Author Topic: Feedback on transistors  (Read 1082 times)
Offline chagliTopic starter
« on: November 23, 2019, 12:54:19 pm »
I am building a low-power FM transmitter based on a pre-existing design.
The first stage is a simple discrete audio amplifier consisting of one NPN transistor (see attached picture).
I would like to understand and adapt it.
I think I have the minimum education concerning bipolar transistors (Ebers and Hybrid-Pi models).
But I am not very familiar with feedback on transistor level. I often see some qualitative statements concerning the effects but no rigorous development.
Could you recommend me a book which addresses feedback at transistor level ?
Thank you.
Offline ferdieCX
  • Country: uy
Re: Feedback on transistors
« Reply #1 on: November 23, 2019, 01:35:05 pm »
This circuit has only DC feedback.
You will find the basic circuit discussed in chapter 10 of "Electronic Devices and Circuits" by Millman and Halkias
https://archive.org/details/ElectronicDevicesCircuits/page/n142
Feedback is discussed in chapter 17
The following users thanked this post: chagli
« Reply #2 on: November 23, 2019, 01:45:42 pm »
Thanks for your answer I will look at the reference.
I think the capacitor C2 is a way to apply pre-emphasis to the audio signal by lowering the feedback at higher frequencies (thus increasing the gain).
Offline ferdieCX
  • Country: uy
« Reply #3 on: November 23, 2019, 02:24:42 pm »
You are probably right. The feedback is high at 20 Hz and very low at 15 KHz
Offline newbrain
« Reply #4 on: November 23, 2019, 02:36:08 pm »
Note that the symbol for the transistor is wrong!
It should have the arrow pointing out (NPN) not in (PNP).
The 2N3565 is, in fact, an NPN transistor.
« Reply #5 on: November 23, 2019, 03:51:40 pm »
That's right !
« Reply #6 on: December 19, 2019, 07:33:26 pm »
I finally found a book which is quite exhaustive about feedback and has examples on transistor level :
'Feedback Circuits and Op. Amps' from D. H. Horrocks.
