If one has extra components then the two ammeters can't be exactly the same model.
It's quite likely that the one designed for 8V to 18V operation, is the same as the 5V model, just with an extra voltage regulator, which can be removed or bypassed for 5V operation, but check the data sheet and schematic (reverse engineer it if necessary) first.
