I am trying to begin to make a complete-ish list on what always to have in your jar, My hope and goal is to give this forum a list, every beginner can go to. :-) I hope that you please will help me to add more components. I.e. there are no rectifier bridges, caps and many other.
Every component can be bought in both SMD and THT so they can be used by everyone and in breadboard.
ALL in brackets [component] are suggestions, please say so if there is any errors at all!
Diodes
1N4001, 1N4002, 1N4003, 1N4004, 1N4005, 1N4006, 1N4007, 1N5400, 1N5401, 1N5402, 1N5403, 1N5404, 1N5405, 1N5406, 1N5407, 1N5408, 1N4148
Diode Schottky
bat54, bat85, [1N5818 ]
Diodes Zener
bzx84cxxx
BJT NPN
BC547C, 2n2222, 2N3904, [2N2907]
BJT PNP
2N3906, BC547C
N-Mosfet
bs170, bss123
P-Mosfet
bss84
comparator
lm339, [TLC3702]
amplifier
lm324, op07, lm358, ua741, lm2904
voltage regulator (dependent on voltage you want to use)
7805, 7806, 7808, 7809, 7810, 7812, 7815, 7818, 7824, LM1117, [LM317]
voltage regulator (negative) (dependent on voltage you want to use)
7905, 7952, 7906, 7908, 7912, 7915, 7918, 7920, 7922, 7924, lm2903
Darlingtorn NPN
tip122, tip126
Inverting Switching Regulators
mc34063
programmable shunt regulator
tl431
Ceramic Capacitors 10n, 22n, 47n, 100n, 220n, 470n, 1u, 2.2u, 4.7u, 10u, 100u
Other
5mm led's
