Hello!
I a bit confused with a circuit on LTspice and I need your help if possible.
I tried simulating the following circuit, from my calculation the power on the Led should be around 20mA, but the simulated circuit shows 1.07mA. I tried the same circuit on other simple online simulators like part-sim and falstad and I got the 20mA. Is there something critical that I am missing? Or is it a design error in LTspice?
Thanks for your time!
