Author Topic: Planix 7 Battery Problem  (Read 5776 times)
Offline jaselbigTopic starter
« on: June 21, 2013, 08:47:40 pm »
Hello Everyone,
Electronics newbie here, recent mechanical engineering graduate but got into electronics while I was in school.
I just got a Planix 7 planimeter (what is a planimeter? http://www.tamaya-technics.com/e_site/planix567_e.html) that doesn't work. Here are the symptoms:
-Turns on with AC adapter connected and battery removed
-Doesn't turn on with AC adapter connected and battery installed
How should I go about troubleshooting this?
I would suspect something is wrong with the charging circuit? The battery connects to the blue and green wires.
Here are some screenshots of the board:
http://www.flickr.com/photos/97850427@N06/sets/72157634249684009/
CompElitePC
  • Guest
Re: Planix 7 Battery Problem
« Reply #1 on: June 22, 2013, 12:02:07 am »
I would start with testing TR1 and TR2 (TR1 is PNP and TR2 is NPN)  test TR2 and transistor 54ALR  first.
one question: will it power up with battery and no AC adapter?
« Last Edit: June 22, 2013, 12:07:24 am by CompElitePC »
Offline David_AVD
« Reply #2 on: June 22, 2013, 12:11:27 am »
What type of battery?
CompElitePC
  • Guest
« Reply #3 on: June 22, 2013, 12:13:58 am »
should be 4.8v nicad
Offline David_AVD
« Reply #4 on: June 22, 2013, 12:17:54 am »
Could the problem be as simple as a dead (partially shorted) battery pack dragging the system down?
CompElitePC
  • Guest
« Reply #5 on: June 22, 2013, 12:20:14 am »
possible.. checking a battery is simple enough, i imagine its been checked already??
i personally think a transistor isnt switching over.
