Author Topic: What component to use for a voltage controlled switch?  (Read 2446 times)
Offline raff5184Topic starter
« on: March 22, 2018, 03:59:23 am »
Hi all, very basic question.
In the attached figure what component can I use to realize a voltage controlled switch?
Basically I want to connect a capacitor to a source or a load based on the voltage across C. The switch happens at about 5V.
It is a DC circuit and I don't need high switching performance, just to switch every few minutes
Thank you
The following users thanked this post: sairfan1
Offline Bassman59
  • Yes, I do this for a living
Re: What component to use for a voltage controlled switch?
« Reply #1 on: March 22, 2018, 04:04:58 am »
Thank you
Analog switches like the DG201 and the venerable 4016 and 4066 have logic-level switch control inputs and can switch voltages up to the level of the analog rails. There are many families, it can be confusing. Tradeoffs include on-resistance of the switch, supply rails, etc.
You could also use a small relay.
« Reply #2 on: March 22, 2018, 04:12:32 am »
thank you, are there also miniaturized versions of the order of 3-4 mm?
Also, are these components passive? I mean I don't want to use extra supply voltage
Offline Bassman59
« Reply #3 on: March 22, 2018, 04:16:00 am »
You'll have to look. Maybe start with the Intersil, Vishay or Analog Devices web site parametric search.
Relays are passive. The analog switch chips I mentioned require at least one rail.
The following users thanked this post: raff5184
Offline David Hess
  • DavidH
« Reply #4 on: March 22, 2018, 02:38:41 pm »
What are the current requirements?  How much capacitance is involved and what is the load resistance?
« Reply #5 on: March 22, 2018, 03:27:46 pm »
For the capacity there are two cases:
Case I) Capacitor of C of the order of hundreds of mF, max 1F.
Case II) Rechargeable battery of about 200 J
R = 1 - 2 k \$\Omega\$
Currents 5-10 mA
« Reply #6 on: March 22, 2018, 04:27:09 pm »
Offline sairfan1
« Reply #7 on: March 22, 2018, 04:32:12 pm »
@Bassman59 I'm hobbyist and looking for same thing, i want to know what do you mean by rail here.  thanks
« Reply #8 on: March 22, 2018, 04:34:23 pm »
Forget the mechanics of this solution for a second.
What are you trying to achieve with the original outline circuit? What's your actual practical goal? What's the underlying problem you are trying to solve?
I ask because I have a suspicion that you're trying to re-invent the wheel, and we may be able to offer you some better solutions for your actual underlying problem.
« Reply #9 on: March 22, 2018, 04:37:39 pm »
"rail" is being used as shorthand for "power supply rail", the 'rail' part of the terminology coming from the common use in everyday transportation of the thing that something rides/comes in along/is carried upon.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #10 on: March 22, 2018, 04:52:33 pm »
its like mr potato solar car problem.. a small footprint can be like SN74LVC1G3157DBVR but that alone wont solve your problem, you need another comparator or schmitt trigger to switch it on and off at the correct level, and you'll need to power those... ymmv..
« Reply #11 on: March 22, 2018, 05:08:05 pm »
Very simply I have a capacitor or rechargeable battery. I charge the capacitor with a voltage supply unit. As soon as the capacitor is charged to 5.5 V I want to automatically disconnect the supply and connect the capacitor to my load. But the switch should be passive I don't have extra sources to power the switch
« Reply #12 on: March 22, 2018, 05:13:19 pm »
No, that's a description of how you are trying to solve your problem. What is your actual problem? What is your load? Why aren't you just connecting the supply to the load?
You appear to be trying to re-invent some kind of charge pump. Without knowing why you're doing this it's hard to offer suggestions.
« Last Edit: March 22, 2018, 05:15:18 pm by Cerebus »
« Reply #13 on: March 22, 2018, 05:32:48 pm »
So I have a mobile device, and this is why I can't connect the supply to the load. My mobile device has a rechargable energy storage (capacitor or battery).
The goal is that of transferring energy to the rechargeable capacity of my mobile system, store it there, and use it to power a non specified load, say an impedance or a load that uses that energy on and off with a certain duty cycle, or use it when I need to
« Reply #14 on: March 22, 2018, 05:44:58 pm »
Ah, ha!
There will be a specific IC, or probably lots of them, designed to do just that job and because this is exactly mobile phone territory they will be designed to take up absolutely minimum space. In fact, many of them will be so small that they'll be out of the 'home gamer' league (e.g. whole chip smaller than the tip of your soldering iron).
A quick look at Mouser shows 4222 'battery management' ICs. Now you have to narrow that down by battery chemistry, charging power voltage and so on. Take a look here: https://www.mouser.co.uk/Semiconductors/Integrated-Circuits-ICs/Power-Management-ICs/Battery-Management/_/N-6j76v/
« Reply #15 on: March 22, 2018, 06:38:45 pm »
do these chips provide automatic switching from the charger to the load once the storage is full? And basically, what happens during the charging? Is the "phone" being powered? Because if so it would take longer to charge it
« Reply #16 on: March 22, 2018, 07:58:26 pm »
All these are possibilities. There is a *huge* array of parts out there. You'll have to narrow it down to a few that suit your basic parameters (voltage, current etc.) and then read the datasheets for a few parts to figure out their capabilities and how they intersect with your usage.
