Selling those things in countries where the problem isn't the temperature but the humidity, is borderline scam. And outside the Sahara desert, this is almost always the case.
They do not work here, and I bet they don't work in Denmark.
Say, if you can drop 35degC 10% RH to 30degC 30% RH, you'll make it more comfortable, but the problem is the opposite in many climates.
Here you tend to need cooling for maybe 2-3 weeks per year, and then the weather is like +28 degC and RH=70%. It feels like +35 degC because of the high humidity. Lowering the RH is #1 priority, reducing the temperature a bit is an extra benefit. Those humidifiers do the opposite, they increase the RH even further. The fact that the temperature could lower by a degree or two does not compensate for the decreased comfort.
Those cheap and crappy, but real compressor based things that have a flexible tube you use to blow hot air outside, work surprisingly well in the Nordic climate I think; I'm very happy at least. They are quite noisy and suck in hot outside air, but compared to the humidifier scams, these still do the real thing, namely dry the air and, at the same time, reduce the temperature easily by a few degrees. For really hot climates, proper air conditioner units are needed, but those cheapies work well enough here. Just be careful not to mix them up with nicely branded "water evaporation" scams.
