A general guide for normal hole sizing for thru-hole boards :
DIPs and wire-ended parts :0.8mm
Square-post headers, TO-220 legs : 1.0mm
For DIPs, you can go down to about 0.6mm, but in practice the only time you need to go below 0.8 is if you really need a smaller pad size due to track density, otherwise stick to 0.8.
Hole size is less of an issue on through-plated PCBs ast the solder will fill the hole pretty much whatever size it is.
You don't went the holes to be anything like a tight fit as it gets much harder to insert components, and also to unsolder them - unsoldering a tight-fitting lead in a plated hole without damaging the plating is pretty much impossible.
