You get SSR's with mains input specially for this use. You might find the input spec is typically 60-265VAC at 30mA, and the output is isolated and typically is able to switch 25-30A.
You just have to be careful that the output you have is not a SSR itself, as then you will have to make sure the off state current is not going to trigger the power switch module. Normally you just use a 10W power resistor across the power switch inputs such that it draws 50ma or so to make sure the off state voltage is well below the power SSR minimum switch voltage.
