Author Topic: Exceeding a resistors rated voltage  (Read 10671 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« on: June 04, 2016, 09:40:22 am »
I have something bugging me with surface mount resistors in this case. Obviously the maximum working voltage of a resistor is actually defined by its wattage and resistance as it will be the voltage at which the maximum power dissipation you are happy with or that the device can sustain has been reached. But what about transients and spikes?
I ask because I quite often design very low power devices for automotive and I do include a TVS diode but in order to make spiky world of automotive electrics a bit easier I tend to put a resistor in series with the power input as even a couple of hundred ohms is acceptable. Obviously at 12 or 24 V this is not a problem but what happens if I get a 250 V spike coming into a resistor that is spec for 150 V? And of course I have to assume that the host vehicle might not be perfect and might be worse than that and have higher voltage spikes. Will the resistor be damaged or does the maximum working voltage mean that beyond this the current would just arc between the caps of the resistor? If arcing occurs then frankly I'm not too concerned as there is a TVS diode right after it to take the voltage causing that arc and clamp it. I also tend to pot my products which I'm assuming would prevent voltages arcing through the air from one end of the resistor to the other.
« Last Edit: June 04, 2016, 09:42:22 am by Simon »
Offline Rerouter
Re: Exceeding a resistors rated voltage
« Reply #1 on: June 04, 2016, 09:48:26 am »
It comes down to the package size your using, an 0402 and your out of luck, a generic 1/4W through hole and you should be fine, based on most guidelines a separation distance of almost 2 mm is required for "functional isolation" for 250V,
Now i do think the resistor will drift from these encounters, but it would take a fair few to start causing worry. (large negative spikes at low duty cycle greatly reduced the value on some foil type resistors i have used)
Again that drift will depend on the materials chosen, and if they spec for low duty cycle currents,
Online wraper
  • Country: lv
« Reply #2 on: June 04, 2016, 10:10:24 am »
Thick film resistors will reduce their resistance if the arching occurs within them.
http://www.rohm.com/web/in/r_what10
Does your potting flow under the part?
  • Global Moderator
« Reply #3 on: June 04, 2016, 10:17:55 am »
Well at least the resistor would continue to conduct which is better than filing open circuit. No I could not guarantee that the potting compound flows under the resistor.
I have to look into resistors with bigger voltage ratings. Or just put a small but higher voltage TVS diode right at the input.
Offline coppice
« Reply #4 on: June 04, 2016, 11:09:12 am »
The specifications for SMD resistors usually specify the maximum working voltage, and its quite low for the smaller ones. It has little to do with resistance and power. If you applied a large pulsed voltage you would stay within the power rating of the resistor, but go way over the rated working voltage. The voltage rating is mostly about breakdown.
Offline coppice
« Reply #5 on: June 04, 2016, 11:20:43 am »
Usually not an issue if you pot the board or use thick conforming coating. In free air and high pollution level, the clearance will be an issue.
If you pot properly, in a vacuum, that might be true (I'm not sure. There might still be issues with the case of the resistor for all I know). I you pot the crude way most electronics is potted there will be so much gas present that you still have discharge issues.
  • Global Moderator
« Reply #6 on: June 04, 2016, 11:21:07 am »
yes it is the break down voltage I am lookng at
  • Global Moderator
« Reply #7 on: June 04, 2016, 11:38:40 am »
the potting is not the issue, the resistor itself will break down anyway.
Offline KJDS
    • my website holding page
« Reply #8 on: June 04, 2016, 11:41:14 am »
I've seen a few SMD resistor data sheets with detailed voltage spike characteristics specified.
Online Zero999
  • 0999
« Reply #9 on: June 04, 2016, 11:53:31 am »
Unless the overvoltage is extreme, the resistor will not normally breakdown and become a conductor. What will happen is the resistance will drop below the nominal value. Whether it's reversible or not depends on the extent of the surge. I suspect twice the rated voltage, for short periods, is unlikely to do any real damage.
  • Global Moderator
« Reply #10 on: June 04, 2016, 11:56:00 am »
judjing from the link posted earlier it causes damage to gthe material and starts to make links that should not be there gradually reducing the resistance.
Online wraper
  • Country: lv
« Reply #11 on: June 04, 2016, 12:42:09 pm »
That's usually caused by carbon deposition. How can ceramic turn into carbon without having a nuclear reaction? The carbon trace usually happens to heavily organic coated resistors, or resistors installed on FR4 with continuous over power stress that the resistor fried the FR4 and turned it into carbon.
:palm: Why do you think there is any carbon involved?
Online wraper
  • Country: lv
« Reply #12 on: June 04, 2016, 12:48:15 pm »
Thick Film resistors are comprised of a random dispersion of conducting metal particles within a non-conducting particulate medium, usually ceramic; hence they are also known as “cermet” resistors. Current through the resistor follows along the random contacts formed among the metal particles. Power surges cause breakdowns in some of the inter-particulate isolation, thereby reducing resistance by establishing new additional current paths. Thus, ESD surges almost always cause a reduction in resistance. This fact is so well established that Thick Film manufacturers use controlled power surges to tune the resistors to the required resistance and tolerance, which typically ranges from 5% to 20%. The susceptibility to change does not stop at manufacture and the resistor is subject to similar changes every time the resistor experiences an ESD event. ESD-induced changes while in service can cause resistance changes up to 50%, which is easily sufficient to cause a malfunction.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #13 on: June 04, 2016, 03:04:58 pm »
Use MELF resistors. They have better surge capability. You're going to need the larger power anyway for a load dump scenario.
Offline madires
  • A qualified hobbyist ;)
« Reply #14 on: June 04, 2016, 03:22:28 pm »
Multiple resistors in series to match the expected voltage spike?
Offline coppice
« Reply #15 on: June 04, 2016, 04:13:32 pm »
That's a very common and effective technique, but its prohibited by regulations in a few applications, so take care.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #16 on: June 04, 2016, 06:34:57 pm »
Huh, got any cites?
Seven Transistor Labs, LLC
Offline MK14
« Reply #17 on: June 04, 2016, 08:03:51 pm »
The problem with that method, is that if the voltage spikes, are very high frequency, it is more the stray capacitance (and inductance etc), and specific PCB layout etc, which effect how the voltage spike is transiently split amongst the resistors.
So very briefly, one (or more) of the resistors, may see MOST of the voltage transient, EXCEEDING the datasheet specification, and hence potentially gradually breaking down the insulating properties of the resistor.
There are some very good article(s) about this, on the internet. Offhand, I've forgotten where a really good one was, that I read many years ago.
tl;dr
Best to use a properly voltage rated resistor, rather than try to share the voltage amongst multiple resistors which may be unreliable or even unsafe in the longer term.
EDIT:
For similar reasons. This is why on some relatively high voltage PCB circuits, slots are cut out in the PCB, in appropriate places. To stop the high voltages/transients gradually breaking down the insulating properties of the PCB.
« Last Edit: June 04, 2016, 08:15:44 pm by MK14 »
Offline Neilm
« Reply #18 on: June 04, 2016, 09:08:13 pm »
I have used Vishay cmb0207 MELF resistors in pulse applications. Normally good for 1W rated for almost 500W pulses at voltages up to 10kV.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
  • Global Moderator
« Reply #19 on: June 04, 2016, 09:52:31 pm »
I would have thought that if you are pushing resistors in series to increase their voltage rating would need to make sure they are placed in a straight line end to end increasing the distance between 2 points where the potential is applied. If for example you put the resistor's head to tail next to each other this could mean a potential spike would jump from one resistor to another. I don't think a suitable layout is too difficult to do it just requires a little bit of common sense and the acceptance that you cannot place components any old how to save space and make things the way you want them. Dave has often pointed to examples of resistors in series to increase the rated voltage in his videos. In my case I am not trying to make up massive voltage ratings with multiple smaller resistors. Officially a 24 V system should not have a spike higher than 250 V which is what a standard 1206 resistor package is rated for so it would be prudent to put 2 of the 1206 packages in series just to ensure I have 500 V for safety sake bearing in mind that the system should only see half of that which is what each resistor is rated for anyway. I also would not see a problem putting to 0805 packages in series which are rated to 150 V each as this would get you 300 V total.
Looking on Farnell I would have to buy at least 150 resistors and a resistor rated for 500 V costs between 13 and 30p versus the 1 or 2p of a standard 250 V resistor and these resistors are much larger packages than a 1206 so they are not exactly anything special they are just bigger. I'm going to guess that if I get a high voltage rated 1206 package it will cost the earth whereas there is not really anything against me putting to 1206 resistors end to end to give myself plenty of margin.
Offline MK14
« Reply #20 on: June 04, 2016, 09:58:39 pm »
In short the voltage ratings DON'T add up like that. Since there is NO mechanism to ensure perfect voltage split between the components. Hence datasheet violations and potential eventual component failure/danger.
EDIT:
BUT in one of the cases you are describing, the single resistor was already rated for the maximum rating it would encounter. So the second/extra resistor, was to just hopefully increase the safety margin. That does NOT sound too bad. Although even in that case, it would be better to use a single, higher voltage rating part.
Although you are giving examples of stuff Dave has opened up. NOT everything which he can show, has been designed 100% correctly, as regards everyone's opinion/experience.
tl;dr
Not everything you see in manufactured electronics equipment, would be a good idea to copy. There are many cases of poor design, unfortunately.
« Last Edit: June 04, 2016, 10:38:07 pm by MK14 »
« Reply #21 on: June 04, 2016, 11:31:34 pm »
tl;dr
The place in Dave's videos you frequently see the string of resistors in series to reach a voltage rating are the input protection on bench multimeters, in particular HP/Aglient/Keysight's ones. The thing that doesn't get pointed out at the same time are the associated inductors and capacitors that make the edges of any input pulses slow enough or capacitors that feed edges forward around resistors to give the whole string time to balance out.  - this is poorly put, but you know what I mean; it's late and I'm not up for offering a full detailed explanation at the moment. Plus they use higher voltage rated parts too.
In the HP34401A input chain I can see a series of eight 2512 500V rated resistors, 3 capacitors, two inductors, a gas discharge tube and a MOV. All this for a working rating of Cat II 300V which equates to an overvoltage rating of 6000V pulse.
Offline MK14
« Reply #22 on: June 04, 2016, 11:41:23 pm »
I agree.
If PROPERLY designed and implemented, it CAN be done. (I.e. a mechanism to reliably ensure necessary even voltage sharing is created, via suitably placed passive etc components, even during very fast transients).
But the thing is that you CAN'T just connect a string of resistors in series and declare the new maximum (transient especially) maximum safe voltage to be the sum of the resistors individual ratings.
My understanding is that a lot of complicated design/development/test work takes place, in order to safely come up with such designs.
« Last Edit: June 05, 2016, 12:06:11 am by MK14 »
  • Global Moderator
« Reply #23 on: June 05, 2016, 07:07:50 am »
That is also true I have seen some pretty horrific things myself some of them designed for safety critical systems. Yes as I said the standard resistor voltage ratings are pretty much what is required but I'd like to be a little bit more resilient. As the maximum voltage I expect is 250 V a 250 V part on paper is fine but as we all know what on paper does not always describe real-life so I think I will be fair in saying that if I put 2 resistors in series no single resistor would see more than two thirds of the maximum applied voltage if I lay my board out properly which would give me a reasonable derating of the component. I suppose you could use an inductor but wouldn't the windings need to be rated for voltage? Surely if you have an inductor the voltage will simply jump from winding to winding rather than go round the winding.
I usually follow my input resistors with a capacitor or and a TVS diode I'm still trying to get my head around how much voltage and current you would actually get through the resistor considering the actual amount of power in a spike which at 250 V would not be enough to produce enough current through the resistor and or a 250 V voltage drop.
Online T3sl4co1l
« Reply #24 on: June 05, 2016, 07:21:56 am »
Automotive transients are generally quite a lot easier to deal with than ESD, EFT and surge in mains-connected equipment.  Don't worry about it.
