Author Topic: Positive input, negative output request  (Read 2331 times)
Offline KaramelTopic starter
  • Country: tr
« on: April 10, 2016, 11:10:30 pm »
I have to get -7V from +12v or +24v input. I have searched someting on internet. There are some solutions but I didn't choose anything which is the best solution for me.
I will use it for at070tn92 lcd screen and I have just single positive power supply.
What should I do to solve this problem?
« Last Edit: April 10, 2016, 11:13:45 pm by Karamel »
Offline danadak
Re: Positive input, negative output request
« Reply #1 on: April 11, 2016, 01:43:44 am »
  • Country: tr
« Reply #2 on: April 11, 2016, 08:14:19 pm »
Thanks for replying and information.
I will use it just an experiment for one time so, I think that, Can I use small another external power supply? Like phone charger unit? I can use minus side adjustable regulator which it could be Lm337 and maybe I can get -7V from it? Is it logical solution?  :-\
Offline danadak
« Reply #3 on: April 11, 2016, 08:21:46 pm »
Hacking apart the walwart could be problematic, maybe potted.
Depends how the regulator is designed inside the walwart, could be switching
and changing Vout a little more involved depending on IC regulator used.
You can get simple charge pumps, they are dirt cheap.
Regards, Dana.
Offline Rudane
    • Electrical Engineering 101
« Reply #4 on: April 12, 2016, 04:31:38 am »
How much current do you need from the -7 V rail?
Voltage appears across and current flows through.
Offline jdraughn
« Reply #5 on: April 12, 2016, 10:41:19 am »
You could possibly use a +12v and +5v supply and make the +12v your ground and the +5v your -7v. The supplies need to be isolated from each other, but those are both very common voltages so it should be easy to find a couple of power bricks.
Online tggzzz
« Reply #6 on: April 12, 2016, 10:48:59 am »
Power bricks often, but not always, have their 0V output connected to mains earth. Been there done that :(
Offline ion
« Reply #7 on: April 12, 2016, 11:16:46 am »
Would be easier with an adjustable power adapter - set it to 7V and hook the positive to your circuit ground.  I haven't come across any that have an earth connection so it should work fine.
