Author Topic: First "real" Kicad Project - small issues  (Read 8148 times)
Offline gildasdTopic starter
  • Engineering watch officer - Apprentice Officer
    • Sci-fi Meanderings
« on: February 03, 2016, 11:36:25 pm »
I've been using three main resources:
- Windsor Schmidt's (WS) channel: https://www.youtube.com/user/TroubleHelix
- Chris Gammel's (CG) channel: https://www.youtube.com/channel/UCkJRycUz2CylxpiP-zMePow
- And searching other threads on this forum
Sadly, some of the critical info I found is about previous versions of Kicad with frustrating differences...
-Firstly, this being my first project that does NOT use a battery, the rules checker does NOT like the 12V power in...
I used CG's Vcc method and I still get the same error, WS skips over this with no info...
Can this be solved by putting a power plug/pins in the schematics?
(See attachment 1)
-The CV PCB hates my guts (and most of my ancestors) and throws error messages galore...
This problem is solved - no chickens were sacrificed - relevant attachments removed.
I'll keep posting problems in this thread as I delve deeper into the void...
The whole schematic (See attachment 2) and in pdf (See attachment 3)
(This is a follow up to a previous thread: https://www.eevblog.com/forum/beginners/filtering-an-output-analoque-rms/msg858052/#msg858052 )
I'm electronically illiterate
Offline MarkS
Re: First "real" Kicad Project - small issues
« Reply #1 on: February 04, 2016, 02:16:35 am »
Where is the 12 volt supply coming in from? You don't have any connectors on the board connecting to the 12 volt bus. Look at the error. How are you driving the 12 volt input?
Offline ElektroQuark
    • ElektroQuark
« Reply #2 on: February 04, 2016, 06:35:44 am »
Add a "Power Flag" from the power library to both +12V and GND.
« Reply #3 on: February 04, 2016, 09:14:05 am »
Ok I get it.
Method, go to point 42: http://docs.kicad-pcb.org/en/getting_started_in_kicad.html
« Last Edit: February 04, 2016, 09:39:39 am by gildasd »
Offline MarkS
« Reply #4 on: February 04, 2016, 09:53:27 am »
I'm just getting started with KiCAD. You don't need to do that with Eagle. Odd.
Offline Codemonkey
« Reply #5 on: February 04, 2016, 09:56:52 am »
I've done a number of boards with KiCad and never had to do this either!
« Reply #6 on: February 04, 2016, 10:12:07 am »
Me neither, but all my previous projects were battery powered...
    • ElektroQuark
« Reply #7 on: February 04, 2016, 10:19:08 am »
That's ERC working. You have a pin marked as power input/output. It must be driven with power, you do taht with the power_flag. If you change that pin to be pasive, for example, the error will not kick in again, but you will miss electrical rules check.
Offline HackedFridgeMagnet
« Reply #8 on: February 04, 2016, 10:26:05 am »
The reason you only get it sometimes is because it depends on the components you place.
Some components will have pins that are marked as "power out" these nodes dont need separate power flags.
Other components will have pins marked as something else, these would need a power flag if there were other pins connected to the node that were marked as "power in".
So the DRC is trying to check for you, but lets you override it if necessary by adding a power flag.
« Reply #9 on: February 04, 2016, 04:57:29 pm »
I think I have done a mistake on the schematic (there might be a need to buffer between the preamp and the final amplification)...
This is simply an extra quad op amp (one component).
I noticed this after laying out my components in PCB new but before laying out any tracks.
Can I still modifiy my schematic without having to redo the whole component lay out?
« Last Edit: February 04, 2016, 05:08:23 pm by gildasd »
Online ve7xen
    • VE7XEN Blog
« Reply #10 on: February 04, 2016, 08:52:44 pm »
If I understand you correctly, then yes you can. If you modify the schematic and save a new netlist file (be careful not to renumber the components though...), then load the netlist in the PCB editor, it will keep everything where you put it and only add new components. There are a couple of options related to this in the read netlist dialog box.
73 de VE7XEN
He/Him
Offline suicidaleggroll
« Reply #11 on: February 04, 2016, 11:26:23 pm »
Yes, you can go back and modify the schematic or footprints as much as you want, at any stage in the design.  Just make your changes, as ve7xen said, do NOT re-number the components, assign your footprints, then in CvPCB read the netlist, and make sure you check the boxes to update footprints (if you changed the footprint for a part) or delete extra footprints (if you deleted a part in the schematic) as necessary.  Nothing will be modified on the board that doesn't have to be.  Your new parts will be placed in the normal spot for new parts, and any parts with an updated footprint will be updated in-place (make sure you re-route any tracks to its pins as necessary).
This is handy when using an MCU with extra GPIOs or using CPLDs or FPGAs.  You can lay out the parts as desired in CvPCB, then go back to your schematic and wire the components up to the pins that are most convenient given your placement.  Got a pair of tracks that would have to hop over each other to get to your MCU, and you don't have any particular reason for them to be routed to the exact pins you have them routing to?  Swap them on your schematic, re-load the netlist in CvPCB, and you're good to go.
I'm often going back and forth between CvPCB and EESchema, making small adjustments here or there to improve signal routing or make things easier.
« Last Edit: February 04, 2016, 11:33:30 pm by suicidaleggroll »
« Reply #12 on: February 04, 2016, 11:48:27 pm »
Thanks, that worked fine.  :-+
Another little issue, some ground pads did not connect to ground... Is there a manner to manually force this?
As an example, the middle pad of this TO220 needs to be to GND
Online ve7xen
    • VE7XEN Blog
« Reply #13 on: February 04, 2016, 11:58:45 pm »
It may just be that the flood fill hasn't been regenerated since the netlist changed. If you right click around the border of the fill there's an option to regenerate the fill (I don't remember exactly what it is), which will recalculate it and if it's the same net as the pin, connect it. I usually just turn the fills off until very late in layout, they just get in the way.
73 de VE7XEN
He/Him
« Reply #14 on: February 05, 2016, 12:01:37 am »
Another possibility is the clearance on the fill is set too large for it to be able to reach the middle pin without violating the clearance to the surrounding pins (doubtful in this case, but it could happen elsewhere).  You can modify the properties of the fill to reduce the clearance, which will let it reach places it otherwise couldn't.
« Reply #15 on: February 05, 2016, 12:08:29 am »
Magic, you are magic!
« Last Edit: February 06, 2016, 08:05:24 pm by gildasd »
Offline langwadt
« Reply #16 on: February 05, 2016, 12:11:23 am »
is the pin connected to ground in your schematic?
the resolution is bit low, but if it's the regulator in top left corner of "Question007-All.jpg" it looks like you didn't
« Reply #17 on: February 05, 2016, 02:13:33 am »
Yup, I had not grasped the "reflow fill after netlist modification".
The File is done, I'll check it again tomorrow before sending it.
Thanks.
« Reply #18 on: February 06, 2016, 08:17:00 pm »
Done!
I tried to use all the advice on this thread and other noob threads.
This is the third iteration, I could not get the Autoroute do work properly. Looked like a robot had a bad case of VIAs poisoning.
In the end, I did it all by hand, turning components over as needed.
Paid particular attention to not leave any "islands" of 9V or GND, the auto-checker missed most of the large  - but spotted all the small.
Oddly, I found it much easier to start on the output, never would have guessed.
Image 1: Component layout.
Image 2: 9V layer
Image 3: Gnd.
Image 4: Schematics.
Thanks to all!
Offline Godzil
    • My own blog
« Reply #19 on: February 06, 2016, 08:31:48 pm »
Your non power track seems really really thin, what setting have you used?
When you make hardware without taking into account the needs of the eventual software developers, you end up with bloated hardware full of pointless excess. From the outset one must consider design from both a hardware and software perspective.
-- Yokoi Gunpei
« Reply #20 on: February 06, 2016, 08:31:56 pm »
To compare, these are the Gerbers with partial Autoroute.
The power was done by hand and then auto-routed. Then modified to fit inside the board.
I had to hand this in, probably will get a good mark, but no way I'm sending this to manufacturing!
(Hence the version above)
« Reply #21 on: February 06, 2016, 08:33:45 pm »
0.25 (default setting), should I change this?
Offline Godzil
    • My own blog
« Reply #22 on: February 06, 2016, 08:38:12 pm »
Strictly speaking, it would depends on your board manufacturer and their capabilities.
As your design is through hole only I would have use larger track, but I don't think it make a big difference unless large current run through the tracks
-- Yokoi Gunpei
« Reply #23 on: February 06, 2016, 09:01:49 pm »
The worst case is 9V at 0.07Amps - but it would need a major short to do that.
The output is limited by 4V Zeners and the input power by a fuse.
I'll check the manufacturer http://www.mijnprintplaat.nl/prototype-printplaat-laten-maken/
Edit; error change in the URL
    Minimale baanbreedte > 6mil (> 0,153mm) trace min: 1.53mm
    Minimale afstand tussen banen/pads > 6 mil (> 0,153mm) Pad to pad min: 1.53
    Minimale afmetingen > 10x10mm min pcb size 10*10mm
    Minimale boordiameter (via's) 0.4mm min via diam: 0.4mm
« Last Edit: February 06, 2016, 09:27:30 pm by gildasd »
« Reply #24 on: February 07, 2016, 07:20:34 pm »
Due to price constraints (95€ vs 40€) I've gone single sided...
And it was HARD, here it is before optimising the GND filling.
