Not a direct answer, but: unless you are space constrained, just increase filter area to the point that the pressure generated by even simple axial fan designs running at modest RPM is enough. Positives are energy saving, less noise, easier fan choice, longer time to filter clogging. Negatives are larger size and initially higher filter cost (offset by the fact you don't have to replace it as quickly).
