am considering
  • 8MB Flash
  • DC/DC Converter 3-14V Input 5V/1A Running at 2250MHz
  • 3.3V LDO powering the ESP8266EX
  • External antenna
I want this board to work with any power source as long as voltage is less than 14V. I am aware of challenges of designing DC/DC converter. I intend to use the PCB design from TI WEBENCH. Further, I have read the ESP8266 hardware design guidelines document. The board will be 4 layers as suggested in hardware guidelines.
I have soldering station, hot-air, 50MHz oscilloscope. I am looking forward to build a toaster reflow oven soon.
I am wondering what problems are in store for me?
Offline JoeO
  • I admit to being deplorable
Re: ESP8266 Custom Board
« Reply #1 on: January 19, 2019, 03:52:34 am »
Go to youtube and search "reflow toaster oven".
There are many videos there that can give you the information that you want.
The day Al Gore was born there were 7,000 polar bears on Earth.
Today, only 26,000 remain.
  • Country: in
« Reply #2 on: January 19, 2019, 09:51:46 am »
I do have a controller board for toaster oven. I am planning to build next weekend.
I am looking for advice on building standalone esp8266 board.
Offline 128ITSH
  • Country: il
« Reply #3 on: January 20, 2019, 04:38:58 pm »
With what part of the board are you struggling? What you want to do is very achievable. Like you said the main challenge I see here is designing the power supply circuitry as efficient as possible. The 8MB flash probably has simple connections to the chip. A thing worth to consider is protecting the Wi-Fi Antenna traces from the switching noise of the power supply. Could be done by putting each on a different side of the board and even using metals to enclose the switching supply. Not so sure about this so look for it online.
A good engineer knows how to use his tools.
A better engineer also knows how his tools work.
The perfect engineer is the one who made his tools.
The following users thanked this post: fossil
  • Country: in
« Reply #4 on: January 21, 2019, 02:27:51 am »
I can't say I am struggling. As of now, I am almost done with schematic. I am trying to find out if there any other things to watch out for.
I am considering to shield the power supply.  Probably, I will also try to shield the wireless chip and analog section as seen in other modules
Offline LukeW
« Reply #5 on: January 25, 2019, 03:01:40 am »
Remember your Vdd needs to be 3.3v not 5V.
Make sure the power supply is clean and stable, can supply appropriate current, and use good decoupling.
Follow the reference designs - hard to go wrong.
You need to pay attention to what flash chip you use - DIO, QIO, double check the pinout and flash speed and page size etc - write to the flash accordingly. Settings that don’t match will cause programming failure.
And then there’s the antenna. Make it a 50 ohm CPWG line with usual impedance design practices.
Put a pi network (0402 footprints) before the antenna to allow matching, and a “T junction” to a uFL connector or similar, with a 0 ohm resistor. This allows you to connect up a VNA and measure s11, and tune up the antenna and matching network for best results.
A lot of cheap modules just seem to use 5.6pF for the series capacitor and NP the two shunt inductors which seems to work ok for typical meandered little 2.4GHz antennas.
  • Country: in
« Reply #6 on: January 25, 2019, 03:39:54 am »
The plan is to use an LDO to power ESP8266.
I will pay attention. The WROOM-02 reference design uses "WP" and "HOLD" to interface with flash. I suppose I need to make sure I select the flash which has "WP" and "Hold" pins.
I will follow above guidelines. I don't want to compromise on performance without going overboard.
Thank you very much for all the help.
