Author Topic: How to show that current leads voltage by 90° in capacitor by experiment?  (Read 569 times)
Offline Edward Yuen
  • Country: hk
Hello,
Many books told us that current leads voltage by 90° in capacitor.
How to show that it is true by an experiment with an oscilloscope?
Edward Yuen
« Last Edit: January 28, 2022, 07:32:56 pm by Edward Yuen »
Offline ejeffrey
A series RC network with a function generator.  Measure the voltage across the capacitor and measure the current by looking at the voltage across the resistor.
The following users thanked this post: Edward Yuen
Offline TimFox
Simple setup for two-channel (dual-trace) oscilloscope (analog or digital).
Choose frequency and capacitor such that the reactance is, say, 1000 ohms.
Connect generator to capacitor and other end of capacitor to small resistor, say, 20 ohms.
Other end of resistor to ground.
One channel input to generator output, which is approximately the voltage across the capacitor.
Other channel input is proportional to current through the capacitor.
Trigger the oscilloscope from channel 1 (voltage).
Offline rstofer
It's a lot easier if you have floating scope inputs.  Then you use one channel to measure the voltage across the resistor, giving current, and one channel across the capacitor giving voltage.
The easiest way I know to do this is with the Digilent Analog Discovery 2.  If I were a student, this would be my first piece of test equipment.
I don't like the new and improved pricing (a lot more than I paid) but there is a sale.  If you buy an FPGA board > $100, the AD2 is discounted substantially.  Still, a lot of money flying out of pocket.  The student price of $279 is a lot better than the list price.
Here's a video and there are MANY more.  I haven't tried any of them...
Offline Edward Yuen
  • Country: hk
I used a series RC circuit in the experiment.
In circuit one, I had sine signal to resistor to capacitor to ground.
Then, I had Vs and Vc in scope. I got the phase difference,p1.
In circuit two, I exchanged the positions of resistor and capacitor.
So, I had sine signal to capacitor to resistor to ground.
Then, I had Vs and Vr in scope. I got the phase difference,p2.
p1+ p2 is approximate to 90 degrees.
« Last Edit: January 28, 2022, 08:39:31 pm by Edward Yuen »
Offline MathWizard
What about if u used an op-amp peak detector circuit on an RC circuit, 1 for the voltage across the cap, and another the R voltage. Then if fed an AC signal, maybe that would show it on LED's for low freq, or fed into a PC. Or just on a scope, or some timer type circuitry.
Offline basinstreetdesign
Peak values will not show you the phase relationship.  That's what the OP wants.
STAND BACK!  I'm going to try SCIENCE!
Offline David Hess
  • DavidH
I would use one of two circuits and an oscilloscope.
An oscilloscope can measure the output of an RC circuit and compare it to the input.  The phase lag will reach 45 degrees at the -3dB point and increase to 90 degrees at higher frequencies.  A comparison can also be made with the capacitor and resistor swapped to make 45 degrees of phase lead.
Alternatively I would use a couple of operational amplifier in inverting mode.  A capacitor used for feedback makes an integrator with 90 degrees of phase lag at all frequencies.
