Electronics => Beginners => Topic started by: Saimoun on May 17, 2024, 09:55:28 am
Hi
Is it possible to have a simple USB Type-C port on the host/source side without a USB PD chip? (for example turning on/off Vbus with transistors)
All the port has to do is to transmit power, no data.
Thank you :)
Would something like the attached circuit work for example?
I understand connecting the CC pins together breaks the standard - but since all USB-C cables only connect one of the two it should work?
Why do you want/need to switch the power? Just wire 5v and 0v to the appropriate pins of the socket?
You don't have to support power delivery for a Type-C port.
I think for a 5V device the only requirements are to have two pulldown resistors on the CC1/CC2, so if you have a simple "OR" detection on these two lines, you can control a current limited power switch with that. There are dedicated USB power controllers as well.
If you do that and two hosts are plugged into each other them boom >:D
Turning on the Vbus only when a device is connected is part of the spec :)
i think just use two diode can simpily fix the standard.
It is worth noting that PMOS may not entirely "open" if you use 10k pull up resister (3.0A@5V), in this case you may use OR gate instead.
New hands here, sorry if it offends :lol:
