Electronics => Beginners => Topic started by: darinsquared on November 19, 2016, 09:27:45 pm
I read a post/article on diagnosing short circuits. I thought it might have been in this forum just recently (this week) but I cannot find the post.
I am trying to find a short in a long wire run so a conductivity test will not work. One method was using a infrared thermometer or camera. I have access to a thermometer but I do not know how precise it is but I do not have a camera. I thought there was another method but I cannot recall the methodology. Any help would be appreciated. I do not know if this matters but there are multiple wires in a plastic loom. I assume the most likely spot will me a "joint" or where the wires bend.
Thanks for the reply. I do not have the equipment you mention, I am just a hobbyist interested in electronics. the wiring issue is on large farm equipment. Your second method may work however the wiring harness with the short is in a group of about 10 wires so there would be a lot of trial and error with that amount of combinations.
what test gear do you have or can have access to? DMM ? a neon lamp test stick? cable tracers?
Put a resistor in line at the source, battery, to limit the current to an amp or two and then follow the wire using a compass.
The deflection will change when you pass the short.
:clap: :clap: :clap:
Somebody give this guy a prize, that's the most ingenious solution I have ever heard.
Connect a low - impedance audible AC source ( e.g. audio amp speaker output) across the end of the cable.
This will create a current loop from the end of the cable to the short.
Then use a small handheld coil and audio amp to follow along the cable until the tome disappears, which will be near the short
