There are plenty of ferrite beads available as SMT packages if you really need them (Sometimes useful for IO immunity and cleaning up switchmode supply ringing).
However with 4 layer boards not being the expense they once were you can usually throw a plane under your routing layer and minimise the loop area (and radiation) that way instead, modern logic being 2.5/1.8/1.5/1.2/1.0V does not hurt any either.
Don't forget that to be a reasonable radiator the geometry has to be bigger then about 1/8th wave at whatever frequency matters, and SMT parts are usually rather small, this helps a lot.
Regards, Dan.
