Author Topic: Few questions about Rigol1054 use.  (Read 1022 times)
Offline TomerTopic starter
  • Country: il
« on: February 11, 2019, 09:38:19 pm »
Hello All and thank you for your help.
I have 3 questions about Rigol1054 use that i can't find answers, i went over the manual few times with no luck
* Please see attached pic.
1) Is there a way to display only a specific measurement, for example the VPP. I can only choose between display all or none ?
2) Can I clear that line or decide what will be the default readings for display ?. I find myself need to change it again and again to what i want.
3) How to stop that from being displayed  ?
Thank you for your help
Tom
Offline mcinque
  • I know that I know nothing
Re: Few questions about Rigol1054 use.
« Reply #1 on: February 11, 2019, 09:51:20 pm »
1) to show only a specific measurement use the left menu, choosing the measurement you want on the screen, this measurement will be "added" to the bottom bar on the screen; depending on the font size, you can have 4 or less measurements at the same time on the screen
2) you can clear the line with the right menu "clear"
3) if I understood correctly, you want to remove "measure all": you can do it using the right menu and pushing on "measure all"
I suggest to watch some YouTube reviews and you will understand quickly many menu commands and functions of the scope.
Hope it helps
The following users thanked this post: Tomer
  • Country: il
« Reply #2 on: February 12, 2019, 09:34:41 am »
Thank you for your help!
Tom
Offline metrologist
« Reply #3 on: February 12, 2019, 06:29:21 pm »
this is a more clunky part of the interface so not surprised it's not intuitive.
