Author Topic: ESR Values for Electrolytic Caps  (Read 184858 times)
Offline dark_hawkTopic starter
« on: July 25, 2013, 07:13:42 pm »
I'm looking to establish a table for acceptable ESR values for Caps, I know that for each specific cap you can look at the data sheet and get the ESR and the tan d (D) to know if your cap is with spec, but when diagnosing caps in a malfunctioning circuit with a lot of caps you will need a ballpark numbers for ESR because desoldering all those caps would be a problem.
Frequent Contributor "Wytnucls" provided a table for the ballpark dissipation factor (D) for various Manufacturers and series.
Problem with ESR values is that it differs from different sources.
Here are some examples:
Taking the 10uF 25V for example, the vaules are 5.3, 14, 1.5.
Which of these tables' values seem closer to the "correct" vaules?
Thanks.
The following users thanked this post: Sehsuan
Offline free_electron
    • SiliconValleyGarage
Re: ESR Values for Electrolytic Caps
« Reply #1 on: July 25, 2013, 07:23:51 pm »
that's like making a table giving the weight of a cow .. depends on the subspecies, race ,where it grew up , what it ate , when it ate , if it farted yet ...
The following users thanked this post: BobBeBob
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #2 on: July 25, 2013, 07:32:43 pm »
You forgot lactating or not  :)
« Reply #3 on: July 25, 2013, 07:39:04 pm »
if capacitors lactate they are bad.  :-DD
The following users thanked this post: Djinn, Qw3rtzuiop, Mortymore, Baron Gray, fjalvingh, Jeff eelcr
Offline PA4TIM
« Reply #4 on: July 26, 2013, 12:04:00 am »
I only look at D and capacitance and measure (except for measuring fun and experiments)  NEVER in circuit (at 1 kHz) I'm now repairing  a Tek 2710 spectrum analyser and have replaced all caps. Just for fun I tested all caps in situ for C, D at 1 kHz and ESR at 100kHz. Then I removed the cap, measured it again using GR and IET LCR gear.
95% of the in situ measurements were so way of that I now am even more sure that methode sucks. It is nice if you have no clue about what you are dioing and a chinp can repair some consumer stuff this way.
Most caps turned out to be much better as in situ. But one bizar example: All tantaliums tested good in situ except one. That one turned out to be the only good one !  five 1 uF tantaliums measured a lot better ESR in circuit because there are a lot of caps parallel. One showed excelent ESR but the scope showed a problem.. After desoldering it turned out to have a D of 1.5 and 4 others were leaking current (but the scope shows it all)
Online mariush
« Reply #5 on: July 26, 2013, 03:01:49 am »
All those charts are based on old series of capacitors ... some that were called Low ESR back then are almost classified in the general purpose category nowadays, there's new series or capacitors with much lower esr values than what was considered back then low and very low esr.
They're not meant to be accurate or definitive and you can't generalize something...
For example you may have a 330uF 16v  nichicon hn capacitor with 0.021 ohm impedance and you may have a 130c rubycon rx30 330uF 16v capacitor with 0.22 ohm impedance.
If you ask, you'll definitely find someone to tell you that both are low esr, but hardly interchangeable.
I know it's technically not 100% correct but in practice it's close enough ... I usually just look in the datasheet for that particular series of capacitors at the Impedance column, measured at 100Khz and compare the ESR i get with a 30-50$ esr meter (a meter using the same principles as bob parker's esr meter).
If the impedance for a 3300uF 16v is listed as 0.015 ohm and I read 0.3 ohm, it's kind of obvious it's a 'sick' capacitor.
Offline kanurys
« Reply #6 on: September 26, 2017, 08:20:11 pm »
Also, If there are multiple of the same type of capacitor, comparing their values is a useful tool. I guess it doesn't really tell you which ones are good or bad, though.
Offline danadak
« Reply #7 on: September 26, 2017, 10:19:30 pm »
Compounding this is T as well as process changes over time.
Not a trivial problem you are trying to master. You cannot rely on datasheets
because over time manufacturer may rev the part with no notice (although
components EE in company can raise hell over this and disqual a vendor).
Best you can do at design time is to qual parts and their datasheet revision
at any give point in time, and pray.
Regards, Dana.,
Offline tigr
  • Country: ua
« Reply #8 on: September 26, 2017, 11:05:26 pm »
For all the ESR tables, a very good capacitor.
Offline innkeeper
« Reply #9 on: September 27, 2017, 12:37:58 am »
now wait, i think the idea has merit...
Others have pointed out the pitfalls, i wont repeat them
how could this be done...
maybe you can generalize cap types and series and then give like an average esr for them.
this will also let you cover various cap types in multiple tables.
sure its many tables, but, it would let someone look it up quick and see if there in the ballpark.
in example, a table that broadly covers all 'typical' low esr electrolytics. (i know i am gonna get flamed just for saying there a typical low ESR electrolytic)
it would be a general table, if someone needs to be sure or exact, then they can go to the data sheet for the cap.
so sure, there no substitute for looking up the exact cap and knowing what the esr should be.
but as a quick reference, for those who are more the weekend engineer types could be a handy reference.
Plus, i don't think there is a modern version of this kind of table exists in one place..
Hobbyist and a retired engineer and possibly a test equipment addict, though, searching for the equipment to test for that.
Offline ruairi
« Reply #10 on: September 27, 2017, 02:01:56 am »
Can we not do the endless pics thing on this thread?  The formatting alone makes me queasy.
Offline innkeeper
« Reply #11 on: September 27, 2017, 03:53:19 am »
guess he had a bad reactance to pictures  :-DD
The following users thanked this post: Ellis_Beatty
Offline tigr
  • Country: ua
« Reply #12 on: September 27, 2017, 07:56:21 pm »
Rubycon MBZ 3300uF/6,3v max.ESR-0,012Ohm
« Last Edit: September 27, 2017, 08:31:15 pm by tigr »
Offline tigr
  • Country: ua
« Reply #13 on: September 27, 2017, 09:46:12 pm »
Maybe this one?
Offline tigr
  • Country: ua
« Reply #14 on: September 28, 2017, 07:56:16 pm »
Another ESR table. After a small adjustment, it can be used for "high-voltage" capacitors.
Only the ESR table needs to be expanded, starting at 0.1uF.
For example.New capacitor 0,47uF/400v.ESR-30Ohm.
« Last Edit: September 28, 2017, 09:46:13 pm by tigr »
Offline tigr
  • Country: ua
« Reply #15 on: September 28, 2017, 11:54:21 pm »
Seriously, the deterioration in the characteristics of electrolytic capacitors and the processes occurring in them, are still poorly understood.
With the in-circuit measurement, looking at the ESR, it can be mistaken for a good capacitor.
Bad capacitor.
680uF/50v.
« Last Edit: September 29, 2017, 12:25:14 am by tigr »
Offline perieanuo
« Reply #16 on: October 01, 2017, 04:19:56 pm »
Regards, Dana.,
Marked as best solution :)
Regards,Pierre
Envoyé de mon iPad en utilisant Tapatalk
Offline tigr
  • Country: ua
« Reply #17 on: October 01, 2017, 09:17:31 pm »
In-Circuit ESR meter.
Offline tigr
  • Country: ua
« Reply #18 on: December 30, 2017, 09:12:15 am »
Fill in the table of ESR.
1uF/16v.
ESR-2Ohm.
« Last Edit: December 30, 2017, 12:18:29 pm by tigr »
Offline PA4TIM
« Reply #19 on: December 30, 2017, 09:41:24 am »
Theoretically, ignoring dielectric absorption loss, ESR=D*X, there X=1/(1*pi*f*C).
X=1/(2*pi*f*C)
And D is given most times for 120Hz, impedance is given for 100 kHz. ESR is most times not stated. 100kHz kinda works for ESR because Xc is almost zero there. But skineffect and dielectric loss can disturb ESR measurement at 100 kHz. ESR is not flat over frequency.
Use s scope, if the ripple is to high, the cap is probably not good.  For the rest, desolder, look up the data sheet. The biggest no-no is measuring caps in situ. I have done many tests on that and it is useless. A measurement that gives a high ESR in situ will be usable. But a complete dead cap can show up bad when measured in situ. And that makes in situ measurements useless
Offline oldway
« Reply #20 on: December 30, 2017, 10:33:27 am »
I find that this kind of topic in the beginner section is not very profitable.
This encourages beginners to develop a real phobia of electrolytic capacitors ....  :--
The attitude towards electrolytic capacitors must be moderate and mitigated.  :box:
Systematically replacing ALL electrolytic capacitors is, in many cases, utterly stupid.  :--
We often bring more problems than we solve. :palm:
We must remember a few rules:
- Nobody cared about the ESR capacitors before the advent of switching power supplies, then, come to change electrolytic capacitors in a 70s amp on the pretext that the ESR is too high, it's absurd.
- Generally, a too high ESR is manifested in one way or another: ripple too high, oscillations, instabilities, ....
To understand if the ESR has or not an importance in the circuit, imagine the circuit with an additional resistance in series with the capacitor .... the operation of the circuit will be modified or not?
For example, for an inter-stage capacitor of an audio amplifier, the low leakage is more important than the ESR.
In a switched-mode power supply, the ESR can usually be checked in circuit by measuring the ripple and comparing it with the ripple specified by the manufacturer of the device.
It is normally necessary to replace:
- bulged capacitors or with leaking electrolyte
- capacitors placed near a heat source. (power resistors, radiators, ...)
- SMD electrolytics capacitors .... if we find that some are defective, it is better to change them all.
In principle, the capacity, ESR and leakage at rated operating voltage should be checked , not just the ESR.
I repair vintage audio gears, my customers know I refuse to recap their amplifiers and receivers, I only replace what is really faulty.....I have no claim, nor return, all my customers are very satisfied.
« Last Edit: December 30, 2017, 10:35:41 am by oldway »
The following users thanked this post: harrimansat
Offline oldway
« Reply #21 on: December 30, 2017, 11:36:20 am »
I was speaking about beginners, I doubt about a beginner could be able to design a brand new mass produced device.... :scared:
It was more about repair, not design.....
Offline tigr
  • Country: ua
« Reply #22 on: December 30, 2017, 02:43:02 pm »
Also, ESR varies heavily on temperature, frequency and age.
I'll give an example. Here's the old board from audio equipment. The capacitors 1uF/16v are 35 years old. The table is needed to determine which ones of them bad.
« Last Edit: December 30, 2017, 02:48:06 pm by tigr »
Offline PA4TIM
« Reply #23 on: December 30, 2017, 03:36:37 pm »
Why you NEED it ?  People repaired audio equipment decennia long without ESR tables. The most important thing is how the circuit works. And that can be done with a FG, a scope and a multimeter. If those measurements point at a bad cap you desolder it, measure it with a decent LCR meter and if needed replace it with a suitable new one with similar specs for capacitance, D, voltage, ripple current and size (so it fits).
The problem is that caps have a bad name because the last 10-20 years manufacturers from cheap consumer stuff use caps that are not suited for their job. I have testgear from the 60's still with the original caps. I do commercial repair work, but no consumer stuff,  and I also have to replace caps so now and then but the same goes for transistors, diodes and things like 74/40/45 IC's. Most times the caps are not even really dead. I have not yet seen popped caps (I have seen them but that was only in consumer stuff I repaired for my self or from family)
Offline madires
  • A qualified hobbyist ;)
« Reply #24 on: December 30, 2017, 04:35:03 pm »
When watching videos about repairing audio gear I sometimes cringe when the expert replaces all electrolytics with low-ESR 105°C "audio grade" caps. In most cases a 85°C standard cap is totally sufficient. Low ESR caps could be even counterproductive in those applications. The ESR tables give just a rough idea about the expected ESR value of a good cap. You don't need to replace a cap if its ESR is off by a few percent. When the capacitance is ok, but the ESR is way off, it's an indication that the cap is dying. A bad cap has most likely a low capacitance and a high ESR. So a capacitance check already finds most bad caps.
The following users thanked this post: rrm479
Offline tigr
  • Country: ua
« Reply #25 on: December 30, 2017, 05:23:45 pm »
Why you NEED it ?
6 capacitors. In all capacitors, the capacitance is in the range 1-1.5 uF. ESR 2-15 Ohm. How would you define a bad capacitor in the circuit without measuring ESR?
Offline PA4TIM
« Reply #26 on: December 30, 2017, 06:15:07 pm »
I already explained why I do not measure ESR in situ (= in circuit) and why you should not do that too. More here: http://www.pa4tim.nl/?p=3775
Just use a scope or desolder them and use a decent LCR meter to measure them. Ever wondered why serious brands do not make ESR meters ?  ;)
Some math. A 1 uF cap has a reactance of 1326 ohm at 120 Hz. If we take 15 ohm we have a D of 0.01. The few datasheet, I looked stated a D of 0.1 up to 0.3 as new.  That is an ESR of 132 ohm at 120 Hz.
So for a non switching powersupply 15 ohm at 120 Hz is nothing.
For audio signal it is a different thing. at 15 kHz the ESR is about the same as the reactance.  Replacing a cap with an ESR of 15 ohm for one with 0,001 ohm in a feedback loop can do Wierd things.(phase wise)
« Last Edit: December 30, 2017, 08:29:22 pm by PA4TIM »
Offline tigr
  • Country: ua
« Reply #27 on: December 30, 2017, 06:31:27 pm »
Just desolder them and use a decent LCR meter to measure them.
Who told you that it is necessary to remove capacitors? In 99%of cases, no. ;)
Offline tigr
  • Country: ua
« Reply #28 on: December 30, 2017, 06:50:36 pm »
Look here. ;)
« Last Edit: December 30, 2017, 11:13:36 pm by tigr »
The following users thanked this post: wolfy007
Offline tigr
  • Country: ua
« Reply #29 on: January 01, 2018, 07:29:23 pm »
And also the tables are necessary to correctly understand the results of measurements.
« Last Edit: January 01, 2018, 10:16:21 pm by tigr »
Offline nuno
  • Country: pt
« Reply #30 on: January 01, 2018, 10:42:29 pm »
Recently measured an unused 25yo 2.2uF 50V electrolytic, which measured 2.2uF and 3.2 Ohm ESR (using scope, fungen and calculator).
Offline PA4TIM
« Reply #31 on: January 05, 2018, 02:47:51 pm »
Nobody, if you know something about electronics you know why not to measure in situ. The point is that it often is possible but it can be way off so you simply can not trust the readings. It a sort of Russian roulette.
- Without analysing the schematic you do not know if there are parts parallel that can make a cap with sky high ESR look good. And that alone is reason enough !!
- A 100 kHz squarewave can have frequency components upto 1 MHz.  So inductive components like traces, inductors, resistors can polute the readings and skin effects start to play a role.
- the biggest problem for ESR in or out circuit is that you do not know what the measured value is. ESR at 100 kHz is almost never stated in datasheets.
- The tables are miles apart from each other and often specially made for a meter (most ESR meter do not measure ESR but |Z| measured  at 100 kHz so you can not use them for another meter.
- There is no low ESR. Nowhere is stated when the ESR is low in absolute numbers. A low ESR cap from brand A can be twice as high as a low ESR cap from brand B.
But you are the specialist
 I just measured a few 470 uF 25V capacitor. I measured 0.182 ohm  and  0.223 ohm in situ and the same were 0.115 ohm  and  0.205 out of the circuit. I used a IET LCR meter, one from Hameg and my own designed ESR meter. Calibrated with ESI standard resistors.
ps: I do not consider a ledbar ESR indicator from BK as professional gear.
Offline wraper
  • Country: lv
« Reply #32 on: January 05, 2018, 02:52:42 pm »
PA4TIM, there is on issue with measuring out of the circuit. When desoldering and therefore heating the capacitors, ESR often becomes significantly lower. In some cases, especially for small caps, it may fool you.
Offline PA4TIM
« Reply #33 on: January 05, 2018, 06:08:04 pm »
Wraper, I know but it is good to mention because beginners tend to heat them up a lot due to crappy soldering tools.. I have a very good desoldering handpiece (Pace SX-100)   They are out within a few seconds so most times they are still cold. If not I let them cool. ESR for a hot cap can be half the value of a cold one.
This afternoon I checked a bunch of caps in a secutest that had some problems. I checked them again in situ and out.   My own design meter can do 10kHz to 100 kHz and as suspected (by me) ESR in situ at 12 kHz was much closer to the out situ measurements. Here I state the 100 kHz ESR as measured with my IET LCR meter at 100 kHz
So a little quiz:
- 10 x 100 uF 35V measured in situ and a few minutes after desoldering and again 1 hour after removing just to be sure. Differences were neglectable.
out          in
0.209   0.178  - 14.8%
0.195   0.231  +18.4%
0.194   0.238  +22.7%
0.198   0.158  - 20.2%
0.214   0.183  - 14.5%
0.271   0.347  +28.0%
0.305   0.346   -13.4%
0.298   0.181   -39.3%
0.304   0.352  +15.8%
0.313   0.332  + 6%
So that gives an uncertainty % of -39 to +28 That is a lot. Besides that a cap can be shunted by others (that was here not the case) and so a cap with an very high ESR can still measure low. That increases the uncertainty even more and makes it useless other then a quick check to expose the really bad ones.
because If the ESR measures very high then there is a very big change that cap is bad. But why bother, if you can or will not test them the right way, just replace them.
And then there are other problem. A dead-shorted cap has a very low ESR. But to much leakage is not detected.  The same for dielectric absorption. And another parameter, the capacitance itself, the most important parameter. Multimeters are only usable for good caps so you need an LCR meter and desolder them after all.
There is one simple test that you can do that tells you quickly if the caps fail:  Measure the ripple voltage with a scope. After that desolder the suspected bad one and test it with an LCR meter. Look up the max value of D or tan-d in the datasheet if you want to be sure. And if you really want to exclude everything do a leakage test.
Sorry for the members of the holy ESR church but this it the way it should be done.  And yes, in cheap TV's and other consumer crap 99% of the times so much caps are bad that the chance of shunting a good one with a bad one is small. That lonely not completely shot cap that on its own tries co keep thing running will not influence much.
I do not repair consumer stuff and bad caps that are so bad that things do not work anymore are rare in the things I must repair. An ESR meter is for me not very useful. I can measure ESR, I'm not stupid, if it really was a good thing I would do it. I once was a believer, do you think I designed and build several ESR meters if I was a non-believer ?
So dear members of the holy ESR church , what to do with these caps ?  Replace them or keep them ?
« Last Edit: January 05, 2018, 06:09:49 pm by PA4TIM »
The following users thanked this post: NikkiC
Offline tigr
  • Country: ua
« Reply #34 on: January 05, 2018, 08:06:58 pm »
Show the photo and the result of measurement by your device of this capacitor.
Offline tigr
  • Country: ua
« Reply #35 on: January 05, 2018, 08:44:13 pm »
Give a specific example of some scheme.
Offline PA4TIM
« Reply #36 on: January 05, 2018, 09:00:34 pm »
Just basic electronics:
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-7/square-wave-signals/
http://mathworld.wolfram.com/FourierSeriesSquareWave.html  (the math part)
A squarewave has in theory an infinitive amount of odd harmonics. How much depends on the rise and fall time. A faster rise/fall time is more harmonics.
As soon as I find one that is not yet exploded (like a short tantalum) If a cap is short it leaks DC current. If it is dead-short the DC resistance is close to zero ohm. What do you think, is the resistance for the signal from your ESR meter in such a case ?  ;)
But first answer my questions above, are my caps bad ? I know the answer without tables, but I like to hear from you which table is correct and should I use. You must know the answer, otherwise there is no use for your ESR meters  ;)
Offline tigr
  • Country: ua
« Reply #37 on: January 05, 2018, 09:08:58 pm »
Give an example instead of 100uF, some low-impedance capacitor. You can 3300uF/6.3v. Or you do not have such? ;)
Offline PA4TIM
« Reply #38 on: January 05, 2018, 09:20:05 pm »
Why not the 100 uF's ?  I have given you all the measured values so now you can tell me if they are good. What do you do if you had to repair this instrument ? call the owner, sorry, it has 100 uF caps in side . I do not know how to test them ?  >:D
http://schneiderelectronicsrepair.nl/?p=518 There you see the instrument that houses the 100 uFs
 I have new caps  on stock up to 6800 uF. In several voltages and type. Besides that a lot of SMD solid polymers and tantalums.  I repair test and calibration gear for a living so I only use high quality caps (Panasonic)
Offline tigr
  • Country: ua
« Reply #39 on: January 05, 2018, 09:23:13 pm »
Look here.
Offline PA4TIM
« Reply #40 on: January 05, 2018, 09:50:04 pm »
So in that case some need to be replaced. But why that table ?
I rather use the table below. It is called a datasheet.  D is max 3 x 0,14 at 100 Hz. The measured D value of the worst cap of my list is 0.039
So all my caps are still as good as they can get.  ;)
https://www.vishay.com/docs/28316/116rll.pdf  the complete datasheet
Offline tigr
  • Country: ua
« Reply #41 on: January 05, 2018, 10:23:47 pm »
Offline PA4TIM
« Reply #42 on: January 05, 2018, 10:40:09 pm »
Yes, an often made mistake, Impedance is not the same as ESR.   Besides that, my caps are 35V and not 10V .  Z=impedance= (R+jX),  R is ESR,  jX is reactance. R is frequency depended. The lowest value is not at 100 kHz. Often is the SRF of an through hole cap lower as 100 kHz, the cap is inductive above the SRF.
The lowest ESR is often somewhere between 50 and 100 kHz. That is de reason the datasheet for through holes state the ESR (in the form of DF or tan-d) at 100 or 120 Hz.
So I guess you did not read my page about ESR I linked several posts ago  ;)
« Last Edit: January 05, 2018, 10:45:32 pm by PA4TIM »
Offline ez24
  • L.D.A.
« Reply #43 on: January 05, 2018, 10:43:35 pm »
Reading
Offline tigr
  • Country: ua
« Reply #44 on: January 05, 2018, 10:56:02 pm »
The following users thanked this post: ebclr
Offline PA4TIM
« Reply #45 on: January 05, 2018, 11:05:50 pm »
That is an impedance table, not an ESR table.  |O
Lets take a cap from my measurements  with an ESR of 0,2 ,
Z of 100 uF @ 100 kHz , Z = (0.2-0.0159j) |Z|= 0.2 ohm (the squarroot of (R squared + jX squared))
« Last Edit: January 05, 2018, 11:12:47 pm by PA4TIM »
Offline tigr
  • Country: ua
« Reply #46 on: January 06, 2018, 12:15:13 am »
Tomorrow I will make measurements of capacitors 100uF/35v. I will show the measurement in the circuit and out of the circuit. There is no difference.
1000uF/50v.ESR-0,01 Ohm
« Last Edit: January 06, 2018, 12:17:59 am by tigr »
Offline The Soulman
  • The sky is the limit!
« Reply #47 on: January 06, 2018, 12:33:09 am »
How about this one?
Offline tigr
  • Country: ua
« Reply #48 on: January 06, 2018, 12:45:31 am »
 :palm:
Offline tigr
  • Country: ua
« Reply #49 on: January 06, 2018, 09:20:25 am »
So a little quiz:
out          in
0.209   0.178  - 14.8%
0.195   0.231  +18.4%
0.194   0.238  +22.7%
0.198   0.158  - 20.2%
0.214   0.183  - 14.5%
0.271   0.347  +28.0%
0.305   0.346   -13.4%
0.298   0.181   -39.3%
0.304   0.352  +15.8%
0.313   0.332  + 6%
I measured my capacitors. The ESR is within 0.2-0.4 Ohm. All the capacitors are not new. You have good capacitors.
Offline The Electrician
« Reply #50 on: January 06, 2018, 10:33:46 am »
It's true that given Z = R + jX, ESR (which is the same same as R here) is not the same concept as |Z|.  ESR is only a part of Z; the other part is X.  But the low cost ESR meters measurement of |Z| is a perfectly adequate substitute for measurement of ESR if the measurement is done at 100 kHz and component being measured is a typical aluminum electrolytic.
I explain why this is true in another thread: https://www.eevblog.com/forum/projects/impedance-lcr-esr-meters/msg459262/#msg459262
Your calculation in reply #47 shows this equivalence; the numerical value of ESR is the same as |Z|:
"That is an impedance table, not an ESR table.  |O
Z of 100 uF @ 100 kHz , Z = (0.2-0.0159j) |Z|= 0.2 ohm (the squarroot of (R squared + jX squared))"
Offline tigr
  • Country: ua
« Reply #51 on: January 06, 2018, 11:32:45 am »
100uF/35v.
Offline PA4TIM
« Reply #52 on: January 06, 2018, 02:28:33 pm »
Yes I know, you are right, as the capacitance increases Z comes closer to R. A bit a bad example. Now beginners think it never makes a difference because they do not understand complex numbers and math.
But something else, as far as I know the 100 kHz in datasheets is measured with an impedance analyser using a true AC sinewave. The signal from my IET is a sinewave, as goes for all my other LCR meters and bridges. But many ESR meters use a squarewave with an DC offset.
My own ESR meter reads the same value with a 12kHz  squarwave as my IET at 100 kHz(sinewave), but not around 100 kHz, then they differ. I have done a lot of ESR measurements with VNA's. But that is also with a sinewave.
But Tigre does not understand my point.
- in situ measurement CAN be usable, but the problem is you need to know if there are components parallel that influence the readings. In many circuits there are at least several 1 to 100 nF caps, for instance on the Vcc pins of IC's. So a reading can be spot on or way off. As the reading is to high you replace a good cap, so no problem and a rare occasion, but the change the reading is to low is bigger and that makes in situ measurements handy as an aid and not a replacement for real troubleshooting with scope and multimeter.
- The table thing. After I told my caps are good he comes with yet another table that shows the impedance and according that table they are bad but he says they are good . The ESR is in my case on its own already higher as the reactance. But according the datasheet they are still within the new-specs. However, if I was believing this table I would have replaced them and then still the secutest would not have worked. I knew they must be good because ripple voltage was good but I did it just to see how usable an in situ measurement was.
So you get measurment data that could be way off, and the dangerous part is that the biggest chance is, the cap is worst as measured.
you can not really check the value because the tables are to different from each other and based on "nothing" without data about the caps and meter.
But on the upside, the ESR meter is cheap and makes it possible for beginners to repair some consumer gear without much knowledge.  (because there caps are number 1 and often so bad the ESR is very high). It can be a handy help to save time for pro's to0. They often know upfront the problems with TV's and know the ESR values they must see. The secutest is something like that. If I check diodes I know there are two that always measure a short in the diode function of the DMM.
And what about this: see picture
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #53 on: January 06, 2018, 03:05:43 pm »
Interesting discussion; I learned since an early stage in electronics to be very careful with in situ readings of component parameters, as I was constantly being fooled by skewed readings. Later in life I found out that any electronic device should be furnished with characterization curves similar to the ones provided by diodes and transistors. In the absence of that for passives, the next best thing is to (1) try and go by with the spot numbers of their datasheets - usually the D factor at 120Hz and sometimes the Z at a higher frequency - and (2) with a complete understanding of the circuit to evaluate if ESR or other parameters can exert an influence. I could not yet find a reliable table of ESR (or D) ratings around, but as PA4TIM and others have said there are simply too many factors to create a reliable one.
Another excellent reference is the discussion below, in particular the posts by the resident expert free_electron.
https://www.eevblog.com/forum/beginners/esr-meter/
« Reply #54 on: January 06, 2018, 03:33:19 pm »
I don't think it's a bad example at all.  If they carefully read what I said they won't think it never makes a difference.  They don't need to understand complex numbers to understand my conclusion.  They can see what I'm talking about in the image showing |Z| and ESR over a wide frequency range with understanding complex numbers.  I said that ESR and |Z| at 100 kHz are the same for typical aluminum electrolytics, and that means no film capacitors, no tantalum, no polymer, no MLCC capacitors, etc.  In the next few posts after the one linked above, I explain that there a few exceptions, but reply #14 in that thread: https://www.eevblog.com/forum/projects/impedance-lcr-esr-meters/msg459471/#msg459471 shows a range of capacitor sizes that more than span the range of cheap ESR meters so that within the allowable range of capacitor size for those ESR meters, such capacitors still have |Z| and ESR the same at 100 kHz.  Low cost ESR meters do an adequate job of measuring ESR at 100 kHz for typical aluminum electrolytics.
True enough, but it doesn't matter if they correctly measure |Z|.  In the referenced thread, I discussed what errors might occur due to using a square wave excitation voltage.  I showed that if ESR is constant from 100 kHz to higher frequencies, square wave excitation doesn't lead to an error.   I gave an example (axial lead capacitors) https://www.eevblog.com/forum/projects/impedance-lcr-esr-meters/msg459434/#msg459434 where square wave excitation could lead to an error in the measurement due to the higher ESL of axial lead capacitors; the reading was in error by a factor of 2.  A factor of 2 error won't prevent the user from detecting a failed capacitor's greatly elevated ESR; in case of a failed capacitor the ESR will be many times larger than it should be.
The low cost ESR meters aren't precision instruments anyway.  I wouldn't use one to collect data to make a table of capacitor ESRs.
I don't understand this; both frequencies pointed to above are the same.  That doesn't make sense.  Did you intend for the first one to be 10 kHz rather than 100 kHz?
If you are measuring a capacitor whose ESR is constant at frequencies above 100 kHz (to at least 1 MHz), then you should get the same result with square wave excitation as with sine wave.  Why do you suppose your own meter gets a different result at 100 kHz?
I completely agree that the repairman needs to determine if there are other capacitors in parallel with a capacitor being measured in circuit, or any other factors that make it necessary to remove a capacitor to properly diagnose its health.
I also agree that the various tables are a general guide only.  As a repairman gains experience, he will learn what a good ESR is for a particular capacitor.  Better than using tables is to just compare to the ESR of a known good capacitor.  :)  It's the capacitors that are marginal that are troublesome.
When I used to repair TVs many years ago, what was known in the business as a "callback" was a big money loser.  If there was any question about a capacitor's health, I replaced it; it wasn't worth the cost of a new capacitor to take a chance on having to deal with an unhappy customer and repair the equipment again.
« Last Edit: January 06, 2018, 04:53:55 pm by The Electrician »
Offline tigr
  • Country: ua
« Reply #55 on: January 06, 2018, 07:23:58 pm »
Offline tigr
  • Country: ua
« Reply #56 on: January 07, 2018, 08:41:03 am »
Difficulties in estimating the values of ESR, happen with such capacitors, which are not present in the tables.
2,2uF/10v
Offline PA4TIM
« Reply #57 on: January 07, 2018, 10:07:26 am »
One last try.
Measurements out of circuit:
The good way:
-Take a LCR meter that gives you D (=tan d).
- Look up the datasheet
- lookup D (=tan d = DF = 1/Q = related to loss angle)
- and the frequency they measured that, often 100 or 120 Hz (it was 1 kHz for a long time)
- lookup the max value of D, most times 200%
- Take a real LCR meter, set it at the stated frequency
- Measure C, is it within specs ? often +/- 20% when they are new, how low the circuit tolerates is an other question.
- A real LCR meter or bridge will give you D
- If both are within specs the cap is good. (if you want to go all the way you can measure leakage. (often stated for 2 or 3 minutes, this is not the working voltage leaking test, that is a test you do for safety.)
The easy way, but not always a good way
- replace the caps by the same brand an type new ones (nothing wrong with this)
- or with a suitable replacement with the same specs
- do not kill the pcb by using crappy desolder tools
- this did not help ? Do some real trouble shooting with things like a scope and multimeter.
I only repaired 3 TV's and non of them had dead electrolytics. (a shorted 1 nF 1kV cap, a dead 4 MHz Xtal and a shorted mosfet) but my satellite receiver needed over 40 new caps.)
The hard way:
- fire up your ESR indicator
- measure the cap in circuit
- spend an afternoon looking for tabels that gives the ESR for 2 uF and works for your indicator (so a Z or an ESR table)
- Then decide witch table could be the correct one.
- You do not know so start a bunch of new topics to get the same answer in all of them...or roll a dice
- before going mental you just replace the cap to be sure
3rd way:
- Fire up your impedance meter (a sweeping one or a simple DIY self ESR meter that does not measure ESR but Z, how convenient    ;) )
- look up datasheet, note impedance Z at 100 kHz.
- is measured Z is withing the stated specs, the cap is good.
4th way, involves some math:
- fire up your real ESR meter
- measure the ESR at 100 kHz
- look up the datasheet and note the impedance at 100 kHz
- calculate the reactance of the cap (based on C measured at 100 kHz ) 1/(2pifC) for 2,06 uF = 0.773 ohm
- calculate Z ; in your case based on 1,2 ohm and 0.773 ohm makes: 1.427 ohm
- if Z is within the stated specs from the manufacturers datasheet the cap is good.
5th way,
- take a scope
- probe the power rails
- if there is to much ripple, replace the cap.
- how high the ripple is allowed to be is stated in the service manual of the thing you repair.
- if it is not stated you must estimate that. Not to hard, measure on the Vcc pins of some components.
You need electronic knowledge for that but you need that for repair anyhow (only swapping maybe-dead caps and random components  is not really repair)
The very bad way:
- every way that measures component in circuit  >:D
You can do that if you want to quickly find the real dead caps in something that is so dead you can not start it. Then remove and measure them using one of the ways above. Then start the normal trouble shooting.
The following users thanked this post: ez24, nugglix, AndyA, Vovk_Z
Online BravoV
  • +++ ATH1
« Reply #58 on: January 07, 2018, 10:53:04 am »
PA4TIM, save your energy, cause Tigr is well known to bombard this forum not only this thread, with photos with his various "elite" esr meters and caps, and I'm guessing he has problem with English.
« Last Edit: January 07, 2018, 10:54:39 am by BravoV »
The following users thanked this post: Vovk_Z
Offline JoeO
  • I admit to being deplorable
« Reply #59 on: January 07, 2018, 11:15:35 am »
I agree with BravoV.  tigr is also trying to show off how much he "knows".  He is trolling people wasting their time.
The day Al Gore was born there were 7,000 polar bears on Earth.
Today, only 26,000 remain.
Offline tigr
  • Country: ua
« Reply #60 on: January 07, 2018, 01:03:02 pm »
BravoV
Do you have any complaints about my measurement results?
Online BravoV
  • +++ ATH1
« Reply #61 on: January 07, 2018, 01:24:01 pm »
BravoV
Complaints what ? Its your measurements, your equipments, your caps , why should I have any problem with that ?  :-//
My post is merely for PA4TIM as I know he is a really generous & knowledgeable guy here around with tons .. yeah, literally tons in weight of 1st tier test equipments, and seeing his posts are getting ignored again and again, just pity him.  :'(
Also probably to The Electrician too, another really helpful, resourceful and knowledgeable guy around here "especially" in capacitor I believe.
Offline tigr
  • Country: ua
« Reply #62 on: January 07, 2018, 02:25:20 pm »
No problem. All good. Good luck. :)
Offline David Hess
  • DavidH
« Reply #63 on: January 07, 2018, 04:37:46 pm »
The good way:
It is possible for a capacitor to pass all of these tests and still be bad.
I came across a z-axis amplifier in a Tektronix 7904 which could not meet its transient response specifications after calibration which had almost no effect.  The natural suspect was the Sprague 30D series 5uF 150V 8105 capacitor used for low ripple current decoupling of the output stage's bias supply but testing after removal revealed proper capacitance, low frequency dissipation, and leakage.  The capacitor was still bad however since replacing it solved the problem.  I assume it suffers from high impedance at higher frequencies which a network analyser would reveal in a comparison with a good capacitor.
« Reply #64 on: January 07, 2018, 06:07:19 pm »
The good way:
Here's an example of the very sort of thing you're describing.  Without a sweep with an analyzer the difference between the defective cap and a good one wouldn't be discovered.  It's too bad you didn't get to do a sweep of your anomalous capacitor!
https://www.eevblog.com/forum/projects/capacitor-measurements-on-an-impedance-analyzer/msg178923/#msg178923
Offline oldway
« Reply #65 on: January 07, 2018, 07:42:39 pm »
All his posts are about ESR....He probably also sleep with his ESR meter....  :-DD
Let's be serious, that exaggeration is not healthy for the beginners who can believe ESR is more important than it is really.
« Last Edit: January 07, 2018, 07:49:22 pm by oldway »
The following users thanked this post: nugglix
Offline David Hess
  • DavidH
« Reply #66 on: January 07, 2018, 09:09:43 pm »
I kept the capacitor for testing when I have the proper equipment.
Offline marcuswilson007
« Reply #67 on: February 07, 2018, 11:48:10 pm »
I don't understand why anyone would remove capacitors on an old piece of gear to test them, if I removed a capacitor I would not refit it, just replace it.
If one capacitor is out of spec, they should all be replaced.
The following users thanked this post: derree
Offline rsjsouza
  • Eternally curious
« Reply #68 on: February 08, 2018, 02:07:55 am »
Not all capacitors are bad on a board just because one or two show some fault - they may belong to entirely different circuits that impose stresses in different manners. Also, not all equipment that has some mileage on it is doomed to have all its capacitor replaced. At last, some capacitors are quite expensive, which needs to be considered on the overall economical viability of the repair. I have one example on my bench: a mid 1990s A/V receiver that has monstruous filter capacitors in excellent shape and some smaller ones that are showing signs of wear - by your logic, a $2.00 repair can easily become $50.00, which surpasses the resale value of the equipment.
Offline David Hess
  • DavidH
« Reply #69 on: February 08, 2018, 07:13:43 pm »
If I unsolder a capacitor then I will likely replace it whether it tests bad or not.
For aluminum electrolytic capacitors, I may or may not replace all or specific ones depending on the circumstances.  If a decoupling capacitor tested bad, then I would change all of the decoupling capacitors.  If an output capacitor tested bad, I would replace all of the output capacitors.  If an input capacitor tested bad, then I would replace all of the input capacitors.  These three catagories tend to all wear out at the same time within their catagory.
Offline ipman
« Reply #70 on: October 23, 2018, 04:50:28 pm »
Sorry for digging the topic grave, but really need to ask something related to this one.
I am trying to troubleshoot a SMPS inside a blender (based on LNK304) which is behaving like bad caps. The suspects are two 1 microfarad capacitors at 450v. One of them has an ESR of 31 and the other one 37 ohm. They are used for AC rectification (here in EU 230V).
I have nothing to compare against, if somebody has a reference I really appreciate.
P.S. I've changed places, its slightly better now, but still not working. I suspect those caps to be bad, but i have nothing similar now and obtaining new ones is a PITA for the moment.
Thank you!
« Last Edit: October 23, 2018, 05:03:34 pm by ipman »
Wife hates words like Fluke, Ersa ...
Online mariush
« Reply #71 on: October 23, 2018, 05:14:06 pm »
Seems like a bit on the high side. I would expect less than 10-15 ohm
Offline PA4TIM
« Reply #72 on: October 23, 2018, 11:51:00 pm »
Search the datasheet for your cap. They state D (often as tan d) Then measure the capacitance and D at 120 Hz. If those values are within limits and the cap does not leak DC he is good. ESR is often not stated but they give impedance at 100 kHz. The reactance is low at 100 kHz so you can use that value as if it was ESR.
But often they give no limit for the impedance.
Measure desoldered.
However the best test is measuring the ripple with your scope. If that is OK the caps are good. Easiest way is replacing them with new ones that have the same specs (D, C, Vdc and max allowed current ) you need to correct the values for the current pulses in the datasheet for the operating frequency (they state the correction factor in the datasheet)
Offline ipman
« Reply #73 on: October 24, 2018, 08:23:31 am »
I cannot find the datasheet for that capacitors, as usual in cheap ones.
Of course, i can find the datasheet for ones manufactured by Panasonic and compare, but this is not 100% relevant.
I don't have a scope now unfortunatelly.
I removed them both from circuit and measured them with a Atmega based tester, which showed allmost exact capacitance value, but this is not helping everytime.
My problem is that i am now in a new country and lacking language skills makes living more dificult, imagine searching for capacitors ... that's why i am searching for help here.
Offline perieanuo
« Reply #74 on: October 24, 2018, 10:30:14 am »
Thank you!
Check resistors,inductance, IC.I don't think it's those capacitors in question
Offline ipman
« Reply #75 on: October 24, 2018, 09:07:36 pm »
Resistors seems to be fine, IC is hard to troubleshoot without osciloscope.
The simptoms: normal startup, works for 2-3 seconds blinking some LED's (normal operation) then shutdown.
I think this is not about a resistor, at least from my experience.
If i swap the capacitors back to their original place, it will not go as far as blinking LED's for a short time.
Offline bitseeker
« Reply #76 on: October 24, 2018, 11:23:16 pm »
There could be multiple issues with the blender's power supply. If the switching IC doesn't get stable-enough power, then it won't start. Moving the primary filter capacitors probably stabilized the power enough for the IC to attempt to start.
After a few seconds of running, if the switching IC doesn't receive feedback from the low-voltage side, then it'll shut down again. Check the components along the path from the output sense resistor back to the IC. The resistor might be damaged, an opto-coupler may be dead, the voltage reference for feedback comparison might be dead.
It's also possible that one or more diodes are shorted or the switching mosfet died. When the supply is on for 2-3 seconds, do you measure the correct voltage at the output of the SMPS? If you get little to nothing, it could be the mosfet.
Those are some of the usual suspects.
Offline ipman
« Reply #77 on: October 26, 2018, 08:19:37 am »
@bitseeker Thank you for all of that.
LNK304 is a low-component count chip for SMPS. It integrates the MOSFET and does not have feedback as i can see from reference design. There is no voltage reference also.
Resistors are very unlikely to be burnt in a 1W SMPS (12v, 120mA max), but you are right, i will chech them.
I will try to measure the voltage, but this is extremely ankward because of construction and the fact that my one year old son likes all my colorfull meter probes. It will take some time to do so.
But again, thank you all.
Offline bitseeker
« Reply #78 on: October 26, 2018, 05:52:50 pm »
Yeah, not having seen the board you're working on, I can only give some general tips of what I've seen in SMPS. With the high level of integration, hopefully there's less to trace through to locate the problem.
Offline Karlo_Moharic
  • Country: hr
« Reply #79 on: October 26, 2018, 06:02:14 pm »
.... but when diagnosing caps in a malfunctioning circuit with a lot of caps you will need a ballpark numbers for ESR because desoldering all those caps would be a problem....
You can't properly measure ESR , if your cap is still part of the circuit when you do it.
Offline nuno
  • Country: pt
« Reply #80 on: October 28, 2018, 11:30:16 am »
One of the latest surprises I had concerning component failure was a 1/4W resistor, clean and 100% immaculate looks from the outside, however, was open (was a 1 or 2.2 Ohm resistor, in series with the rail). Also in a low power (linear) PSU. Didn't take long to find it only because someone on the Internet had already done that job "for me" (many thanks!).
« Last Edit: October 28, 2018, 11:31:55 am by nuno »
Offline 6PTsocket
« Reply #81 on: October 29, 2018, 03:26:27 pm »
I was considering buying an ESR meter for general trouble shooting but after reading this thread I wonder what "bad" is. Is an in- circuit device only sort of useful? Can it only be trusted to spot a bad cap when readings are very high? Is there some simple guide lines for using one, short of reasearching the factory specs on every cap tested?
Sent from my SM-G900V using Tapatalk
Offline bitseeker
« Reply #82 on: October 29, 2018, 09:06:49 pm »
Simple guidelines:
1. You can test in-circuit as a quick, but not necessarily reliable, check if you know the circuit topology and how your measurements may be affected by other components on the board. Always follow up with a proper measurement out of circuit.
2. Instead of #1, at least desolder one lead prior to taking a measurement. It's half the work of removing the component, but much better than measuring completely in-circuit.
3. Compare your measurement with the datasheet for the component. If a matching datasheet isn't available, compare it to the datasheet for as similar a capacitor or capacitor series as possible. If the value is significantly different (e.g., very high ESR), then it's probably out of spec.
4. If you have no basis for comparison, replace the component and see if the original problem is corrected.
Offline ipman
« Reply #83 on: November 08, 2018, 07:52:21 pm »
Some time later: found new caps. Jamicon brand, not LowESR.
They measure (stand-alone, not in circuit) 10ohms, compared to 35-37 originals. Also, they are larger than originals both in diameter and height.
Replaced them, but there is still something else.
Output varies slowly between 3 and 5v and settles near 3v afther a while.
Probably a dead rectifier diode, will continue when i have enough time to do so.
Offline NikkiC
« Reply #84 on: January 25, 2019, 04:38:45 pm »
You wrote this a year ago but I laughed hard reading  your 'holy ESR church' comment.   So true!  I have and still use electrolytic caps that are 40+ years old.   No leakage issues, no high ESR, they are rock solid.  I have concluded that many times they fail due to just being placed into a circuit in a willy-nilly manner, not taking into account heat, ripple current, etc.  I've a lot of old vintage computer power supplies from the 60's 70's and 80's.   Stuff like IBM, Digital, DEC.  I just don't run into very many computer grade electrolytic caps that need replacement. When I do, I replace them with the same exact capacitor that is also 40+ years old. I believe these old caps will likely work flawlessly another 40 years.  To me, blindly replacing them  just because of their age is irresponsible. I have even seen old caps that have been greatly abused, baking in the sun and exposed to harsh weather extremes for years, test good and operate reliably.
In my opinion, the consumer junk is just copy/paste of previous designs, flaws and all.   It is known, expected and intended for caps to fail in modern consumer electronics.  Since you already know most are going to be bad or marginal, replacing them all makes sense.  I get it.  But this just doesn't  hold true across the whole spectrum of electronic designs.   Not blindly replacing all electrolytic caps due to age is apparently an unforgivable sin resulting in false accusations of being a sorcerer or witch, excommunication and eventual condendamation to  be burnt at the stake and then sent hell for ever and ever amen.  Seriously.   To read the admonishments of  holy ESR church members  to seasoned veterans who know better  and refuse to believe is astonishing. Thanks for the laugh and for sharing your knowledge.
The following users thanked this post: rsjsouza, Ellis_Beatty
Offline mvs
« Reply #85 on: January 26, 2019, 11:12:28 am »
Electrolytic capacitors do have a shelf life. If a piece of vintage equipment was unpowered for decades, it may need a reforming of some caps before it can be used again. Blind replacement of caps is quick solution for this problem, if maintaing of original state is not required.
Offline wraper
  • Country: lv
« Reply #86 on: January 26, 2019, 02:23:24 pm »
Not only that. You don't really know how much life is left in them even if they measure OK at given moment. It might be several decades or just a few months. Replacing all of them is a way to ensure reliability, usually not expensive too.
Offline WindWalker
  • Country: pt
« Reply #87 on: April 25, 2020, 08:04:25 pm »
I've just received some Rubycon CFX capacitors (3.3uF 400V 10x16mm). I've tested them for ESR using the "method" shown in this video (I don't have an ESR/LCR meter).
With a 2V 100 kHz square wave (zero offset), I've measured a typical 560-580mV peak to peak voltage across the capacitor (1.04V in two of such capacitors). I get a waveform similar to the one at 10:25 in the video. According to the video (12:49), ESR is R=50*.56/(2-.56)=19.4 Ω. According to the datasheet, maximum ESR is 0.20/(2*3.14*2*50*3.3)*1e6=96.5 Ω (mains frequency is 50 Hz here).
Questions:
1) Is any of these calculations wrong?
2) If not, is the ESR supposed to go down in the first hours of use or are these just bad/dry capacitors? The capacitors are supposed to be new (maybe they are from very old stock?)
Thanks
« Last Edit: April 25, 2020, 08:08:44 pm by WindWalker »
Offline Jay_Diddy_B
« Reply #88 on: April 27, 2020, 05:01:48 pm »
First you have to convert from Tan d (Tan delta), the tangent of the loss angle, to ESR
The datasheet gives tan d = 0.20 at 120Hz
The capacitor value is 3.3E-6
ESR = 0.02 / (2 x Pi x 120 x 3.3E-6) = 8 Ohms
So if we put this in a test circuit:
The result shows
So if you are measuring 550 - 580 mV p-p
The capacitors are good.
Regards,
Jay_Diddy_B
Offline WindWalker
  • Country: pt
« Reply #89 on: April 27, 2020, 06:33:50 pm »
Thanks a lot for the images/simulation, but I couldn't figure out why you used 0.02 in the ESR calculation while the datasheet says 0.20. Isn't it 'ESR = tan d/Xc'?
Also, could you tell me what software you used for the simulation?
« Last Edit: April 27, 2020, 06:37:16 pm by WindWalker »
Offline Jay_Diddy_B
« Reply #90 on: April 27, 2020, 08:20:13 pm »
Sorry I made a typo
The ESR should be
ESR = 0.20 /(2 x Pi x 120 x 3.3E6) = 80.3 \$\Omega\$
This is the maximum value allowed by the datasheet.
I used LTspice for the simulation.
I would expect new capacitors to be better than this.
Regards,
Jay_Diddy_B
Offline Shock
« Reply #91 on: April 28, 2020, 09:32:27 pm »
To answer the other question yes leakage and esr is less when capacitors have been recently used or are warm. Likely to bounce back somewhat to their original state when they have been sitting unused for while. Just ensure you discharge them before testing.
« Reply #92 on: April 29, 2020, 09:35:20 pm »
Sorry I made a typo
The ESR should be
Regards,
Jay_Diddy_B
Since the max DF is specified at 120 Hz, 80.3 ohms is the max ESR also at 120 Hz.  At the lower left corner of the first page of the data sheet is a chart labeled "Multiplier for ripple current".  The different allowable ripple currents at different frequencies tells us that ESR is varying with frequency.   The allowable ripple current at 100 kHz is 5 times what it is at 120 Hz.  Since the dissipation in the ESR is proportional to the square of the ripple current, the max ESR at 100 kHz is apparently 1/25 of the value at 120 Hz, namely 3.2 ohms.
WindWalker made his measurement at 100 kHz, so the max ESR at 100 kHz of 3.2 ohms is what he should be comparing his measurement to.
Offline WindWalker
  • Country: pt
« Reply #93 on: May 01, 2020, 11:19:42 pm »
Thanks a lot for this valuable information. I didn't know what these multipliers meant. So, I suppose these multipliers relate to the rated rippled current (e.g., if the multiplier is 1.0 and rate ripple current 180mA @ 100kHz, then if the multiplier is 0.2 for 120Hz ripple current should be derrated by a factor of 1/0.2=5, so 180*0.2=180/5=36mA at 120Hz).
I did some testing today. I put the capacitors as close as possible to the function generator output terminal (see attachment). Then I applied a 1V 100kHz square wave. Then I proceeded to heat the capacitor with a heat gun (400ºC at a distance of 20-30cm). I have a video here. As you can see, the peak-to-peak voltage at the capacitor dropped from ~120mV to ~40mV. This means that ESR went down from 50*.12/(1-.12)=6.8 to 50*.04/(1-.04)=2.1 Ω.
I was able to achieve the same decrease for all other capacitors (~40mV). So, I guess ESR will most likely decrease to a value within spec during use :)
« Last Edit: May 01, 2020, 11:26:02 pm by WindWalker »
« Reply #94 on: May 01, 2020, 11:52:58 pm »
Note that the "Dissipation Factor (MAX)" chart on the first page of the datasheet specifies that the measurement is to be made at 20C.  Even though the allowable ripple current is specified at 105C, the ESR at 100 kHz we calculated would be the ESR measured at 20C, so this is the max allowable ESR at 100 kHz when measured at 20C.
« Last Edit: May 01, 2020, 11:58:25 pm by The Electrician »
Offline WindWalker
  • Country: pt
« Reply #95 on: May 02, 2020, 12:47:01 am »
I see... then they should all be out of spec, as after a few minutes resting the voltage went back to ~120mV/6.8Ω, two of them even to 200 and 300mV (12.5 and 21.4Ω). So my guess is that they are old stock or even rejected stock (re)sold cheaper.
« Reply #96 on: May 02, 2020, 01:13:51 am »
Try reforming them.  Apply a variable voltage (through a protective resistor, maybe 100k) increasing gradually to rated 400 VDC.  Leave the cap on the voltage supply for an hour or so.  Then discharge the cap with a 10k resistor connected to the cap for several minutes.  Disconnect the cap from the 10k resistor, wait several minutes and measure the cap voltage, which will recover somewhat.  Make sure the recovered voltage won't hurt your ESR meter before you measure it.  If the recovered voltage is more than a few tenths of a volt, reconnect the 10k bleeder resistor and wait several more minutes, and try again.
If you can't apply 400 VDC, use the highest DC voltage you can come up with.
I've occasionally had NOS capacitors end up with much inproved ESR after this treatment.
Offline WindWalker
  • Country: pt
« Reply #97 on: May 03, 2020, 05:45:02 pm »
Thanks again for your input. I'm assuming that by protective resistor you meant series resistor (to limit the charging current on the capacitor) and not parallel resistor (to induce some ripple current).
I put 5 of these capacitors in parallel (:D) and charged them through a ~500kΩ resistor up to 300-320V (output of a bridge rectifier, mains voltage here is 230V single-phase so 230*sqrt(2)~320V). They stayed like this for almost one hour and a half.  After discharging (the simple voltage measurement with a multimeter was enough to almost fully discharge them) I did some 2-3 "bleedings" with a 10kΩ resistor like you suggested. Voltage before bleeding went up to ~1,1V and ~0,5V.
I don't have an ESR meter, and don't want to buy one to have it sitting unused for months after these experiments, that's why I use the oscilloscope plus function generator method (at a laboratory). It may take some time to have access to them again because of quarantine issues :)
Offline WindWalker
  • Country: pt
« Reply #98 on: May 19, 2020, 11:24:33 am »
Try reforming them.
My experiments with this reforming have been very interesting.
One the one hand, these 3.3uF 400V Rubycon capacitors still give me 120mV after "reforming" (they were charged at ~320V DC from several hours to about a full day), so clearly out of spec (6.8 vs 3.2Ω at 100kHz).
On the other hand, I've also received some nichicon capacitors (4.7uF 400V LD series and 6.8uF 400V CS series). Interestingly enough, some of these capacitors (not sure if the 4.7uF or the 6.8uF ones) measured about 11uF (yes!). So I put some them in parallel to do "reforming"/burn-in (with the 500kΩ resistor), and it took over 24 hours to bring the voltage up from 60V to the full 320V (across several hours, I measured 60,160,200,250,290 and 300V). After this, I got 70-80mV on them (3.8-4.3Ω), and if I did the math correctly I should expect (the squared multiplier ratios come from the datasheets):
1) 4.7uF LD: 0.24/(2*pi*120*4.7*1e-6) * (1.00/2.00)^2 = 16.9Ω
2) 6.8uF CS: 0.24/(2*pi*120*6.8*1e-6) * (0.50/1.00)^2 = 11.7Ω
Considering these reference values, my guess is that modern 400V capacitors will actually have an ESR in the range of 1-10Ω. It is a bit strange, since usually I read that proper ESR values should be less than 1Ω, eventually down to 0.1Ω, so I guess this applies only to lower rated voltage capacitors.
BTW, the protective resistor is a very good idea to 'burn-in' capacitors. It is able to limit the current to less than 1mA, allowing for capacitor self-healing without "big" currents.
Offline wraper
  • Country: lv
« Reply #99 on: May 19, 2020, 12:34:46 pm »
This is nonsense when you apply it to capacitors in general. ESR heavily depends on capacitance and to lower extent on rated voltage. Not to say some ultra small capacitors may have significantly higher ESR than capacitors with same ratings in general. For many capacitors 0.1 Ohm is completely unacceptable, for others 10 Ohm is completely normal.
Offline madires
« Reply #100 on: May 19, 2020, 01:57:18 pm »
An ESR of roughly 3-5 Ohms is typical for electrolytics around 1-10µF at 400V. Haven't you checked the datasheets you've linked? >:D
Offline m3vuv
« Reply #101 on: May 20, 2020, 10:40:13 am »
just saying i repaired the trigger circuit on my tek 453 using the 5 transister esr meter from here,the cap tested was a 100pf disk ceramic,the esr readings were nonsense but when testing some known good 100pf ceramics i got some meter deflection although meaningless but at least there was some meter deflection,on the bad cap there was none,it was a sort of go no go test,anyway doing that fixed my scope.
Offline WindWalker
  • Country: pt
« Reply #102 on: May 21, 2020, 07:14:52 pm »
Before doing these experiments, I didn't know how to interpret the datasheet information. Now I understand which values are to be expected (in the worst case, since dissipation factor is given as maximum value).
Offline masster
« Reply #103 on: July 22, 2022, 08:41:06 am »
See below my contribution to this topic. The tables are based on a very large batch of ESR measurements of new capacitors from various manufacturers.The ESR meter was Peak Atlas ESR70.
« Last Edit: July 22, 2022, 08:44:05 am by masster »
The following users thanked this post: madires, ebclr, mag_therm
« Reply #104 on: July 22, 2022, 03:56:51 pm »
Tables like this are useless.
It heavily depends on manufacturer, family of capacitor, physical construction , fat squat body or slender tall body but most importantly : what electrolyte is being used !
The ESR of a capacitor used to couple an audio signal is irrelevant. You are talking 2 ohms on an input impedance of hundreds of kilo-ohm ...
Where it matters is power supply , especially for capacitors that are working hard : current in current out. Ripple current is important because ripple current x esr gives a voltage ripple but more importantly : a power dissipation ! the damn thing will heat up ,and no matter how good the seal is , the electrolyte will evaporate over time...
So: capacitors after rectifiers are working hard, whether this is a bridge at 50hz or a switcher
Capacitors after a linear regulator are not working so hard but they can still endure pulse currents from the load side.
Don't go randomly swapping out capacitors for "better esr" the esr may be there for a reason ! a low esr cap on a lm317 output is a reason to drive the thing into oscillation ! you need 1 to 2 ohms there.
A low ESR cap on the input of a circuit fed by a power supply over a long cable (like a laptop power adapter ) can have disastrous effects. When you hotplug such a thing ( adapter is powered and you plug the cable in the jack) you will get a massive surge current. Combine that with the inductance in the cable and you will get a pulse voltage that can easily double or triple the supply voltage. if you have a 19 volt supply and your regulators are designed for 24 volts max ... be prepared for them to fry.
The electrolytes today are almost all water based. no more glycol/ DMF or DMA unless you buy specific long life / high temp capacitors.
and for cleaning off leaky capacitors : what to use also heavily depends on what electrolyte was used. electrolyte is not only conductive ( so there is electromigration when voltage is applied. ) but it can also form copper salts when reacting with the traces.
Capacitors have gotten a bad rap because of the stolen chemistry in the early 2000's , but that has long been resolved. Those were the early days of water based electrolytes. the stabiliser was missing and the water was split infot oxygen and hydrogen and the capacitor popped. Not becasue of the explosive mixture but purely because of the pressure build-up. The top just split.
A much more common failure these days is leaking at the electrodes. The rubber seal between the case and pins leaks. This can happen if the capacitor has been mis-treated : too long in the  reflow or wave and board cleaned with an incompatible cleaning agent that damaged the rubber. Or they run hot , the rubber dries out , becomes brittle and cracks.
it all depends on application and the capacitor. you cannot simply go 2200uf 16 volt : that 0.2 ohm esr.
so please : throw that ESR meter in the drawer until you learn how to read datasheets. and NEVER mix manufacturers and families. Oh i want nichicons .. ok , which one ? there's ate least 25 families and another 25 that are obsolete... and they are all different but they all are 2200uf 16 volts...
« Last Edit: July 22, 2022, 04:05:45 pm by free_electron »
The following users thanked this post: EE54
Offline masster
Re: ESR Values for Electrolytic Caps
« Reply #105 on: July 22, 2022, 04:14:35 pm »
I really don't like your disrespectful tone. You can have an opinion without being a jerk.My reply addressed the original poster message. If you don't like my reply, ignore it. Oh, and you might go for some anger management classes.
Offline mag_therm
« Reply #106 on: July 22, 2022, 04:30:34 pm »
Thanks masster.
One table like that is worth > a page of hot air.
My contribution is that the ESR increases as temperature reduces.
I  worked on an outdoor tracked vehicle with VS chopper drive.
We had trouble at below -10C as I recall, sorry I have no data about it, but recall testing in the hot/cold chamber
« Last Edit: July 22, 2022, 04:35:32 pm by mag_therm »
Offline rsjsouza
  • Eternally curious
« Reply #107 on: July 22, 2022, 05:37:40 pm »
Masster, this is a long forgotten thread that originally had problems by perpetuating an incorrect belief that tables will be relevant without many proper disclaimers. The first analogy from free_electron nine years ago summarizes the same rant today:
that's like making a table giving the weight of a cow .. depends on the subspecies, race ,where it grew up , what it ate , when it ate , if it farted yet ...
Sure this is tongue in cheek, but it gives the proper sense of the usefulness of this data in the light of the immense variations mentioned nine years ago and in today's rant as well. Nothing in the principles of the measurement and the capacitors' inner workings changed at all.
If it is not obvious, I too find ESR tables very limited in relevance due to the exact reasons pointed out years ago and in many fora around the internet, but somehow this is still a sticking point that can demonstrably cause more problems and waste than solve them - especially if someone without experience is reading this.
If you feel you can apply this safely in your environment, then feel free to do it. Unfortunately the boundary conditions are too vast for general applicability.
The following users thanked this post: sab
Offline free_electron
    • SiliconValleyGarage
« Reply #108 on: July 23, 2022, 04:31:51 pm »
i am not being disrespectful. i am just stating facts.
You have two tables high quality and normal quality. That in itself is a problem.
- what were your selection criteria ?
- what brands , models were you using ? what is the spread per cell ?
These tables have no frame of reference.
You may have put in a lot of effort but the result is not usable.
If i pick a capacitor that needs comparison : does it fall in your definition of "quality" or is it just "average" ? which table do i use ?
Even assuming that you took the best of the best for the high quality table and the worst of the worst for the normal quality. What if i use one that falls in the middle ?  which table do i use ? do i interpolate ? is the gradient from normal to high quality linear ?
What if i have a very high quality 2200uf 35volt 105 degree 10000hour brand new capacitor and it measures 0.52 ohm. according to your high quality table it should be 0.05 ohm . my capacitor is an order of magnitude worse... should i return it to digikey ? complain to the manufacturer ?
What was the measurement frequency ? i don't have your particular machine, i do have a few others : A DE5000 , a Tonghui TH2821B and a HP 4263A bridge. From what i read that Peak Atlas measures at 50Khz (it's actually a range" but there don't specify what frequency is used for what)
Typically for big capacitors for bulk storage in power systems ( line voltage , not switching ) should be measured at 50, 60 or 100 and 120 hz : single phase rectification eu/us and double phase rectification eu/us. that is why ESR meters have settings for those frequencies.
Components for switching applications should be measured at higher frequencies.
The behavior of ESR for one and the same capacitor is not linear. it decreases (over frequency) very quickly in the first decade, then slows down as frequency keeps increasing.
So i can't even reproduce the readings unless i know what frequency was used for each of the cells. The peak atlas seems to have a range from 40Khz to 100Khz , so it looks like at can "adjust" depending on what it is measuring. That throws  another spanner in the works. Are all the capacitors in the same bin measured at the same frequency or did the meter decide to switch frequencies ?
Your effort no doubt took a lot of time but unfortunately the resulting table is not usable
- what brands , models were you using ? what is the spread between manufacturers/models per cell ?
- what is the frequency they were tested at ? was it locked ?
- how large is your sample size ? (not only between capacitors, but also within a same model. : i tested 3 capacitors 2200uf 16 volt. one teapio , one nichicon and one xicon... so you can see a spread between brands. but what is the spread inside the brand ? test 10 of the same make and model ,test 100 of same make and model )
There is not enough information to have a frame of reference.
Take the datasheet of the manufacturer and model and look it up, then measure it and compare.
« Last Edit: July 23, 2022, 04:34:37 pm by free_electron »
Offline floobydust
« Reply #109 on: July 23, 2022, 04:56:12 pm »
I use tables like these for a ballpark when testing parts, because failed electrolytics are an order of magnitude off. Who's got time to track down the exact datasheet for the cap when model/series numbers are rarely even on the label.
OP can you recheck table 1, the 10uF 16V and 25V values look high in comparison to parts bigger 10uF 8Ω seems high to me. Would like values for the 10V and 16V down to 1uF filled in.
Graph is from Anatek Blue ESR Meter - log scale is gross to read but graph might be a better format.
Offline wraper
  • Country: lv
« Reply #110 on: July 23, 2022, 06:09:11 pm »
This graph is an utter nonsense. Generalizing<5uF, 5-10uF, 10-100uF and 100-500uF  :palm:. Then >500uF is something entirely different. Also why the hell >500uF has entirely different ESR relation to voltage rating?  Which actually is much closer to reality than the rest. then <5/10-100uF ESR/V relations are the same, 5-10/100-500uF are the same too but entirely different from latter  :palm:.
Offline floobydust
« Reply #111 on: July 23, 2022, 07:12:39 pm »
The graphs are the latest Anatek Blue ESR Meter decal. I wasn't saying it's "accurate" or even readable (yuck!) but it's another approach compared to tables, if there were some grid lines and sanity added.
Another table was here https://www.badcaps.net/forum/showthread.php?t=95107&page=3
There, 10uF 16V is 1.6Ω
Offline wraper
  • Country: lv
« Reply #112 on: July 23, 2022, 07:18:55 pm »
I wonder why they couldn't just draw a bunch of identical plots shifted from each other on Y axis instead of drawing this nonsense.
Online Vovk_Z
  • Country: ua
« Reply #113 on: July 23, 2022, 07:52:38 pm »
1uF/16v.
ESR-2Ohm.
2 Ohm is fine for 1 uF cap.
« Reply #114 on: July 23, 2022, 10:55:14 pm »
1uF/16v.
ESR-2Ohm.
It is an incomplete specification and thus useless.
ESR is an AC parameter that is frequency dependent.
Answering the value without the measurement frequency is like giving directions to someone , but from an unknown start point.
Excuse me sire , do you know how to get to the dentist ?
Yeah, sure you go straight, then left at the crossroads, then two traffic lights over , then right at the intersection.
When the guy is about to leave you tell him , wait , those are the directions from where i live. I'm just a tourist on a guided tour...
2 ohm may NOT be fine for a 1uF cap. It all depends on the application. That little 10uf cap at the output of a lm317 or 1117 needs some ESR to keep the frequency loop stable. If you have too low an esr the regulator will oscillate.
Even modern regulators have this issue : https://www.ti.com/lit/an/slva214a/slva214a.pdf
Offline David Hess
  • DavidH
« Reply #115 on: July 24, 2022, 12:18:21 am »
ESR is is largely independent of frequency above a minimum frequency.  Here are some measurements I took of a 15 microfarad solid tantalum capacitor that I had handy using my DE-5000, and my ancient ESI 250DA gives the same results at its measurement frequency of 1000 Hz:
100 Hz   0.022 D   2.2 Ohms   15.812 uF   101 Rx
120 Hz   0.024 D   2.0 Ohms   15.784 uF   84.1 Rx
1 kHz   0.106 D   1.08 Ohms   15.507 uF   10.3 Rx
10 kHz   0.911 D   0.96 Ohms   15.081 uF   1.06 Rx
100 kHz   10.42 D   0.91 Ohms   18.15 uF   0.0877 Rx
Rx (reactance) = 1/2PiFC
ESR = D * Rx
What this shows is a relatively constant ESR, which results in an increasing dissipation (D) as the capacitive reactance falls with frequency to approach the ESR.  It is the dissipation which changes with frequency, and not the ESR, but it is changing because the losses in the relatively constant ESR become significant when the capacitive reactance approaches the ESR.
A dedicated ESR meter makes a direct AC scalar measurement of the ESR at a frequency high enough that the capacitive reactance can be ignored.  This is not as good as a vector measurement like I did above, but is close enough for diagnosis in a bulk decoupling application.  This scalar measurement of the ESR meter fails at low values of capacitance where the capacitive reactance is greater than the ESR, which for the 15 microfarad capacitor measured above is somewhere below 100 kHz.
Offline ebclr
« Reply #116 on: July 24, 2022, 06:26:32 am »
If the good or bad value to be expected can't be defined by a table. And many capacitors are extremely hard to link to a datasheet and are dependent on temperature, frequencies,, and other factors. Then is my question why measure esr , since the measured value can't be compared to nothing?  I guess is better to have a table as a reference than nothing
Offline rsjsouza
  • Eternally curious
« Reply #117 on: July 24, 2022, 12:18:31 pm »
1uF/16v.
ESR-2Ohm.
Indeed.
@1kHz:
Brand new Rubycon 1µF/50V YXM series: D = 0,038; ESR = 6,25Ω; 981,2nF
10 year old Nichicon 1µF/50V PW series: D = 0,044; ESR = 7,52Ω; 947,7nF
20 year old Tantalun 1µ/25V (unknown brand): D = 0,030; ESR = 5,28Ω; 930,9nF
40 year old Siemens 1µF/63V XD series: D = 0,042; ESR = 6,44Ω; 1056,2nF
40 year old Philips 1µ/250V (MKT): D = 0,003; ESR = 0,49Ω; 1031,3nF
@100kHz:
Brand new Rubycon 1µF/50V YXM series: D = 1,520; ESR = 2,93Ω; 827,3nF
10 year old Nichicon 1µF/50V PW series: D = 0,568; ESR = 1,08Ω; 829,3nF
20 year old Tantalun 1µ/25V (unknown brand): D = 1,863; ESR = 3,50Ω; 846,5nF
40 year old Siemens 1µF/63V XD series: D = 1,053; ESR = 1,90Ω; 907,1nF
40 year old Philips 1µ/250V (MKT): D = 0,025; ESR = 0,03Ω; 1007,9nF
All of them except the last one (which is a MKT film capacitor) fail the vast majority of tables.
« Reply #118 on: July 24, 2022, 02:29:02 pm »
do that again with an electrolytic ... that's what those tables are for. comparing (solid) tantalium to electrolytics is apples and pears, more like apples and cows. totally different species , totally different behavior.
Every capacitor behaves differently. In an electrolytic Capacitor most of the esr is split between the mechanical construction and the electrolye. The non reactive portion (pure-ohmic)  is in the conductivity of the electrolyte. the rest sits (mostly.. the electrolyte has some too) elsewhere.
Wide body, squat capacitors are made for pulse loads at low frequency : large currents after 50/60hz rectifiers with loads drawing relatively low frequency currents. Tall slender caps are for pulse load at high frequency : switchers and capable of delivering fast transients. They have very low esl.
Every capacitor family and model has its application.
As for not being able to find datasheets : that too is nonsense. capacitors are always marked . i just turned around and grabbed a few random capacitors out of my drawer. i got these at the surplus swapmeet, so i do not know the exact part number
IC - RZSM MM 105C 470uf 35v : IC = Illinois Capacitor owned by cornell-dubilier. went to cde.com (manufacturer , search for rzsm . first hit gave me part number. googled for part number -> datasheet
logo , dont recognise it - google NRSA : second hit NRSA series. open website : NIC components is manufacturer , google for NIC NRSA : first hit : datasheet
logo could be nippon chemicon , could be nichicon , don't know, don't care : 470uf LXF 63V 105c : google LXF. third hit : datasheet : LXF series united chemic-con
The key is those letter codes. That identifies the series.
The same goes for SMD electrolytics there is (almost) always a letter code that lets you identify it. it may take a bit of work but it is doable. there is always service manuals too.
It is not that hard to find the datasheet. Better than trusting a random table made with random measurement of random components , from random lineage , random model, random type with random instruments.
and comparing them to your part with your meter ...
Offline wraper
  • Country: lv
« Reply #119 on: July 24, 2022, 02:35:51 pm »
Not really, cheap general purpose Chinese capacitors often do not have series marking. Not to say there is often no website or no datasheets on the website even if you know who made them.
Online Vovk_Z
  • Country: ua
« Reply #120 on: July 24, 2022, 04:49:37 pm »
1uF/16v.
ESR-2Ohm.
Answering the value without the measurement frequency is like giving directions to someone but from an unknown start point.
We measure ESR typically at 100 kHz, plus or minus some deviation (I mean it is given in datasheets at this frequency). Even if this frequency varies +-(30..40)% from this point, such a result (2 Ohm) still is good.
Of cause, we can measure the frequency at 1 Hz, or at 10000 MHz, but this is a bit, as you say "useless".
« Last Edit: July 24, 2022, 04:52:18 pm by Vovk_Z »
« Reply #121 on: July 24, 2022, 05:32:15 pm »
that is not correct. it depends on capacitor application. The datasheets will call out the measurement frequency.
That illinois capacitor part calls it out for 120hz . same for NiC. (they give it as dissipation factor wo you can derive ESR from that (provided you know test frequency)
not the scale is logaritmic !
It all depends on the application. if you have a capacitor after a bridge rectifier you are not interested in the esr at 100KHz you want to know it at 100 or 120hz. Thermal effect in a capacitor are mainly caused by the ripple current^2 x esr .
ESR also drifts over temperature.
https://article.murata.com/en-us/article/impedance-esr-frequency-characteristics-in-capacitors
Offline David Hess
  • DavidH
« Reply #122 on: July 24, 2022, 06:05:46 pm »
The same pattern appears.  I tested 2 different new parts, and 4 very old parts.  The old Sprague 30D series compares favorably with the new modern low impedance part which explains its popularity in early switching power supplies.
ESR = D * Rx
100 Microfarad 50 Volt Nichicon PM (Low Impedance) with 2036 Date Code
100 Hz   0.024 D   0.40 Ohms   95.18 uF   16.7 Rx
120 Hz   0.025 D   0.36 Ohms   95.01 uF   14.0 Rx
1 kHz   0.071 D   0.122 Ohms   92.25 uF   1.73 Rx
10 kHz   0.547 D   0.097 Ohms   68.4 uF   0.233 Rx
100 kHz   4.86 D   0.087 Ohms   3.59 uF   0.443 Rx
100 Microfarad 25 Volt Nichicon KL (Low Leakage) with 2021 Date Code
100 Hz   0.037 D   0.66 Ohms   90.12 uF   17.7 Rx
120 Hz   0.041 D   0.61 Ohms   89.92 uF   14.8 Rx
1 kHz   0.192 D   0.354 Ohms   84.38 uF   1.89 Rx
10 kHz   1.570 D   0.315 Ohms   23.1 uF   0.689 Rx
100 kHz   23.6 D   0.284 Ohms   0.238 uF   6.69 Rx
#1 100 Microfarad 50 Volt Tektronix House Number with 7844 Date Code (1)
100 Hz   0.047 D   0.58 Ohms   125.46 uF   12.7 Rx
120 Hz   0.049 D   0.52 Ohms   124.80 uF   10.6 Rx
1 kHz   0.185 D   0.246 Ohms   115.33 uF   1.38 Rx
10 kHz   1.211 D   0.187 Ohms   41.6 uF   0.383 Rx
100 kHz   38.2 D   0.152 Ohms   0.277 uF   5.75 Rx
#2 100 Microfarad 50 Volt Tektronix House Number with 7844 Date Code (1)
100 Hz   0.038 D   0.47 Ohms   127.19 uF   12.5 Rx
120 Hz   0.042 D   0.44 Ohms   126.74 uF   10.5 Rx
1 kHz   0.181 D   0.235 Ohms   117.51 uF   1.36 Rx
10 kHz   1.208 D   0.180 Ohms   43.1 uF   0.369 Rx
100 kHz   25.9 D   0.147 Ohms   0.405 uF   3.93 Rx
#3 100 Microfarad 50 Volt Sprague 30D Series with 7421 Date Code
100 Hz   0.024 D   0.30 Ohms   119.48 uF   13.3 Rx
120 Hz   0.026 D   0.28 Ohms   119.16 uF   11.1 Rx
1 kHz   0.122 D   0.166 Ohms   115.10 uF   1.38 Rx
10 kHz   0.954 D   0.139 Ohms   57.0 uF   0.279 Rx
100 kHz   4.98 D   0.115 Ohms   2.64 uF   0.603 Rx
#4 100 Microfarad 50 Volt Sprague 30D Series with 7421 Date Code
100 Hz   0.026 D   0.32 Ohms   127.73 uF   12.5 Rx
120 Hz   0.028 D   0.29 Ohms   127.32 uF   10.4 Rx
1 kHz   0.142 D   0.181 Ohms   122.19 uF   1.30 Rx
10 kHz   1.065 D   0.148 Ohms   53.3 uF   0.299 Rx
100 kHz   6.26 D   0.125 Ohms   1.979 uF   0.804 Rx
« Last Edit: July 24, 2022, 06:08:40 pm by David Hess »
Offline smile
« Reply #123 on: July 27, 2022, 03:23:29 pm »
What about ESR for low value caps like, typical used in ATX PSU?
50V 0.33uf; 50V 0.22uf; 50V 0.1uf; 50V 1uf
Online mariush
« Reply #124 on: July 27, 2022, 04:53:32 pm »
Those are most likely not in high frequency paths, where you need low esr, so it doesn't really matter.  But I'd expect 4-10 ohm for such capacitors.
For example, you may see such small capacitor on the input of a controller chip, to smooth out the input voltage before the chip gets its power from an auxiliary winding on the transformer. don't need low esr for that.
Could be used in a comparator or opamp for protections, basic simple things that don't need low esr.
Offline smile
« Reply #125 on: July 27, 2022, 05:52:53 pm »
On one PSU the PWM circuit had 50V 0.22caps, that had 10Ohm ESR, the circuit did not work. I replaced the caps with salvaged caps that had ESR of 2Ohms. The circuit (+5VSB) began working.
You seem to be too optimistic quoting 10Ohms.
Offline wraper
  • Country: lv
« Reply #126 on: July 27, 2022, 06:25:18 pm »
2Ohm ESR for 0.22uF cap is very low, most of LOW ESR caps won't have it this low. Even 10 ohm is quite low, certainly not on a high side.
Offline David Hess
  • DavidH
« Reply #127 on: July 27, 2022, 07:43:16 pm »
They may still need low ESR to suppress ripple from high frequency load current variation.  I call these "bulk decoupling capacitors".  I have seen some power supplies that decoupled the small bulk decoupling capacitor from the load using an inductor and ceramic or film capacitor.
Because of their small volume for electrolyte for a given perimeter of rubber seal at the lead end, their operating life can be limited even in low ripple current applications.  When I change the big output capacitors in a switching power supply, I try to find these and change them also.  These were the first parts to fail in my Craftsman power tool chargers and my Maha MH-C9000 charger.  I have seen a few Tektronix power supplies that only required replacement of the bootstrap capacitor.
Offline floobydust
« Reply #128 on: July 28, 2022, 04:16:26 am »
For example, you may see such small capacitor on the input of a controller chip, to smooth out the input voltage before the chip gets its power from an auxiliary winding on the transformer. don't need low esr for that. [...]
I find the SMPS aux cap must be low ESR. They are typically 10-47uF and commonly fail, I think because the parts see high ripple current spikes with the drive switching on the mosfet. I'm not sure, they simply fail a lot. Some SMPS add a small series resistor like 10Ω feed in series with the cap after the rectifier diode.
47uF 50V ripple current spec. 100kHz varies from is 90-400mA, depending on the part. For the better parts:
Nichicon UPW 300mA at 100kHz, ESR 0.43Ω
Panasonic FR 405mA at 100kHz, ESR 0.14Ω
« Reply #129 on: July 28, 2022, 06:22:49 am »
Why does anybody ever use electrolytic caps in such low capacitance rather than film caps?
Offline David Hess
  • DavidH
« Reply #130 on: July 28, 2022, 08:19:59 am »
They are less expensive, and often their higher ESR is a virtue in bulk decoupling applications.
« Reply #131 on: July 28, 2022, 10:44:23 am »
A quick look at Digikey for .22 uF electrolytics nets some parts all designated "not for new designs".  The prices ranged from 13 cents to 43 cents.
A search for .22 uF film netted so many I didn't look through all of them for price, but I saw some for 30 cents.
You said about the electrolytic ones: "Because of their small volume for electrolyte for a given perimeter of rubber seal at the lead end, their operating life can be limited even in low ripple current applications."
For me, the rather small price difference plus the substantially lower life span would rule out electrolytics.
Offline wraper
  • Country: lv
« Reply #132 on: July 28, 2022, 12:02:34 pm »
Those prices are more than an order of magnitude higher than what manufacturer would pay for volume production. The price difference may not look that important for you but its a huge deal for mass production of inexpensive consumer devices.
Offline madires
  • A qualified hobbyist ;)
« Reply #133 on: July 28, 2022, 01:16:54 pm »
A local online shop sells a single MLCC (0805, X7R, 220nF, 50V, 125°C, Kemet) for 3 euro cents.
Offline Jeff eelcr
« Reply #134 on: July 28, 2022, 01:34:22 pm »
My answer is 12 and you put the decimal point where ever it fits as in
.012, .12, 1.2, 12.0, 120.0 fits most applications, note numbers may
vary also. :-DD
Jeff
