Ordinary P-ch MOSFET requires negative gate voltage to keep it turned on, because the source will be at ground potential.
Special depletion mode N-ch MOSFETs are conductive with zero gate voltage, but they need negative gate voltage to turn them off.
I'm not very familiar with USB C, but isn't it the case that you need these resistors for data connection to work at all?
