Author Topic: Everyone's Favorite Solvent?  (Read 12813 times)
Offline CaptnYellowShirt
  • Scooty Puff Jr.
« on: February 28, 2014, 05:22:58 am »
There's a 'best' solvent for cleaning just about everything out there. But here I'm wondering what people use on their electronics?
Personally, in the last year, I've gotten on quite well with 91% isopropyl. It seems to cut though just about any gook with minimal effort, it cleans up (evaporates) easily, and doesn't harm plastic (like acetone can). I also really like CNC's QD Electronic Cleaner -- that stuff works really really well. It's a bit like using freon to clean things, but its kind of expensive, and from the smell of it I worry if its going to give me cancer.
« Last Edit: February 28, 2014, 05:24:53 am by CaptnYellowShirt »
Offline David Hess
  • DavidH
Re: Everyone's Favorite Solvent?
« Reply #1 on: February 28, 2014, 05:39:27 am »
I usually use distilled water with a little bit of dish soap or TSP.  Plastic safe contact cleaners often use naphtha as a solvent.  For other things I use isopropyl alcohol or lacquer thinner.
Offline Psi
« Reply #2 on: February 28, 2014, 06:11:42 am »
When i need a solvent here's the order i try things in.
Level 1 - Meths or Iso
Level 2 - Turps
Level 3 - Xylene (wearing gloves)
Level 4 - Acetone
Level 5 - Paint stripper (wearing gloves)
Once i get to Level 3 It's a full-on battle and either the substance dissolves or the item itself does  :-DD
« Last Edit: February 28, 2014, 06:31:25 am by Psi »
  • Scooty Puff Jr.
« Reply #3 on: February 28, 2014, 06:27:40 am »
Yeah, if I can't get something with my 'electronic' solvents its straight to the brake cleaner.
In a related subject, I've found the auto-parts store "Mag Wheel/Rim" cleaner to be highly effective at dissolving even the most stubborn oxides. Granted, its some heart-stopping concoction of hydrofluoric, hydrochloric, and phosphoric acids... but hey, at least the thing will solder up now!
Offline Psi
« Reply #4 on: February 28, 2014, 06:30:21 am »
haha brake cleaner, i've not tried that but yeah i've heard its pretty bad.
Offline BravoV
  • +++ ATH1
« Reply #5 on: February 28, 2014, 06:31:40 am »
Level 2 - Turps
Level 4 - Acetone
Level ? - Aqua Regia  :-DD
  • Scooty Puff Jr.
« Reply #6 on: February 28, 2014, 06:34:39 am »
I walk that stuff outside when I need to use it.
Offline electronics man
« Reply #7 on: February 28, 2014, 07:53:43 am »
I use isopropyl alcohol it alwase works for me.
follow me on twitter @get_your_byte
Online grumpydoc
« Reply #8 on: February 28, 2014, 07:57:49 am »
Hydrofluoric acid - it'll fetch anything off :) :)  :o
Offline GeoffS
« Reply #9 on: February 28, 2014, 08:11:41 am »
Never weld near it or on metal it's been used on. Phosgene gas can be released.
Offline Derick Freese
« Reply #10 on: February 28, 2014, 08:25:29 am »
The phosgene issue only exists with chlorinated brake cleaner.  Go for the non-chlorinated stuff.
Offline peter.mitchell
« Reply #11 on: February 28, 2014, 08:31:56 am »
And if that isn't good enough, use some HF-SbF5 (Fluoroantimonic acid), that'll surely get rid of anything.
As for solvents and the mention of brake cleaner, brake FLUID itself is a pretty damn good solvent too.
Offline 6E5
« Reply #12 on: February 28, 2014, 09:23:29 am »
Bringing things back to reality....anks
DeOxit, denatured alcohol, acetone, and lacquer thinner cover everything for me.
One useful thing to do is when you get DeOXit oil residue on your PCB because of overspray from cleaning your pot, use denatued alcohol to get it off. I hate having that lube on my PCBs. Also, it gets rid of sharpie.
I buy everything but the DeOxit in 5 gallon tanks for $20.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #13 on: February 28, 2014, 09:59:05 am »
1,1,1TCE  ...if it were available anymore.  Cuts through grease, flux, adhesive and other assorted residues like nothing, while generally leaving substrates alone.  In terms of number of materials affected and amount required to soften or dissolve them, it's probably halfway between acetone and single-carbon chlorides (methylene chloride (CHCl2) being the active nastiness in paint stripper; chloroform (CHCl3) being a little more mild, and carbon tet (CCl4) being nasty stuff either way).
Also... Level 666 :o
Oops, ya beat me to it..
Seven Transistor Labs, LLC
Offline poorchava
  • Troll Cave Electronics!
« Reply #14 on: February 28, 2014, 11:28:58 am »
Usually a stuff called PCB Cleanser manufactured by Polish company Micro-Chip (no affiliation with a bit more known company, they only deal in chemicals for electronic industry). It's IPA based with some mild additives.
For more persistent stuff i use stuff called 'Nitro'. It's a kind of solvent widely available in Poland (and other neighbouring countries). Generally it's thinner for nitrocelulose-based paints and lacquers. Typically consists of around 70% toluene and 30% acetone, but the formula is not standarised and various manufacturers add stuff like xylene, ethylobenzene, methyl or ethyl acetate and sometimes isopropyl or methyl alcohol. Generally quite nasty stuff, but it's cheap, readily available and if it doesn't work the next thing to try is a sledgehammer.
Offline Stonent
« Reply #15 on: February 28, 2014, 12:16:07 pm »
Offline madires
  • A qualified hobbyist ;)
« Reply #16 on: February 28, 2014, 01:05:07 pm »
Acetone is quite useful when dealing with ABS. Dissolve some ABS in acetone and you'll get a nice glue for ABS. No need to buy an expensive special glue.
Offline madires
« Reply #17 on: February 28, 2014, 01:10:16 pm »
Yep, the lovely nitro thinner. Use it outsides and don't have too much sniffs ;-)
« Last Edit: February 28, 2014, 01:16:19 pm by madires »
Offline nanofrog
« Reply #18 on: February 28, 2014, 03:00:16 pm »
Where are you finding it that cheap?
I'm used to seeing 1 gal containers for ~20 (denatured alcohol), and cheapest price on a 5 gal ~$43 FWIW, so a cheaper source/s would be extremely helpful. Could also use sources on cheaper IPA and maybe some MEK ($92 for 5 gal).
Offline N2IXK
« Last Edit: February 28, 2014, 03:04:52 pm by N2IXK »
"My favorite programming language is...SOLDER!"--Robert A. Pease
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #20 on: February 28, 2014, 03:14:16 pm »
I have always used MEK for that. I checked and both acetone and MEK are used but acetone dissolves ABS quicker.
Offline rstoer
« Reply #21 on: February 28, 2014, 03:20:34 pm »
I can't get away from methanol. I used it for over twenty years when I had my electronics repair business. When I started in 1969 I bought it by the gallon at the local hardware store. By the time I sold out in 1992 we had to special order it from a lab supply for big $ (at least compared to the hardware store).
I've tried everything else since. The substitutes either don't do the job as well or they eat plastics. Now that I'm back into electronics (mostly as a hobby), I got myself a liter of it (through Amazon) and it works as well as I remember.
They say it doesn't take much of it to kill you but after all these years I'm still here. Probably isopropyl is the closest in results and it's much safer, but once you've used the real thing...
Offline G7PSK
  • It is hot until proved not.
« Reply #22 on: February 28, 2014, 03:39:44 pm »
I use benzine or meths.
Hydrofluoric acid certainly shifts most things but its not much good on rubber.
  • Scooty Puff Jr.
« Reply #23 on: February 28, 2014, 04:32:10 pm »
I have a litter of methanol for optics stuff, but I rarely use it out of fear it will absorb though my skin (really, its more of a laziness to get up and find a pair of gloves). Did you always use gloves?
  • Scooty Puff Jr.
« Reply #24 on: February 28, 2014, 04:33:48 pm »
For those REALLY stubborn cleaning jobs, there's always chlorine trifluoride....
http://pipeline.corante.com/archives/2008/02/26/sand_wont_save_you_this_time.php
http://pipeline.corante.com/archives/2013/04/05/chlorine_trifluoride_some_empirical_findings.php
"It is hypergolic with every known fuel, and so rapidly hypergolic that no ignition delay has ever been measured. It is also hypergolic with such things as cloth, wood, and test engineers, not to mention asbestos, sand, and water-with which it reacts explosively"
 :scared:
Offline rdl
« Reply #25 on: February 28, 2014, 05:11:25 pm »
In general, ethanol is a better solvent than isopropanol, but not as good as methanol for some things. I wonder if the reason IPA seems to be used more in electronics has something to do with the solubility of rosin flux.
Ethanol is probably a little safer to use, after all people have been drinking it for thousands of years, whereas methanol is classified as a poison and will cause blindness or death if consumed and isopropanol will make you extremely sick at best. Warning, do not drink denatured ethanol, they put a small amount of other solvents in it to make it undrinkable, otherwise it would have to be taxed as liquor.
The plastics used for electronic parts are almost always "thermoset" types such as nylon, polypropylene, polyethylene, etc. These are not affected by solvents much, if at all. Others like ABS and polystyrene however, are thermoplastic and will dissolve in the active solvents such as acetone, MEK, etc.
Offline JoeyP
« Reply #26 on: February 28, 2014, 06:12:05 pm »
For cleaning rosin flux off of PCBs I always default to acetone. For anything else, I progress through these until something happens:
1. Water (cleans organic compounds like coffee which don't respond as well to chemical solvents)
2. Methanol
3. Acetone
4. Mineral spirits
5. MEK
6. Xylene (about as strong as MEK, but some things respond better to it)
7. Sand blasting
8. Torch
9. Hammer
Offline M0BSW
  • Left this site 2013, they will not delete it ????
« Reply #27 on: February 28, 2014, 06:18:11 pm »
I don't mind any of them, as the law is over here in the UK, your asked if your 18 years old, when you try and buy them, and at almost 60, that makes my day when I'm asked.
no one would or will tell me how to delete this account
Offline 6E5
« Reply #28 on: February 28, 2014, 06:21:56 pm »
Sorry, I buy it from a small local store who's friends with the family. But yes, from home depot its usually $20 a gallon.
Offline David Hess
  • DavidH
« Reply #29 on: February 28, 2014, 06:29:43 pm »
I have noticed before that some rosin thinners use IPA but in cleaning applications, I suspect isopropyl alcohol is used because of easy availability and lack of tax or denaturing issues.  If it were not for the BATFE, I suspect ethanol would be the preferred choice between the two.
Offline nanofrog
« Reply #30 on: February 28, 2014, 07:34:15 pm »
These are all thermoplastics as well, not thermosets. Take nylon for example (6 or 6,6). Comes in pellets for injection molding, and though it's resistant to most common solvents, it will dissolve in resorcinol for example (Benzene-1,3-diol).
Wish I had contacts like that.  ;)
Offline N2IXK
« Reply #31 on: February 28, 2014, 07:34:53 pm »
The distinction between thermoplastics and thermoset plastics has NOTHING to do with solvent compatibility. Thermoset polymers will not remelt when heated.  Bakelite is the classic example of a thermoset resin. Other examples are epoxies, melamine, and polyurethanes.
Nylon, polypropylene, and polyethylene are all thermoplastics.
Offline gibbled
  • VE7mumble
« Reply #32 on: February 28, 2014, 07:59:39 pm »
Methylene chloride is my solvent of last resort.   Available by the gallon at plastic fabricator shops.
Offline rdl
« Reply #33 on: February 28, 2014, 08:09:41 pm »
Yeah, I was kind of in a hurry. I meant to say something like "types that act more like thermoset", but I got in a hurry because I was late to an appointment. It has more to do with molecular weight and crystallinity, but I didn't want to get that detailed. At the coatings companies I've worked at, we'd to use a lot of polypropylene cups and beakers and such. We'd wash them with MEK or acetone, they could withstand weeks of soaking without much degradation. Whereas something like polystyrene will just melt almost instantly in acetone.
Offline JoeyP
« Reply #34 on: February 28, 2014, 09:01:06 pm »
Methylene chloride (AKA Dichloromethane) is one I've never tried. What is it particularly good at as compared to the others? Does it for example dissolve something like epoxy quickly?
In looking it up, I came across this site which has properties of a very wide range of solvents (and apparently online ordering of same):
http://www.sigmaaldrich.com/chemistry/solvents/dichloromethane-center.html
Offline robrenz
« Reply #35 on: February 28, 2014, 09:09:27 pm »
I have always thought of methylene dichloride or trichloride as a solvent glue for acrylic/plexiglass.
Online T3sl4co1l
« Reply #36 on: February 28, 2014, 09:24:06 pm »
Nothing dissolves epoxy (though fuming nitric acid burns it away pretty reasonably...along with everything else..), but DCM is one of the few solvents that softens it, IIRC.
Speaking of solvent welding, THF (tetrahydrofuran) is a primary constituent of PVC cement.
Oh, for something around IPA or acetone, but a little heavier, one could try ethyl acetate (typically a component of nail polish remover).
Offline gibbled
  • VE7mumble
Re: Re: Everyone's Favorite Solvent?
« Reply #37 on: February 28, 2014, 10:00:00 pm »
It is the active ingredient in the good paint strippers but doesn't have the gelling agents and wax.   A little in a sealed mason jar overnight with smps transformers and they come apart easily.
A long soak softens many potting compounds too. (although it often softens the potted components :-\)
Also handy to rapidly solvent weld some plastics.
Offline Zepnat
« Reply #38 on: February 28, 2014, 11:43:03 pm »
Although not exactly a solvent my favourite liquid in a can is plain old gas lighter refill from discount stores.
It is, I believe, similar to butane/propane or isobutane mix that is used in Air Duster cans, in the UK at least not sure about other parts of the world.
With a nozzle and small tube it works great for only 99p, against the ~£5 cost of proper air duster its a bargain.
Turned upside down its also useful for freezing stuff too  >:D
But people get a bit uptight about it, spray Air Duster all over the place and although Highly Flammable is prominently written in red no ones minds, grab a can of 'lighter fluid' with a tube on it and people are like 'WE'RE ALL GONNA DIE'!
Offline N2IXK
« Reply #39 on: March 01, 2014, 01:57:00 am »
Most of the "canned air" products I have seen here in the states were non flammable HFC-based, not hydrocarbon.  Is the use of hydrocarbons a recent development related to ODP?  I'm lucky enough to have shop air, so haven''t used one of the canned products in years.
DCM is good stuff for reverse engineering applications. Will soften most epoxy potting compounds with long term exposure/submersion. I have fond memories of using the stuff to depot/ reverse engineer cable TV descrambler circuits back in my high school days.  :) And as mentioned, great stuff for solvent welding styrene, acrylic or polycarbonate. Nasty fumes, though (and probable liver toxin/suspect carcinogen), so use in sealed container, or outdoors if you don't have access to a fume hood.
« Last Edit: March 01, 2014, 02:02:50 am by N2IXK »
Offline vk6zgo
« Reply #40 on: March 01, 2014, 02:11:41 am »
We had a Switch mode power supply self-destruct at work,so ordered a replacement from the equipment manufacturer in the PRC.
It duly arrived,mounted on a different sized heat sink which wouldn't fit our gear,so we had to swap the guts over to the old one.
There was a layer of black crud across the old heatsink,witha very large blob of melted gunk right in the middle.
I tried  denatured alcohol (Metho in Oz talk),Turps, "White Spirit"& Eucalyptus oil---nothing would budge it.
I borrowed my wife's Nail Polish remover---about a teaspoonful on a cloth removed the stuff easily.
Offline rstoer
« Reply #41 on: March 01, 2014, 06:16:18 pm »
No, I don't wear gloves. I know I should but before anyone knew you were supposed to I had been using it for decades without. No harm came to me (that I'm aware of) so I can't be bothered to start now.
In the US it was not until the 80s that restrictions began to be put on it. Before that all that was said about methanol was if you drank it you'd go blind or die. Now you practically need a hazmat suit to handle it. I would not suggest anyone not wear gloves when using it but if you're unhappy with your present cleaner of choice, it may be worth it to 'suit up' (or at least 'glove up') and give methanol a try. It's much gentler with plastics than ethanol and it cleans better than isopropyl.
Offline PedroDaGr8
  • A sociable geek chemist
« Reply #42 on: March 01, 2014, 10:44:21 pm »
Yay my world. As a chemist I have a world of solvents at my disposal. I often use solvents like chloroform abd methanol liters at a time. Methanol isn't that bad. For bulk toxicity the rule of thumb was half as drunk twice as dead in comparison to ethanol. So it's twice as toxic but had half the energizing effects. The bigger issue is it's potential carcinogenicity. Our body, as well as the bacteria in our gut, naturally produces small amounts of methanol as byproducts of metabolism. That being said wear gloves if you have them. Plus be very aware of open flames. Pure methanol burns with a faint blue flame it can be very very hard to see.
Now for my favorite solvents:
1) chloroform/methylene chloride
2) alcohols (methanol, isopropanol, 1-butanol)
3) Non-polars (xylene, toluene, benzene, hexanes)
4)DMSO/DMF (great for polar materials that aren't handled by the above)
5) ethers
6) ketones and acetates
Sent from my EVO using Tapatalk
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
  • Scooty Puff Jr.
« Reply #43 on: March 02, 2014, 04:43:20 am »
I had worked worked with Hg manometers for years before the health and safety people got wind of it. From their response, you'd think have 2 oz of this stuff covered by water in a glass tube was like forcing orphans to refine Plutonium with their bare hands.
Online T3sl4co1l
« Reply #44 on: March 02, 2014, 06:23:47 am »
Heh...
Mercury is given a lot worse rep than it deserves.  AFAIK, metallic mercury isn't really harmful, until extended exposure is had.  The *real* nasties are organomercury compounds, like dimethylmercury (a recent case being several years ago, a researcher working with the stuff got only a drop on her hand -- it diffused through two layers of gloves -- and succumbed to the symptoms several months later :o ).
On topic... mercury is a good solvent for many metals, including gold, silver, copper, tin, aluminum, etc.  At STP, it evaporates...rather slowly to say the least, especially compared to the organic solvents listed in this thread.  So it usually requires heating to achieve the same effect (ideally, by distilling it off under vacuum).  The first samples of calcium, magnesium, etc. metals were obtained in this way (by forming an amalgam, then distilling the mercury off).
« Reply #45 on: March 02, 2014, 07:37:39 am »
Still have a kilo of mercury around in a bottle, wrapped in a cloth and packed in a tin outer just in case. You need to take a big block of Aluminium and drill a small dent into the top of a smooth block, place a drop of mercury there and scratch through it to expose the metal to the mercury and leave it in a glass dish in a warm spot for a month. It vanishes leaving the mercury behind, and a dish full of oxide flowers.
Offline JoeyP
« Reply #46 on: March 03, 2014, 06:26:19 pm »
Your comment got me wondering about methanol. I've been using "Denatured Alcohol" for a long time, and thought it was mostly methanol. I buy it from Home Depot by the gallon. Doesn't say on the can just what it is, but does say it contains methanol, so I thought it was mostly methanol. Just looked it up, and found that it's about 50% methanol, 50% ethanol and a little methyl isobutyl ketone.
As far as exposure, I've been soaked up to my elbows in this stuff many times over decades, with no known effects so far (other than temporarily very dry skin) - I'm extremely healthy, and no spring chicken. I just had a look at the MSDS, and it appears that acute exposure (like drinking the stuff) can kill you or cause blindness, but typical skin contact or inhalation is likely to only cause various temporary forms of irritation like nausea or headache.
  • Scooty Puff Jr.
« Reply #47 on: March 03, 2014, 06:45:37 pm »
Good to know. I'm glad to have some practical feedback.
After I ran into the 'health and safety' people over the Hg manometers, I started to wonder how toxic the stuff really was and (if it was) how best to handle it.
I can understand the need to place highly structured warning/exposure information into an MSDS-like format -- especially from a litigation stand point. But, I think the sad thing about the culture surrounding the MSDS is it does't provide for any kind of practical knowledge of mitigating the risk.  A substance is either toxic, or not.  If its in the toxic category people start thinking about it like its an evil spirit -- you cleanse your labs of it using some prescribed ritual, preform the rites of paperwork, and are finally blessed by the high priest of 'health and safety' for continued operation. There's very little information available on what the risks are in a practical sense -- worse than 2nd hand smoke? More risk than driving to work... on a motorcycle? Personally, I'm not trying to avoid all risk in my life. There are benefits to risk. I'm trying to manage it. And to do that I need practical information.
For example, when I wanted to know about mitigating the risk of Hg exposure, I couldn't ask the health and safety people -- all they could say was "its toxic".... yes, yes, I'm aware of that... but if you think in black and white, so is table salt. Should I avoid that too?
You can't look in the MSDS -- all that says is its toxic at some mg/kg exposure. If you ask a chemist they say "go look in the MSDS". In the end I pulled anthropological  papers on gold mining in underdeveloped countries. The anthropologists detailed the ways these people dissolve gold with Hg and then distill the Au out -- and the ways they keep from exposing themselves (what's important to do, and what's not).
Anyway, my point is thanks for the info... :)
« Last Edit: March 03, 2014, 06:50:07 pm by CaptnYellowShirt »
Offline JoeyP
« Reply #48 on: March 03, 2014, 07:24:24 pm »
I totally agree with you. I wish everything weren't "Known to the state of California to be carcenogenic" etc. It would be much more helpful to have some information as to the degree of toxicity for various levels of exposure. The MSDS sort of tries to do that, but doesn't attach any numbers that would help me judge the risk for my level of exposure.
Offline rstoer
« Reply #49 on: March 03, 2014, 07:56:55 pm »
I tried denatured alcohol back when I had the electronics repair business and the methanol became hard to get. We found it damaged many plastics used in consumer electronics (I think due to the ethanol content) which made it unsatisfactory for our needs.
Offline JoeyP
« Reply #50 on: March 03, 2014, 08:16:42 pm »
I wouldn't ever use it to clean plastic. I'd probably use naptha on plastic. Each solvent has its place.
Offline rdl
« Reply #51 on: March 03, 2014, 08:22:15 pm »
Wow, what brand was this? I worked in the paint and coatings industry for 25 years and the lowest level of ethanol I remember seeing was around 80%. The basic definition of denatured alcohol is ethanol with some other stuff added, 50% methanol is unusual.
More than likely it was the denaturants that were added that caused your problems. These can be active solvents such as acetates or ketones which are very aggressive toward many plastics.
Offline JoeyP
« Reply #52 on: March 03, 2014, 08:30:09 pm »
The brand is "Klean-Strip", but it's actually made by W. M. Barr. Here's a link to the MSDS:
http://engineering.case.edu/thinkbox/sites/engineering.case.edu.thinkbox/files/msds-1-denatured_alcohol.pdf
Offline N2IXK
« Reply #53 on: March 03, 2014, 08:31:12 pm »
Chemically speaking, "denatured alcohol" is pretty meaningless. All it really means is ethanol, with enough of something else added to render it unfit for consumption.
That "something else" could be any number of different things, or combinations of them.  While methanol is one popular additive, it is certainly not the only one that can be used.  Here in the US, our government has a specific list of allowable formulations, some including diesel fuel, gasoline, pyridine, benzene, or formaldehyde. Yes, Uncle Sam would rather have you blind or dead than to let you get away with avoiding booze taxes!  :-//
A complete list of formulations available here:
http://www.ecfr.gov/cgi-bin/text-idx?c=ecfr&sid=f7866313787bfcfb2b9cd25ba6af81b5&rgn=div5&view=text&node=27:1.0.1.1.17&idno=27#27:1.0.1.1.17.7.253.1
Offline Fsck
  • sleep deprived
« Reply #54 on: March 03, 2014, 10:36:43 pm »
agreed. denatured alcohol is supposed to be ethanol primarily. The methanol and other denaturing additives are there to avoid the "alcohol" tax on consumable  alcohol.
"This is a one line proof...if we start sufficiently far to the left."
Offline JoeyP
« Reply #55 on: March 04, 2014, 12:10:37 am »
I've never given a moment's thought about hurting the government's feelings over tax enforcement when choosing my favorite solvents. The 50/50 mix of ethanol/methanol that I can buy at Home Depot for around $25/gallon is a cheap,  excellent solvent for a lot of cleaning jobs :)
Offline David Hess
  • DavidH
« Reply #56 on: March 04, 2014, 01:35:56 am »
The problem is not denatured alcohol but that it is not always clear what it is denatured with and the consumer grades may be contaminated with rather unsavory things at least as far as cleaning applications.  I have had problems with consumer grade isopropyl alcohol as well where it left film or deposits behind.  Taxed alcohol at least has the advantage of being suitable for consumption (I hope!) and therefor being "food grade" so it will not have kerosene, MEK, or benzine in it.
Offline tsmith35
« Reply #57 on: March 04, 2014, 04:16:42 am »
I buy 99% pure isopropyl alcohol (IPA) by the gallon from a nearby veterinary supply company. Cheap and works great.
Denatured alcohol typically contains (among other things) denatonium benzoate, one of the bitterest compounds around. Denatonium is the same stuff that's added to products that aren't meant to be consumed. It's so bitter that 10 parts per million is unbearably bitter to humans (per Wikipedia). It's in anti-licking spray used to keep pets from bothering wounds or infections.
Offline G7PSK
« Reply #58 on: March 04, 2014, 03:12:59 pm »
Denatonium benzoate is known as Bitrex in the UK ( http://www.bitrex.com/about-bitrex ) They put it in rat poison but the rats don't seem to mind they still eat it.
I had a friend who worked in the Cavendish laboratory in Cambridge, he used to analyse the glass washing alcohol as it came in if it was pure ethanol as it often was he would divert some of it to make gin.  :-DD
Offline zapta
« Reply #59 on: March 04, 2014, 04:12:51 pm »
Such a long thread and nobody mentioned yet The Dip (a mix of turpentine acetone and benzene) so here it is.   ;-)
Drain the swamp.
Offline rdl
« Reply #60 on: March 04, 2014, 06:03:22 pm »
I'm just curious. I see a lot of references in this thread to benzene, is this what you are really using? The use of benzene (C6H6) pretty much ceased in the U.S. a long time ago (other than it's use as a precursor to other things) mainly because it became known that it was highly carcinogenic.
Quote from: The American Petroleum Institute in 1948
"it is generally considered that the only absolutely safe concentration for benzene is zero."
Offline N2IXK
« Reply #61 on: March 04, 2014, 06:19:56 pm »
Probably some confusion between benzene (C6H6) and "benzine" which is a European (?) term for a mixture of hydrocarbon solvents akin to "naphtha" or "petroleum ether".
Offline tsmith35
« Reply #62 on: March 05, 2014, 03:43:20 am »
I've heard of using deionized water for cleaning circuit boards. Water is really my favorite solvent, right up there with ethanol... ;)
Offline nanofrog
« Reply #63 on: March 05, 2014, 03:52:59 am »
Do you make vodka out of mix them?  :o  :P
Now where'd I put that orange juice....  >:D
Offline tsmith35
« Reply #64 on: March 05, 2014, 05:23:58 pm »
It's customary to combine solidified water with ethanol. Additives are optional. ^-^
  • Scooty Puff Jr.
« Reply #65 on: March 05, 2014, 05:28:00 pm »
Carbonation helps too... also a twist of lime.
Offline tsmith35
« Reply #66 on: March 05, 2014, 09:41:13 pm »
That reminds me... d-limonene is a very, very effective solvent for removing inks, oils, adhesives and whatnot. It's commonly found in commercial "citrus degreaser".
Back at a previous job, we found that said citrus degreaser was actually more effective than xylene and other nasty chemicals at removing alcohol-based ink residue. Much safer, too, but wear gloves since it will strip the oil out of your skin.
Offline David Hess
  • DavidH
« Reply #67 on: March 05, 2014, 10:41:29 pm »
Water that is deionized or distilled or produced by reverse osmosis is my first choice.  First I wash using a detergent like dish soap or TSP and then rinse.  It works great for removing contamination which is causing board leakage.  In extreme cases instead of scrubbing with a toothbrush, I use an ultrasonic cleaner and hot water for the wash stage.  Old assembled boards come out looking new.
I have seen dishwashers used for cleaning boards in production environments.
Offline nanofrog
« Reply #68 on: March 06, 2014, 12:20:35 am »
I like how you guys think.  ;D
Though for straight ethanol, I'd skip the solidified water, and opt for a few contaminants. Namely those found in a good single malt scotch.  :-DD
Offline tsmith35
« Reply #69 on: March 06, 2014, 12:55:30 am »
So the conversation went from benzene to booze in a single page. ;)
Offline nanofrog
« Reply #70 on: March 06, 2014, 01:44:45 am »
Of course!  ;D
It's [ethanol] simply a solvent with additional uses.   >:D
Offline N2IXK
« Reply #71 on: March 06, 2014, 03:29:32 am »
Yes, and while 91% IPA might be the one for cleaning, this IPA is much more entertaining at 18%....
http://www.beeradvocate.com/beer/profile/64/9086/
