- 1V per diode, so 2V per bridge is not unusual
- I guess the 35A is the max repetitive peak current the bridge can withstand, and not the continuous RMS. Add the part number and the datasheet, to see what is the 35A referring to
- same for heating, it is normal for a bridge to heat under 1A, the datasheet will tell by how much
