Background: I've been slowly asking questions about this topic + learning about it (slowly) for years.
1.
2.
3.
4., and I think I'm almost done. Obviously the circuit has gotten more complex over time as my knowledge grew, but I'm genuinely happy with it.
My most current iteration is
here.
What the circuit does: It uses two op-amps; one for controlling the FET (so that the FET is acting essentially as a variable resistor), and another op-amp in a comparator-configuration. The purpose of the comparator is so that the FET is held non-conductive until an actual input voltage is detected (preventing a sudden current-spike when a load is connected, before the op-amp has time to regulate the FET).
_________________________________________________
The reason/question for this post: I'm wondering if anyone can provide specific suggestions on two key areas;
1. Is this resistor really needed? My rationale for it was to slow the charge/discharge of the small 100pF capacitor, but maybe at such a low capacitance, it doesn't matter?
2. Should this configuration of capacitor + resistors be changed up? My rationale for the configuration is to slow the charge/discharge of the small 1n capacitor (which I imagine is probably too-large), slow the charge/discharge of the FET gate, as well as prevent oscillations from occurring.
Thanks!
