Author Topic: Faucet light  (Read 5202 times)
Offline kt315Topic starter
Faucet light
« on: April 18, 2013, 12:58:27 am »
I came across one of these on the ebay: http://www.ebay.ca/itm/230867280850?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2648#ht_3115wt_1378
Any ideas how it is powered?
Online IanB
Re: Faucet light
« Reply #1 on: April 18, 2013, 01:02:48 am »
It says "no batteries required" so it probably uses a small turbine that spins as the water flows. It only needs to generate a few mA to power an LED.
Offline FenderBender
    • The Solid State Workshop
Re: Faucet light
« Reply #2 on: April 18, 2013, 01:11:32 am »
That's pretty good for US $3...
Offline David_AVD
Re: Faucet light
« Reply #3 on: April 18, 2013, 01:13:07 am »
I bought one to see how it worked.  There is a battery - the packaging lied.   :o
Basically a pair of button cells, an LED and a (water) pressure switch.
Offline c4757p
  • adieu
Re: Faucet light
« Reply #4 on: April 18, 2013, 01:15:38 am »
Shocker.
Re: Faucet light
« Reply #5 on: April 18, 2013, 01:15:51 am »
I figured as much. Not that a little dc motor and a turbine and some diodes costs that much, but for $3 idk bout that.
Offline DavidDLC
Re: Faucet light
« Reply #6 on: April 18, 2013, 01:16:33 am »
And seems like it has a temperature sensor, since the color changes based on the water temperature.
David.
Offline David_AVD
Re: Faucet light
« Reply #7 on: April 18, 2013, 01:18:29 am »
I don't recall if the one I got was colour changing (with water temperature) to be honest.  It could have been, but I do recall the coin cells.
Online IanB
Re: Faucet light
« Reply #8 on: April 18, 2013, 01:45:42 am »
Ah, makes sense. A bit like those (fake) magnetic "shake to operate" torches then, that also have a coin cell inside them...
« Last Edit: April 18, 2013, 02:13:07 am by IanB »
Re: Faucet light
« Reply #9 on: April 18, 2013, 01:46:24 am »
Wait no I thought he meant, just a switch that turns it on, not powering it.
Online IanB
Re: Faucet light
« Reply #10 on: April 18, 2013, 02:14:45 am »
Yeah, I know. They used to sell those torches that pretended to have a generator inside them, but all along they just had a battery and a switch that activated when you would shake them. All seemed fine for a year, until the battery expired and they stopped working.
Offline David_AVD
Re: Faucet light
« Reply #11 on: April 18, 2013, 02:19:10 am »
You mean somebody was making and selling something that was a sham?  Say it ain't so!   :-DD
Re: Faucet light
« Reply #12 on: April 18, 2013, 03:10:08 am »
Yeah, I was wondering where does it actually take power from. But I guess the phrase "does not require battery" can be a bit misleading.  :-//
Offline Jon Chandler
    • Throw Away PIC
Re: Faucet light
« Reply #13 on: April 18, 2013, 05:29:32 am »
I got one of these and it is powered by a turbine.  You can hear the buzz as it turns.
It has three colors, rather bizarrely arranged.  Cold water results in green light, warm water in blue and hot in red.  It does take a second or two to change with temperature.  Seems kind of gimacky, but it quickly becomes natural to check the colors before washing hands with cold water or getting a scald with too hot of water.
Offline David_AVD
Re: Faucet light
« Reply #14 on: April 18, 2013, 07:42:53 am »
There must be different varieties of them.  I think I got mine from an AliExpress seller.
Offline Hydrawerk
Re: Faucet light
« Reply #15 on: April 18, 2013, 01:05:12 pm »
Esactly. I got one in about 2002 and it was crap. In 2003 I got this rotating mobile phone charger with a white LED. It's been produced for a long time. I put a 1 Farad 5V capacitor there. This is now my real hand powered torch.
Offline daveshah
  • Country: at
    • Projects
Re: Faucet light
« Reply #16 on: April 18, 2013, 03:42:08 pm »
I once had a 'solar powered' torch that had a solar panel and diode (to prevent the battery from discharging through the panel) connected in parallel with an ordinary non-rechargeable CR2032. When I took it apart, the battery had an open circuit voltage over 5V! It dropped to almost nothing under load though.
Offline M0BSW
  • Left this site 2013, they will not delete it ????
Re: Faucet light
« Reply #17 on: April 18, 2013, 04:43:59 pm »
They Lied, surely not, advertisers don't lie do they.
no one would or will tell me how to delete this account
Offline amyk
Re: Faucet light
« Reply #18 on: April 19, 2013, 10:59:29 am »
This is something I'd like to see a teardown of (one with generator preferable, but "fake" one would be fine too.) :D
